Dodge Grand Caravan: Gear Shift Indicator
                    Ok guys...what did I do? I degreased & hosed the engine compartment this morning, followed by a quick check of the oil and transmission levels (only checked them; didn't add anything). Took the van on a couple short 1-2 mile trips around town this afternoon. This evening I noticed that, while pulling the van in the garage, the gear shift indicator is not always moving in sync w/the actual gears!
I guess this isn't that big of a deal because the transmission is working properly. For instance when I shift out of Park and into Drive the transmission goes into Drive and the gear shift indicator shows I'm in Drive. But if I then switch it to Reverse or Neutral the transmission complies but the gear shift indicator doesn't move!
Any thoughts?
- Rob
Any thoughts?
- Rob
A few times since then, when we start the van, all of the gear shift indicators light up. The van went in for a leak in the power steering lines in February and I asked them to check this too. They said there were no codes.
Yesterday I was driving and the road was blocked so I had to back up. Well the thing would not go into reverse. I am wondering if there was damage caused by low fluid. Any info would be greatly appreciated. There are less than 4000 km on the van and we are ready to park it and refuse to make payments. Thanks
any ideas????
A new battery put everything back to normal.
Also does the front seat belts lock when braking hard, or when pulling the front seat belts themselves real fast when seating in the seats?
SORRY FOR THE MIX UP
Re-trans indicator problems. I also had my engine / trans power washed after a streering hose broke and covered everything in steering fluid..BIG mistake!!!
I had it cleaned because a mechanic at the dealer where I took it to fix the hose tried to tell me I needed a NEW modulator valve...A $560.00 job BTW. ( because it had red fluid on it)....just like most everything else under there after the hose broke.
I didn't think that was right because my fluid never needed topping up.
The problem is that the three multi-pin connecters that go into the trans get wet..that causes all sorts of wierd things to happen.
I was OK for about a week,then all the shift indicator lights were on all at once.
then, the trans started to not shift properly, finally it would not shift into 3rd or 4th.
I found a small trans shop in Barrie and fearing the worst; I was very surprised when the owner told me ( without even looking at my van) that it was all an electrical problem, he told me to disconnect and CLEAN the 3 muti-pin plugs that go into the trans.
I did that and all was well..for a couple of weeks.
It started again, I went back and he told me to clean ALL the connections under and going into the relay / fuse pannel under the hood. Sure enough....they were mostly green!
That was the fix!! After some time the connections under that relay box can become corroded. Since I cleaned and sprayed them with "Rust Check" I have had no other problems at all. That was back in March 2008.
For a couple of hrs work and a few $ I saved what I thought would be a trans rebuild.
BTW, my speedometer also stopped working when this happened until I cleaned all those connections.
It's not hard to do, but, you have to remove the battery; The relay / fuse box is on a "hinge" and you can't move it until the battery is out of the way....
