Oldsmobile Intrigue Steering Issues
When turning and or braking at slow speed, I get a clunking or poping noise up by the steering column. It is most prevalent when turning to park the vehicle. It seems to be getting louder as time goes on. Anyone experienced this?
Tnx: Howco4
Tnx: Howco4
Our 2001 Intrigue went back into the dealer last Tuesday because of a "tick-tick-tick" that sounded like lifters or piston noise. We never had this before they replaced the head gasket & right cylinder head. The dealer has been consulting with the GM Techs and he warned us that the bottom line may be an engine replacement! We've only got 51,000 miles on our car but the good news is that we have full warranty til 60,000. We are now driving a courtesy 2004 Malibu until our car is returned. Another perk of the warranty.
I can estimate that our car has spent nearly 6 weeks in the shop over the past 4 years and at least $12,000 in major repairs. Maybe once it's totally rebuilt it will be as depenable as it is fun to drive.
:confuse:
I had this problem on my 2001 Aurora (V6) when I bought it year ago.
Pretty bad popping feeling, more pronounced when turning left.
Dealer replaced bearings in the column, did not help.
Then he sent all column for rebuild - no help...
Then, when popping became just terrible, I went to the small garage and Mechanic pumped Lithium grease into the steering shaft, deep inside, putting turning and removing column 7-9 times, pumping additional grease every time.
78 months since then there is no problems - For 122 bucks!
I am having a very much similar problems with my 98 olds' intrigue. How was your problem solved? Was it very expensive?
I send my car to a dealer and a mechanic told me I had this problem by a short try of driving. They said the cost would be around $1,200, which I do believe is somewhat to expensive.
Do you have any idea which might be of some help to me? Thanks!
I just bought a 1999 intrigue gsl a few weeks ago. Its in great condition....However, i have a slight clunkiness when I turn at slow speeds, and its now starting to squeel a bit when i turn. The car just feels a bit weak in the front steering column. Also I'm getting about 14 mpg city and part hwy. I know that, that sucks. I bought from the dealership and they said that they'll fix mechanical problems within the month. Ive brought it in a couple times and told them about my problems but they keep saying that they dont see anything wrong. Should I bring it in to another mechanic first to get the car diagnosed. I'm hoping that I didnt get jipped, I really want the car to run well. Can anyone please give me some advice, it would be greatly appreciated.
Thanx!
gas mileage: check the easy things first like air filter, tire pressure, driving habits.
What engine do you have the 3.8 or 3.5?
I will check the air filter and tire pressure, thanks.
I have a 3.5
Di
At 75,000 I traded the 99er on a 2002 GL-what a deal-Nov.2002-they were giving them away. Traded it in May 2007 on a 4300 mile 2006 Pontiac Grand Prix GT-loaded to the brim. The 2002 Intrigue had 119,500 miles, sweetheart of a car, but had some problems. No engine,a/c,transmission, or electrical mishaps. Major tire cupping problems tthrough 67000 miles-24 cupped babies, Chevy dealer finally aligned the car for 275 buckeroos, switched to Michelin "Harmony" and after 50,000 miles they were good for another 25k..Tires were balanced on the car with a strobe light. The 3.5 engine was finally tuned-plugs only, @111,000 miles.Battery was replaced at 95k, right frt hub@98k. One ISS @ 60k and brakes were never touched until 65k and they were a problem until 100k then I had some cheap rotors installed and watched the torguing of the lug nuts. Oil burning was always a problem with Mobil oil and I switched to Penn around 40k and had the oil changed every 3k. The original trans fluid was still good at the end and never added any coolant throughout the ownership period. The 3.5 was never touched and never failed. It was 100% Florida driving-mpg was between 25-31. I regret that I sold the car, but it was time to part. Bought the Pontiac just because it had low miles and was a cheap deal. Caddy tradein. However the ISS has been replaced @13k and-the supercharged engine loves gas. The Intrigues were a pain at times, but they were a much better performing car overall. The Grand Prix GT is a low-tech auto but it will serve the purpose until GM gets its act together. I only buy Detroit iron-no transplants...
Previous answers on hard transmissions shifts were much appreciated. PCV valve was replaced at low cost and problem is gone.
The DIY fix for the ISS is to grease the steering shaft connection under the dashboard. Move the driver's seat all the way back; follow the steering wheel under the dashboard; slide back the rubber sheath and you should feel a metal connection. If you are small enough to get al the way under the dashboard, you may be able to see it. get a can of silicone grease and spray this connection. If the ISS is the problem, you should feel a noticeable difference in the steering. Plus a can of silicone grease only cost $3.50.
have your mechanic check the wheel sensors, bearings and tie rods as well. It sounds like you have a good mechanic.
Should I expect to have to replace the starter, the alternator and the exhaust pipe system any time soon, as I intend to keep the car for another 2-3 years ? What else could go wrong ?
there are no guarantees esp. with this vehicle. The good thing is many of the issues have been addressed on this website and this one: http://www.automotiveforums.com/vbulletin/forumdisplay.php?f=764,
some of the issues that have been popping up are A/C problems, transmission issues, some head gaskets, suspension wear (age related), etc. The thing to remember is even the most recent Intrigues are 8 years old now. Most have some miles on them.
good luck.
I had the rack and pinion replaced at my local mechanic at half the price of the Goodwrench guys. They had a life guarantee on the part. They also replaced a front wheel hub and bearing that worn out.
I know some other repairs will show up, given the actual mileage and age. Rear suspension has been replaced 2 years ago, as well as tie-rods. I believe I should be able to get another 40k miles at a reasonable cost. Anyhow, the current resale value of the car is between 1/1.5k$. There is not much risk here.
