I have heard of a $77.00 per year special they are running but don't know the code to use.
So..has anyone made the switch? I've got the 6 CD changer/AM/FM/Sat radio that's standard with the Sportwagen TDI; is the receiver that's been bandied about been tried on the latest models and has anyone had success with the swap?
I know I can take the spare XM Commander I de-installed from my trade-in and mount it under the back floor, stick the chicklet on the roof and run cables to the aux audio in jack in the armrest; I'm kind of looking for a more integrated solution.
Thoughts?
BB
09 Sportwagen TDI
Life in the fast lane, with a DIESEL of all things...:)
If you are unlucky enough to NOT have the code in the owners manual, then the radio needs to be removed and VW dealer can use the serial# from the radio to lookup the securitycode in their computer.
http://www.apple.com/ipodclassic/specs.html
Unless somthing has changed, an iPod device only *stores* music in the AAC format....no matter what format it is stored on your hard drive. The "iTunes" software does this for you under the covers. (during the 'conversion' part of the sequence)
The document you reference says it "supports" the other formats. This is accomplised via the iTunes software doing the "support" (by way of converting the files to AAC as they are sent to the iPod device)... not the iPod device itself.
And yes - I breifly owned a G3 iPod... it would only charge via a firewire connection to my computer, (would not NOT charge via USB!!) the battery was not user-replacable and the hard drive crashed. Apple informed me it would cost more than a new iPod to replace the hardDrive. I learned my lesson about Apple products and do not anticipate ever owning another one.
The iPod merely copies the files from the iTunes library. It does not convert them to AAC unless you specifically tell it to compress them to a smaller size before syncing.
Don't correct people if you don't know what you are talking about.
I am not sure where to get the code. But, take it to your dealer to get it set up for you. They should go over it with you.
Does anyone have any experience with this phone setup?
Also, I've read different things about the compatiblity of the IPOD adapter cable for units with NAV. I also have an AUX in capability. I am interested to know if anyone has definitive info on using an IPOD in conjunction with NAV equipped cars.
By the way, my car came with a six-month sat radio trial period.
For Bluetooth you can install the Skoda unit or the 9W3 thats being installed on new models. It can function without a MFSW. If you really want the phone button you could retrofit a MFSW but that would be at least $800 since it requires an expensive steering wheel and controller. It might be cheaper if you used ebay. Your airbag would be reused. If you want the full functionality on bluetooth then you should get it. It all depends on what you really want.
The NAV system already has a phone button. I dont need one on the steering wheel. Just wanted to know if anyone has experience with VW bluetooth capability in conjunction with the NAV system.
Yes it will full integrate it the iPod. You can use the touch screen to control it and it will show it on the display. It works great on some units. It works really well. As long as it's made past the 4th gen Photo unit then it will work.
The Volk-L only acts as a headset and you have to use your phones send/receive buttons. The benefit of having the MFSW is that you can send/recieve calls. The Phone button is really a menu button which can access your contacts, latest calls, and touch screen dialing. The Phone button on the wheel would enable voice dialing. Only the 9W3 and Skoda unit do this feature.
Hoiw do I remove my radio without having to remove any of the dash panels?
Thanks. A few questions. What is MDI? A cable or interface spec? Any idea of the price of an RCD-510(Premium 8)? I've seen the Bluetooth module for the RCD-510 or RNS-510 for up to $740 on ebay. Seems rather steep for a bluetooth module. I suspect the MDI Ipod cable is also expensive. Would I have to upgrade my dash? I have an 09 Jetta sedan, the MFD is red.
Shamrock22
I've seen UK sellers selling the bluetooth unit for $550. This is the new D revision unit which supports A2DP aka Bluetooth Audio streaming. No dash upgrades. If you want voice dialing you'll need an multi function steering wheel which is expensive. Those retrofits are possible. The Bluetooth module and the RCD-510 will require coding. The bluetooth will need it to configure the unit. The RCD-510 will need it if you have the Premium amplified sound system. Set it as VW sound system to enable that. Of course the MFSW will require it if you want to retrofit it. If your car has it then you don't have to do it. No cluster upgrades though.
Finally you'll need a Sirius extender so you can use the factory sirius antenna with the RCD-510.
A long post and analysis but informative. Hope this helps.
Did some checking and unless you have the NAV package the titles of the songs do not show up on the radio display.
Thanks VW for a worthless adaptor. But at least I saved myself $300 by not buying the Ipod I was thinking of getting.
Any Ideas?
Hey all - just took delivery of my silver 2010 TDI Jetta sportwagen and am loving it. The dealer forgot to include my circled option of an iphone adaptor, so I am trying to figure out the different options I have to push iphone content into the nav screen radio controls (no navigation system on-board), i.e. google maps, music, photos, etc. The armrest has a standard 3.5 femail stereo port, which I assume will only take audio off the iPhone (3g) but nothing else and I would need to control form phone, not nav screen. I did see a neat little adaptor from snedstation (https://www.sendstation.com/us/products/pocketdock/lineout-usb.html) that would allow me to push audio from the phone and also charge to an alternate input, like DC lighter, but doubt this will push any media other than audio. any ideas?
I have the same issue with my '08 Jetta, did you find a way around this problem? I used to be able to just press "CD" and it would go into aux just fine, and now it does exactly what you described.
If you found a solution I would love to hear it, thanks a million in advance!!!
S.
I have a 2009 TDI and have been unable to find a micro USB to 3.5mm Cable.
Do you remember where you obtained it ?
Thanks, Leland
