Caravan/T&C Squeaks, Squeals and Funny Noises
When I first drive my van of a morning (and later in the day, as well, if it's been sitting for several hours), from under the hood we hear a noise that sounds a bit like a low-pitched dentists drill. It gets louder when I turn, and once I'm through the turn it remains, but the noise level is back to what it was prior to the turn. There are times the noise almost sounds like it's skipping.
I might compare it to the way a handheld electric sanding gizmo sounds when you accidentally run off the side of whatever it is that you're sanding, and then you quickly move the sander back over the surface. It's like... a skip.
My kids' school is 14 blocks away. By the time I take them there and back, the noise has quit.
If I let the van warm up for 5-10 minutes before driving it, I never hear the noise.
It's got another 12Kish miles on the warranty. The problem is, there are no T&C dealers locally. I'm going to have to take it 45 miles away, and by the time I get the van there, the noise will be long gone.
Does anyone have a clue what it might be?
The buzzing sound seems to originate somewhere in front of the driver’s seat --- on the driver’s side of the vehicle. (In the general area of the gas/brake pedals or slightly above) The sound can be heard both inside and outside the vehicle. The sound is muffled from the inside and louder and more pronounced when heard from outside the vehicle. (Driving with the driver's window down)
The sound occurs in the range of 1-3 seconds. At times, the buzzing sound is a short burst. Other times when the gas pedal is compressed just right the sound lasts longer and seems to get strung out. Once the buzzing sound has occurred, it will not return until you release the gas pedal and once again try to accelerate the vehicle at a somewhat slow pace.
Furthermore, since the weather has turned cold the noise has seemed to disappear.
Usually only occurs at slow speeds, but I think I heard it on the highway once. Once the van is moving, accelerating does not seem to make the sound. My wife says it's getting worse (happening more often).
it's a 2005 TC Touring with the Stow-n-Go and about 55000 miles.
Any ideas?
I also have oil all over the engine block, but there is no oil dripping on my drive or garage, the mechanic said it might be the oil leak is when the engine is on.
Has anyone had similar problem?
Happy Holidays
K
We found that the rear brake pads wore unevenly ( they had been pressing in a V shape instead of flat against the rotor) and had worn out on just one edge of the pad.
So, if you look at one side, they looked good, but upon removal, the other side, which you couldn't see without removing them, was worn down to the metal and that was causing our noise. New brake pads and rotors fixed our noise and we have not had it come back.
Sorry for the rant!
At 8500 miles, brand new I had to replace the front brake pads. At 11k driver side axel and front ball joint. At 16k all tires were bad replaced, 19k rear brakes. I drive City of Philadelphia over 30 traffic lights one way to work everyday. I replaced the brake rotors at 24k and brake pads 3 more times before 27k. At 29k, I walked out new years day to find the Rack and Pinion was leaking out of the passenger dust boot. Replaced under warranty. The humming noise in the front is the combo between the power steering and Rack and Pinion. If the alignment is off it will add more to the humming noise. At 27k the power steering was making strange noise, the dealership stated, I had air in the line and the drilling noise was the air in the line? 90 days later, at 29k I walked in and told the guy "REMEMBER ME?" the Rack is now leaking, so you guys couldn't figure out where the air was coming from? He did not reply except smile at me and said, we will check for impact accident and if not impact will replace under warranty. They have known for a while these vans have issues with the Rack and Pinion and Power Steering unit. At 38k after factor warranty expired, the water pumps died on me. Dodge has let me down for the last time. After being a dodge/Mopar Chrysler customer for over 20 years, I am tired. Right now, my front brakes are making noise. I replaced them April 15, 2009. One last note, everyone will like this, for some reason or another when very cold the turn signal will not work left or right or one will work but not the other. They said it was a unit inside the steering column $325+. I said, think again. For everyone reading this pass the word for all these caravan. Take a bottle of WD Liquid Wrench Spray, or Pepboys Brand. Clean the turn signal outside the steering column. Turn to right turn, spray inbetween the turn lever, then turn to left turn signal and spray. Lightly not too much. Allow to sit for a while, turn on the car, and spray cold air .Use one of the cans used to clean your pc. Allow to sit for a couple of hours, then spray the liquid WD again. What is going on is Chrysler Dodge did not put an extra protection cover inside the turn lever. Dirt and dust get in and in the cold water/moister gets in and makes the unit fail. I told the guy at the dealership what I did and he smiled again.
Take care all
Bart
2009 Dodge GC SXT
Actually, its probably a round disk like thing that goes near one or both of your front wheels. Not sure on the part name but when mine were replaced it fixed my moaning problem for exactly the same issue.
Mini Van Dad
