Chevrolet Impala TSBs/Recalls/Problem Codes
Thanks...I understand WHY and WHEN to use fresh air. I lived in FL before moving to SC and it's even hotter here. My car stays in the garage so it is rarely super-heated by the sun. I would just prefer having the capability to leave my A/C in recirc until I chose otherwise.
That being the case, has anyone else had the updated software loaded for their HVAC and does it remain in recirc even after restarting the vehicle? Thanks!
Recirculating is recommended because it dries up the air faster, which is more effective in reaching comfort. After all, hand-held thermometers don't have a human skin.
even though this bulliten applies to 05's there may be an issue with the 06 as well
My '06 is an okay car. It does what I expect it to do (get me where I need to go). Mine has some build issues such as dash creaks and door rattles every now and then. With only 2700 miles on mine, I currently do not plan to keep it more than 2 years or so. Granted, I have not experienced the issues you are having. But, I have owned my fair share of cars in the past several years and know exactly what you are going through. It can be very frustrating and time consuming (not to mention inconvenient) to have to deal with all of that. I cannot blame you for wanting to bail out as I have done that with cars before.
For what it is worth, the range of the fob on my Impala varies in my lot at work, too. Some days it is great and other days it is weak. 95% of the time I use it, the range is very good. I chalk the weak signals up to "something in the air". Most of the time, however, I do not use the fob until I am 10 feet or less from the car. The range for the remote start has always been good (it will start from in the house).
Have you tried a little shot of belt dressing on the belt? Maybe it is not the pulley and the belt just needs a little lube? :confuse:
Best of luck to you and I hope you are able to find something to make you happy. Stress from car problems can be very upsetting.
I had a headlight replaced in the past month too. It seems that the light had melted the housing for the hehead lamp.I still need to take the info for the cooling system in and have that done. The air won't be used much now for a few months--so of course I think about it now. I only had one day that the air would not work at all----one of the warmest days all summer.
I have the rubbing/ screeching on the passenger side window and was told the fix was to be ready by late summer. If GM figured it out, someone forgot to notify the service guys at my dealership. Now that Indiana temperatures are cooler, it doesn't seem to be as bad. (However, the driver's side door is now beginning to rub slightly.)
Temperature change, though, may make or break what I do. It seemed like once it warmed up, I had less problems. I am really dreading the cold with this car.
The other issue was that the car did not always record the codes when there was a problem. I stated earlier that ONSTAR became one of my dearest connections. Whenever a light came on, I had them run a diagnostic. That way, when there was not a code recorded, a call to ONSTAR supported what I was telling the service department. (Not only that, I knew what was going on and what action I should take.)
In case you didn't guess, I have extended the ONSTAR coverage. At least I know that if the car has its issues, I have help at hand.
Like you, I have been loyal to the Chevy brand over the past 5 years. (My WONDERFUL salesperson left Oldsmobile, so I followed him to a Pontiac and then to Chevrolet.) This is my third Impala. The 2002 was traded because of mechanical issues that they could not find. I had a major trip that couldn't be changed and wasn't willing to risk what I knew was a problem. (It had a warranty repair of some kind the day that I traded it. I never found out what it was, but received a survey about the service.) I then bought an '03 that was the best car I ever owned. (Should have kept that one, but I tend to trade before the warranty is up.)
I really think that Chevy made some poor changes from that model to the current one. The heated seats were so much better on the '03. Air conditioning could literally freeze people out. Not the case on this one......
If you read through this forum, though, major problems seem to be the exception. I could live with short opening distance with the FOB. The Bose system hum is not something that would park the car. (That is not to say that I wouldn't want them fixed.)
Engine issues that ONSTAR reports from the GM statement could cause a stall without warning and tire issues/ alignment are not things that make one feel safe in THIS Impala. "THIS Impala" seems to be the key. When I trade, it will probably be a lateral move. (I have a loyalty to GM because they provided a wonderful childhood and have taken care of my dad in retirement--at least up to this point.) I have checked with many people and they assure me that this is probably the car with the least amount of problems for Chevrolet. I was just one of the lucky ones. (The service writer here says that there is only one other person having similar problems to mine and they have not been nearly as extensive. Could that be because they learned the issues from mine and his gets fixed the first time around?) When it is "healthy", I have to admit, the ride is wonderful........now if those heated seats just worked the way I expected.
I too had that window screech and sprayed down inside the window with armorll and have not been revisited by the screech. I had the window have some residue from the armorall for a couple of raises but wiped it off and it isfine now.
Gene
chrisis30, "Chevrolet Impala: Problems & Solutions" #1835, 13 Jun 2006 8:58 pm
1. See where the water is coming from within the vehicle. i.e. is it dripping from the light bulb by the heater blower motor (this is the most common), or is running down the firewall on the left or right side.
2. If it is dripping from the light bulb under the dash by the blower motor, or it is running down the left side of the firewall, your leak is coming from the deflector seal that holds the HEPA filter.
3. To locate this seal:
a.) Remove the one plastic screw cap and two push spreader caps that are located on the black plastic cowl directly under the passenger wiper arm. Pry the two caps up with a screw driver and pull out with pliers.
b.) unclip the windshield washer tube from the cowl and move it out of the way.
c.) Pull of the rear hood seal until you expose the front of the cowl.
d.) Remove the cowl.
4. You should now be looking at a plastic cover with a small air (HEPA) filter under it.
a.) The metal case that the filter sets in is called a deflector.
b.) Look at the base of it and you will see a seal.
c.) You can either remove the deflector and replace the seal, or a wiser solution is to use silicone caulking around the base.
5. Simply reverse these teps to put everything back together. All told, the repair takes 20-30 minutes.
It may seem like it is leaking down the right side, but if it is also noticeable dripping from the underdash light, or the left side of the firewall...It is coming from the heater deflector and is probably running down the dash to the right side. It's easy to tell. Once you pull HEPA filter out of the way after you notice the leak, use a flashlight to look down into the intake. You will probably see water inside.
There's a "How to" button on the left side of the home page, and from there if you scroll down to almost the bottom of that page there's a link titled " Want to know how to change the Passenger Compartment Air Filter?" This will take you step-by-step (with photos, arrows, etc.) through the process. Granted the 2006-2007 Impala might be slightly different than the previous model, but you should be able to use this info as a guide at least to attack yours.
I've tried to e-mail the guy that built the site, but I think his e-mail isn't valid any more. He may no longer be an Impala owner, as the last date I can see on the site is from July 2005, but if not I hope he keeps the site up for the rest of us; it's a great resource for things like this!
Try this site which has a number of Impala members and topics on everything.
http://www.naioa.com
I clicked on the link but could not get a reason for the recall. Anyone have any ideas?
If AutoZone can read the code and tell you what it is, at least if you then take it to the dealer the next time it happens you'll have a rough idea of what the problem should be.
