Ford Focus Electrical and Lighting Problems
1121315171825
  • use a 12 volt test light, turn pk light on, remove bulb, ground test light to inner surface or where bulb tangs park, then touch pointed end to bulb contact, it should light, if not, move ground clamp to a KNOWN good ground, if it lights then, you have a bad ground.if it doesn't light, you have an open in the power feed side, pos a bad socket. let me know
  • OK it may sound degrading but check the bulbs and compare them with the opposite side. if there is a single filament bulb in a dual filament socket it with cause a short and loss of power to certain components. some bulbs look very similar. You wouldn't believe how often I see this happen being a technician for four different car lines. Let me know what you find.
  • Well, I feel a bit silly, aggravated/frustrated and all those wonderful feelings. Now keep in mind I had previously gone over the fuses. And I had thought I had checked them all. So I either just missed one, or just didn't see it. because the problem turned out to be the fuse. Thank you rchannin and oldfordmech. I really appreciate the suggestions you both have given me. I still don't know how I missed the blown fuse, but somehow I did. I guess I do need my eyes checked or something. Anyways, thanks again.
  • I am having this problem with my 2002 focus se. it sit's for a few day's and its dead as a door nail. I am on my third alternator, new starter and 5th battery. have you figured out what the problem was with your's?
  • I solved the same problem by disconnecting the radio fuses. I guess the radio coils in the focus are known to drain power, especially when it gets cold.
    A mechanic suggested I disconnect the main radio fuse, plus the instrument cluster/radio fuse. However, he told me to put the cluster one back in if I experienced any driving/shifting problems because of the cluster's effect on this. But I've had both fuses out since, and no battery death.
  • What do you mean by taking the fuses out? Take them out when the car sits or take them out for good?
  • you can connect an amp meter up in line on the battery at the highest setting so you dont blow the fuse in the meter, and check the amount of amps being used while the car is off, then then you can remove the fuses one at a time and see if the amps drop drastically after each fuse is pulled. whichever fuse causes the amps to drop thats where the problem is. check the components on that circuit by disconnecting the components on that circuit one at a time with all the fuses in then again whichever causes the drop in amps thats whats causing the problem check the wires and connection before assuming the component is faulty. This is called a parasitic draw test. Sounds like there is something being grounded that shouldn't be when the car is off. You can pick up a cheap amp meter at most parts stores for ten bucks or so.
  • Hi OFM, I just joined edmunds after reading your reply to this problem:
    I have a 04 focus zx3 133,000 mi. when driving the car after it has warmed up the radio will turn off along with dash lights for a sec or two sometimes loss of power to engine. when this happens i can hear a relay clicking up under the left side of dash. also sometimes when trying to start the car there is no power to anything. the alternator is good and battery is new. any help would be appreciated!"
    I have had similar intermittent problems with a 2002 Focus ZX5 where I hear the clicking under the dash, and once turned the car off, and then attempted to turn on - but no power (even radio memory lost). Waited a couple of minutes, then turned motor on, clicking returned but when I turned on headlamps, engine promptly died. Started back up after turning the key. Got home, no clicking no dying when turning lights on. ??????? What's the clicking, etc.
  • I am a newbie on these forums so this may be a double post. Still figuring how to use Edmunds.
    But, I just noticed that my front right bright filament is out in this car. Is this related to the below problem?
    Orignal post:, I just joined edmunds after reading your reply to this problem:
    "I have a 04 focus zx3 133,000 mi. when driving the car after it has warmed up the radio will turn off along with dash lights for a sec or two sometimes loss of power to engine. when this happens i can hear a relay clicking up under the left side of dash. also sometimes when trying to start the car there is no power to anything. the alternator is good and battery is new. any help would be appreciated!"
