We have an updated look. Click here for information on how to manage your settings. If you run into any issues, please email [email protected]
Ford Freestyle Rear Brakes
I have a '06 Freestyle AWD (26K miles) and took my vehicle in for an oil change and tire rotation. The mechanic noted that the is severe and uneven wear on the rear brake pads. He asked if I accidently did not take off my parking brake, which I never use. I called the dealer and the service technician said that brakes are considered "normal" wear on the car and are not covered, which I understand if I didn't only have 26k miles on it. Has anyone else had problems??? -- Thanks.
it gives them a history to work from.
Stay tuned.....
The guy at the service lane mentioned that the rear brakes need to be done at the 20000mls service but then checked with someone else. That tech guy obviously knew about the problem and did not let my wife drive away.
She was brought home and later was picked up by the dealer's shuttle service! Last time the Freestyle was in for service we even got a Lincoln Navigator as loaner free of charge because they couldn't get a spare part in time! We really cannot complain about our Ford dealer and still are more than happy with the Freebie
Carsten
but here's why it's going in.
Water in the right rear tail lights after rain.
Vibration in brakes (rear brakes I believe) under noderate braking. (just noticed it this past weekend)
The car has about 8000 miles on it.
I'll keep you updated on the solutions.
The rotor wore because the pads wore out. I'm afraid it is the owner's responsibility to ensure that the brake pads are OK. Didn't they check the pads at the 5000 miles checkup?
I was getting the same vibration that you described. I questioned the service tech on how a pad can induce vibration, but he just said that it is a known issue and the new pads will alleviate the problem. I will let you know if it works.
I'd have to disagree with you here. There is NO way that brakes should wear out on a new car that has only 8500 miles on it. And the owner should NOT be responsible for something like that. Shame on any service dealer for expecting a new owner to foot the bill for something like that.
Having said that, mine is going in on Friday for the same thing and I'm interested in hearing their diagnosis of my brakes. I'll keep everyone updated.
How about if he/she holds the brake while using the accelerator?
The legal contract for the warranty states that wear items are not covered. I agree that they should not wear that much under normal conditions.
If I were the dealer I would cover the repairs just for good customer relations.
If I hold the brake while hitting the gas, don't you think the all four rotors need to be worked? :P
And just got off the phone with Ford customer service, and was told rotor is not covered, but the CS just cannot find a complete list of the items covered only for 12 month/12k or 18k miles. :mad: :mad: :mad:
LOL good one! :-) Those people are few and far between though and not the norm...I hope.
They've already stated that the pads are an issue with the Freestyle and they are aware of it. If the rotors (as another poster stated) are destroyed by the "faulty" pads, then Ford is required to fix the rotors also free of charge.
I'll keep you updated...just dropped it off this morning.
see my above post on my brake problem. Have your dealer verify that the pads are faulty...probably a service bulletin on them.
Carsten
No charge.
They were unsuccesful turning them because rotors nowadays are made for one time usage and are not supposed to be turned down...they tried anyways and failed...must have warped them worse.
Anyways....short story...no charge :shades:
Are we talking rear brakes only here?
How many miles on the odometer and what were the symptoms?
My FWD Freestyle is now 14 months old and I continue to see far more brake dust on the rear wheels than on the front. In fact, I never see any on the front.
Oh, I wasn't talking about your case. I was responding to someone saying that the pads don't wear out that fast.
LOL good one! Those people are few and far between though and not the norm...I hope. "
Call me bigfoot, but I have to be consciously aware of where my right foot is resting. My foot is big enough that I hit the accelerator and brake if I'm not careful.
I don't have a problem with hitting the brake while I'm accelerating, just vice versa.
Same with mine, but only the rear driver's side. I have 33K miles and no brake problems, other than the dust.
Rear brakes only with 8000 miles on the car since last July.
Symptoms were I could feel the brake pedal pulsing when I applied moderate to heavy braking. I knew something was wrong and I suspected the rear brake pad problem that has been talked about here.
I was referring to the people that use the right foot for the gas and the left foot for the brake, and have a tendency to hit both at the same time.
Carsten
Bottom line, this sucks!!! I have never had any brakes go out before 50k on any Ford I have owned. This is how car companies lose customers. A recognized problem, but they are not willing to help. I even offered a pro rated solution and got turned down by the local rep and the customer relationship center (CRC). The local rep is the one who gave me all this info, so I at least felt like he heard me, but the CRC was worthless. A complete waste of time not too mention, I was waiting for someone to pick up the phone for 20 minutes.
I don't know who I will buy my next car from, but if nothing changes, it won't be a Ford.
From a loyal Ford owner (6 cars in 15 years).
Obviously another case of poor engineering!
At any rate, assuming Ford doesn't change their response, I will let my dollars do the talking for me the next time I get a car. Considering my 2000 Focus has over 100k, that may be real soon. Seems a shame because up until now, I planned on getting another Focus; I really like that car.
Oh well. I am sure I can find another car out there that I like. There are plenty to choose from in that price range.
I am thinking of selling this car asap. Previously, I've always owned Hondas, and they never had to have anything other than regular oil changes.
Take a deep breath mandy. Sounds like your '05 Freestyle is one that was built prior to February 2005, and would have had the original rear brake pads that were used up until that time. There is (I believe) a "service bulletin" from Ford that addresses the problem. Your dealer should be aware of this and will install the newer "improved" pads. They (the dealer) will treat you kindly on the matter if you only give them a chance to.
BTW.. there isn't a Honda on the planet that is the safety cage the Freestyle is.
it is too bad you are having a brake problem, i just think your post does not address the real problem.
Actually, all the newer models do have a similar advanced safey design, called ACE. It is on the 2007 CR-V, for example.
Of course, it isn't the same safety cage as the FS, so I suppose your statement is technically correct. But I differ with the factualness of the statement.
I think it is crazy that Ford programmed the brakes this way. For a car that sits up higher, it has no front plow to its braking, so I guess that is the positive.
So... unless you were personally involved with programming the brains of the braking system in the Freestyle, you don't know what you are talking about. I don't either, but I know what Ford's regional rep told me. Why did he tell me that if it wasn't true? It certainly didn't make me feel any better about the car. All it told me was that my rear brakes will need to be replaced much more frequently than what I am used to, which certainly didn't make me happy.
If the HO gets enough of your complaints they will launch an investigation and implement a recall and correction.
I am a Fusion owner and was considering moving over to a Freestyle, but my honest rep told me to hold out till Ford figured out what was going on with the rear brakes.
Speak out directly to Ford customer service, not the dealer.
Cheers/
Mark.
