Nissan Sentra Noises
Hey guys,
I just bought a Sentra about 4 weeks ago (posted in the buying experience forum about it) and overall I like my car, but there is this weird noise that is coming out of the dash area behind the steering wheel. It kind of sounds like a hissing or spraying noise, like when fluid or air is escaping from a small hole. I took it into the dealer twice, the first time they thought I was talking about the belts, so they fixed that, but then the next time they didn't hear the noise so they told me to bring it in and have one of their "noise experts" check it out. So I went in today, he sat in the car and right when I moved forward, the noise started up ever so slightly and he said immediately he knew what it was. He said it was the power steering fluid going through the system after the car warms up and it is a normal thing for all Sentras and it was not a defect. As a result, it isn't covered under the Lemon Law. Can anyone confirm that they have this noise with their Sentras as well and have you been getting the same response?
The noise is just really aggravating and I want it to stop! :confuse: :mad:
I have no noise the way you describe the noise. The Sentra does have a fair amount of engine and road noise that are normal.
I think the noise you have is exactly the same that I have. Tell the dealer that you heard it might be related to the power steering system. I think the way you describe it is correct, it does sound like electro-static noise.
I am going to have them replace the power steering pump as well. Can you provide me with a link as to the service bulletin? That way i can print it out and show it to the service people.
Did I tell you about the person that listened to the car and said the noise was definitely NOT normal? Anyway...definitely let me know how it goes.
Agent6537
I too am having the same issue with a 2006 Nissan Sentra 1.8 special edition. I too notice it after about 20-25 min. of driving and it gets worse or better depending on whether you are turning the steering wheel. What did you ever find out when you took your car in? I am taking mine in on Friday. Also you mentioned that you had a PDF file of the service bulletin. Your e-mail was marked private so I could not contact you directly. Do you still have it? Thanks in advance for your help. I am just curious as to what you found our prior to me taking my car in to be checked.
I had the dealer replace the power steering pump, but it really didn't solve the problem (although it may have helped a little). I'm going to take the car to a different Nissan dealer in a few weeks to see if they can find the problem. Still, I would definitely recommend that you ask the dealer to take a look at your ps pump. This was such a common problem with earlier Sentras that they issued a technical service bulletin. I've unblocked my email address, so feel free to shoot me a message and I'll send you the .pdf file.
From what it looks like based on the fact it looks like more and more people are coming out of hte woodwork with the same complaint, Ithink that my dealer might be correct that the noise is normal. This blows, but the noise has gotten better on my car so that if Ihave the radio on at volume level10, Ican't hear it. Definitely can't hear it with the windows open.
:confuse:
My Sentra 2.0S is three weeks old, and the engine after it is warm and there is no other sounds, makes a ticking noise. It only noticeable when everything else is quiet.
Also, when using the auxilary jack for my iPod, the speakers emit a squeal if you will.
Anyone have similar issues?
I just found this site--so back in september I bought a
2006 nissan sentra 1.8 S, and I also have that dam noise behind the dash to--I noticed that when it is cold it does not do it,meaning cold weather or first thing in the morning
but when it gets hot I can hear it--I use to be a mechanic--more on the older cars and I do not see how it could have anything to do with the power steering in any way---my car you do not have to turn the steering wheel,but I noticed that when you rev it up between 1000- and 2500 rpms is when it does it--like there is a slight rubbing from the needle???--I do know that it does not have a cable to it--it is electronic..
So did anybody figure this out yet--or have the dealer fix it??????
I had the same issue, I bought mine in July and bagan to notice it in the Oct. time frame. My issue sounds identical to yours. It did occur in the RPM range you speak of. But with mine the noise would get better or go away when you moved the steering wheel left or right and put it under a load. My dealer here in Florence Kentucky changed the Power steering pump in late Nov. However I have heard the noise on two different occasions. Both times when I had driven it for a couple of hours straight. Before I would hear it after about 20-25 min of run time. I am curious to see if it gets worse as the weather warms up. My dealer described the issue as the power steering fluid pulsing or surging as it was being pumped. I do know that if you remove the belt and start up the car the noise is not there. I feel it is an issue with the pump, but may be a problem we have to live with.But clearly mine is 80% better with the pump replaced!! I do have a service bulitin for a 94 sentra that describes the problem and suggests changing the pump. Give me your e-mail and I will forward it to you.
My 1.8S has squeaking problems as well, whenever I'm accelerating from rest there is a slight sqeak from behind the dash. Actually, I've identified 2 distinct squeaks. I also had trouble cranking the engine--that turned out to be a bad gas pump which they replaced under warranty. We also have an '02 Altima that is basically no good now and these cars are well kept. I've also passed a few '07 Altimas that broke down, one owner told me hers was apparently electrical but no one could figure out--a dalership that's not helpful--big surprise!!! Basically, nothing phases me now. Didn't these companies pioneer 'built to last?' Whatever happened to that? I can assure you that this will be my last Nissan which is too bad because I like their design direction.
My 6-CD player also cuts in and out until it warms up---
--but no sqeeking or any other problems.
The problem is over rough roads like the frost heaving you get up north the constant vibrations WILL make thing rattle eventually.
Around Nov. of last year i noticed a knocking sound coming from the engine when warming up the car early in the morning. Then the noise would go away and come back anytime when waiting at a red light for example. Took it to the Nissan dealer and they said the noise was caused by an aftermarket filter (mobil 1 oil filter + mobil 1 synthetic oil) i used on my 1st. oil change and that i should use a Nissan genuine oil filter cause theirs have a check valve that keeps the pressure inside the engine to avoid this sound. I found that to be BS when my dad changed the oil for the 2nd. time but using an OEM Nissan filter + Quaker State synthetic oil. At the time i'm writing this my car has about 14000 miles and the noise is still there.
Took it to the dealer for the 2nd. time. Waited until the next morning to turn on the car with me and their mechanic inside, the noise is very weak and can only be heard when it's really quiet and yet they can't determine what it is. They said they would contact a Nissan expert and would let me know within 2 weeks - well i'm still waiting for their call.
Great car so far, cheap on gas, love the 6th gear and the bluetooth features.
Anybody else with the same issue on the new Sentras?
Of course after installing new starter, the sound disappeared.
From just a week ago,
when the speed is between 50 km and 55 km, I can hear whistling noise.
Even if I put the transmisson in neutral postion I can still hear the noise.
The Nissan service person said it's normal. But I don't think so.
Does some one have the same problem with me?
I also get noise when I shift from rev to drive and turn the wheel... sounds like pulling the parking brake in old stick shift cars.
I can also hear the suspension (like... springs or air puffs) every time I go over any bumps in the road.
I'm having the identical problem in my 2010 Sentra SR... a knocking noise when braking and accelerating, and a screeching sound when turning the wheel immediately after coming out of reverse.
If you can, please let me know what your dealer says about the problem. I've had the car in for this issue twice and have been told that the sounds are normal--but I'm not ready to accept that.