    Clarkejoe: I have had similar intermittent problems with a 2002 Focus ZX5 where I hear the clicking under the dash, and once turned the car off, and then attempted to turn on - but no power (even radio memory lost). Waited a couple of minutes, then turned motor on, clicking returned but when I turned on headlamps, engine promptly died. Started back up after turning the key. Got home, no clicking no dying when turning lights on. ??????? What's the clicking, etc.
  • It sounds like a bad relay in the fuse box panel that is causing the clicking and possibly the electrical malfunction. You can tell which relay it is by touching the top to see if you can feel the click.
  • 2/9/10
    It's has been 1 year and the problem has never came back. It cost zero dollars to fix this issue. Thanks to the old Ford Mechanic.
    Steve
  • Glad to help, thanks for the feed back
  • help...............my shifter button , would not go in.......I have to do it manually........fuse appears to be fine.............is there a relay.............dealer is trying to sell me a shifter assembly...............HELP!
  • ? are you saying that when you have your brake applied and you try to come out of park you have use a screwdriver through the access hole and hold the paw ouer to get it out of park ? If this is the case,check and see if your brake lights are working. If they work, check to see if you have 12 volts to paw solinoid under shifter cover.If you have 12 V. there I THINK you can get the solinoid by it's self or at a junk yard. Hope this helps.
    Cliff
  • my car ford focus se 2002 cannot start after overnight rest. I changed old battery last november and it happen again. I asked car technician who replace new battery to check again. he said there in no problem after check. When I went to pick up car, it lost power again in his place. I feel some wrong with electricity. electrical leakage by somehow. could some one give me some clues to find out mycar problem?
  • Take your radio fuses out. The radio is probably draining, like mine does in cold weather.
  • persistancepersistance Posts: 5
    edited February 2010
    i had a focus wagon fully loaded and loved to drive it fun car but.........
    the car is made by ford and is a piece of under engineered crap
    tried to have it fixed several places and tried to fix it myself also I got rid of the piece of wallet sucking undependable junk and got a toyota It was my 1st [non-permissible content removed] car 2 years later just change oil and put in gas and it keeps going
    see when your an adult with kids you need dependability
    another problem with the wonder six disc cd change junk and 600 for new one from ford and o yeah all my cd's were stuck inside nice huh car only had 20,000 miles on it
    get ready for a leaking windshield when it rains and its not the windshield seal
    guy at ford said they had problems with water coming in the heater inlet and I said "your telling me" started shifting like crap too (automatic trans.) good luck
  • haulthault Columbus OhioPosts: 128
    I have a 2000 Focus since new. My solution for the battery drain problem was to wrap aluminum foil around the battery post prior to putting the cable on. It solved my connection/battery drain problem except for long periods(more than a week) of inactivity. Focus has numerous battery drain issues. I have read several solutions that have worked for different people. Countless hours and $ spent. If you are on a tight budget you can also install a "battery cutoff switch." They sell it cheapest at "Walmart." It goes on the negative side of the battery. You twist a knob for ON/OFF. The only drawback is items with "memory" may lose their memory. The switch worked perfect on my wifes older car that had a slow battery drain problem. You can use it over night or all the time if you want. Good luck!
  • Many thing can cause batt drain. 1. is the batt KNOWN to be in very good cond.?
    2. if so batt muct be dry and CLEAN, Cables & Posts clean & TIGHT at BOTH ends. 3. If #2 is good, disconnect neg cable, put a digital volt-amp meter between post & cable end, set on the 10 amp setting,key out,doors and ALL lifgts & acc OFF. read meter, if over 0.5 TO 0.75 amp draw, start removing fuses 1 at a time until amp reading falls back, when it does, you have found the bad circuit Repair that circuit and you have repaired your battery draw.
    Hope this helps.
    Cliff
  • olebikerolebiker Posts: 3
    I have a problem with blowing a fuse for the front electric windows. At first, a fuse would blow ocassionally..now it has progressed to where the fuse blows the instant the power is turn on, even before activating any switches. I have traced the wiring as much as I can see and there is no apparent damage to any wiring. Any ideas?
