Volvo C70 Warning Lights
Had the light come on yesterday. I know the first place to check is the gas cap. It was barely on!! Don't understand how it got loose, because I always give it 5+ clicks. Maybe I had a "senior moment". Any how, the last fillup was half a tank ago. Any idea how long it takes for the system to reset and the light to go out?? :confuse:
or you could disconnect the battery for 30 minutes.
then there are pc and palm solutions.
i think this place used to sell a setup you could use from your laptop:
http://www.obdii.com/
i bought software and a cable for my Sony Clie.
For less than 4000 miles on a $47,000 vehicle, I'm seeing a lot more of the dealer than I did with my $16000, PT Cruiser.
I hope you will solve the problem quickly.
sounds like they have a true leak on their hands. sorry to hear it, but unfortunately, it happens. You could have just as easily lucked out and gotten one that would go 200k with no lights. That's exactly what it is sometimes ... luck.
Every time you think the car needs a thorough clean and wax job, you take a small hammer and plastic rod, make a little dent on a certain place on the roof, go to your dealer and complain that the problem isn't over yet?
Hmm, might work for a couple of times
I am new here. Is there a good source for the meanings of the codes? My reader only gives generic answers, and I have been told that Volvo does not always use the same key...
