At 95,000 miles??! The car is highway driven and well taken care of. And Detroit can't figure out why they're in trouble??! We are (were) a Ford family but no more. Looked at an Edge and a Mitsubishi Outlander for the wife, bought the Mitsu with the 10 year/100K mile bumper -to -bumper warranty. And you know what??! You never hear about Hondas dropping a transmission or losing an engine @ 95K!!
I'm done with American made cars,especially Ford. For those of you who have purchased an LS, be prepared. In addition to the transmission problems, there is the spark plug coil problems that will run you in the neighborhood of $600 to fix when THEY surface. That was last years problems....if I had known then what I was in for, the car would have been dumped on some dealer for a Honda/Lexus, etc.
WAKE UP AMERICAN CAR COMPANIES!! You are self destructing.
Oh really? Try recalls, class action lawsuits and continuing problems......
http://wheels.blogs.nytimes.com/2011/01/08/honda-transmission-problems-seem-to-p- ersist/
You'll enjoy your Outlander. My '07's been a great car. So has my '05 LS.
The tranny does shift effortlessly after the repair.
Does anyone know of a recall for this problem or a way to have the bill reduced?
I have a 2005 Lincoln LS. How much did it cost you to replace the solenoid pack and what were the symtoms leading up to your trans problem.
Thanks, Jerry
I have a 01 LS with a speed sensor issue that may be computer related. The sensor reads within spec for ohms. I checked the sensor feedback waveform with a O-scope to verify operation (VSS, ISS and TSS) All the sensors provided feedback with sinusoidal waveforms that varied with RPMs at the different spots in the trans. Still with a scanner the vehicle measures 0 MPH. The speedo in the car works fine. Still the trans is inoperative in D. No reverse or 5th. Can get other gears in manual. Can the input from the computer be dead? Any way to verify? Any help will be appreciated. I do get the proper reading from the computer for the Turbine Speed Sensor. There was no way to measure the Intermediate Speed Sensor.
This morning I was driving my 02 lincoln LS8 and it was doing ok, I made a stop to get gas and then started back down the road my car started acting up and wouldn't shift. I looked down and the it said "E" and in the info ctr it said ck transmission. I pulled over, shut the engine off and let it set for about 1 minute, then i dropped it manually into 1st and then shifted it up to D5, when i babied it it would go back to normal, when i got relaxed and started driving again normally it blinked back into the "E" mode. As long as I babied it I could drive it, but if I tried to drive it normally it would do the "E" mode. What is going on and how or what do I do. NOW I when I say drive normally,I am NOT driving crazy, but I do drive around 70-75 on the interstate, but I don't drive my car hard, just normal. I should mention that this morning is the coldest morning that we've had in probably 5 years, I don't know if that has anything to do with it, but I need to know what to do. Thanks
Getting the following codes on my 2004 LS. I think emission codes were there before - Ford dealer said problem with catalytic converter and suggested not bothering with. As for the others I am seeking a solution. Symptoms are waning power and also does really jerk into reverse gear. Also, "E" symbol just came up. Any ideas on what the problem might be based on the codes? Could it be just be an electrical/sensor problem or something? Thank you!
Powertrain - Auxilliary Emission Controls - ISO/SAE Controlled P0403 - Exhaust gas re circulation "A" control circuit P0443 - Evaporative emission system purge control valve circuit P0446 - EVAP system canister vent solenoid fault conditions
Powertrain - Transmission - ISO/SAE Controlled P0743 - Torque converter clutch circuit electrical P0755 - Shift solenoid 2 circuit conditions P0760 - Shift solenoid 3 circuit conditions P0962 - Pressure control solenoid "A" control circuit low P0966 - Pressure control solenoid "B" control circuit low P0970 - Pressure control solenoid "B" control circuit low
Based on what I'm seeing here and on other forums a lot of the time the replacement of these parts don't fx the issue.
Anyone got their tranny fixed to their satisfaction?
i have a 2001 lincoln ls v8 I bought the car for a great price knowing it had this problem but I cannot figure it out. The engine runs perfect but not the same for the trans. When you put it into reverse you feel it go into gear, but it will barely move no matter how much you rev it. If you put it in d5 it does the same thing you can feel it go into gear but barely will move, if you pull it down into d1 it will go into gear then it will jerk again and you can go but you have to manually switch gears, they all work fine but you have to shift manually. When you get goin down the highway and you go to pass some one and get on it a little it will slip out of gear and you have to pull it down to d4 till it goes back into gear??? And it sound like the bearing in like a pully is going bad but it sounds like it's coming from the bell housing? And it was saying check transmission so I ran the codes and there were only two there was the output shaft sensor no signal. I changed it and no more check transmission or E on dash. The other was a p0840.
