Caravan/T&C Squeaks, Squeals and Funny Noises
Brought my Wife's van back in this past Monday to have the dealer look into the continued creaking and chirping noises. The chirping, they're hoping, is coming from the timing belt. They already replaced (on a different visit) a pulley (wheel) associated with the belt. That didn't help. Now they will replace the entire belt. They wanted to keep the van overnight to see if the chirping disappears this am.
The creaking, which happened when starting to accelerate, is supposedly coming from the exhaust system. They replaced some piping and they also replace a motor mount. Isn't a motor mount a pretty big job?
Motor mounts on most vehicles are not all that hard to replace, though I am sure there are exceptions to that statement.
Most of the problems were addressed by the dealer. But, we still have a creaking sound coming from under the van. We enjoy the van, but wonder how it will hold up in the long run!
The noise occurs when accelrating form a stand still. A creaking is the only sound explanation I have...... :confuse:
I don't have any experience with these consoles, don't have one in our 2006 GC, so I am not familar how it latches into the floor, but maybe the problem is at this latch area?
I don't think the center removable console is causing the problem. When the van was in for service about 3 weeks ago, the creaking was almost completely gone after I got the van back. But, within a week, the creaking was back. I noticed that when we turn at slow speeds, it sounds like the suspension creaks or pops as well.
Also, I drove a neighbor's 2003 T&C Limited and there was NO creaking coming from their van. It actually felt more solid than ours. I also noticed that their van (w/ 74,000 miles) accelerates much better than out T&C Touring (21,500 miles). The only thing I can think of is either when the stow-n-go was added they reduced the HP of the 3.8, therefore reducing acceleration or their engine is more worn in than ours......I really don't know! :sick:
Just a thought.
Best Regards,
Shipo
Additionally, your perceptions of lower acceleration rates for your 2005 may be more perception than reality. The noise levels on the Stow and Go GC's and T&C's have been reduced from the earlier generation, and it is surprising how much a lower noise level on acceleration can fool one into believing that the van has less power.
Best Regards,
Shipo
Since your van is still under warranty, don't give up! At least get things documented that they looked for the creaks so that if the source is found later, you have proof there was a problem while it was still under warranty but went undiagnosed. Then you might be able to still get the fix covered under warranty.
I think we have the exact same van. The in dash 6 cd/DVD unit hold up to 6 cd's or DVD's OR any combination of the 2. So you can have 5 cd's and 1 DVD or 1CD or 5 DVD's and so on and so on. There are 6 numbered buttons below the 6 disc slot. When you want to load a cd/dvd push the numbered button first, the unit will then allow you to insert the disc. Push the next numbered button and insert the new disc. When you want to play one of the disc's, push the desired number and it will load that disc.
Does that answer your question?
With engine turned on and foot is on brake, engaje the trans
mission to R or D and the noise rummbling and the chirping come. so they changed the Alternator,Belt,idler...and the noise still there..chirping and rumbuling in R or D.
somebody on this planet have any idea what is this problem please tues feb 6 2007.
ring,$$water pump,$$vibration damper,$$$A/C, and the $$$ belt tensioner. yes for the chirping problem. because the rumbuling noise when you engaje in R or D is another thing.
sos...auxilio...help....please
Tune up, Full Injector service....The noise was THE BELT TENSIONER.(20 mins job)....HOOO! MMMMA' Real Life History...THE END.
You may also want to look at comments #9, 10 and 11 under the Dodge Grand Caravan Steering topic for more ideas about how to solve the problem.
I too have this strange whine when we start up the car and disappears after 10-15 seconds. My question is, what is this special steering fluid you found to work on this noise. I would like to try it first before taking it in to get service.
Thank you in advance for your reply
