Oldsmobile Intrigue Transmission / Suspension Problems
pastort
Member Posts: 1
in Oldsmobile
I recently purchased a GLS from a very good used car lot - willing to fix anything in the first month. Also with a drivetrain and transmission warranty for 2 years or 30,000 miles. Three times now while highway driving the car started to shake and shudder, really felt it in the steering wheel. Felt like a wheel was out of balance. This happened between 40 and 65 mph. They checked it out - no codes. Thinking the engine might be missing I punched it down - only got worse as speed increased. I let off the gas and while approaching a stop the car didn't seem to roll freely - any ideas.
I have a '99 Olds Intrigue GX with an Automatic transmission with 113,000 miles on it. I've owned it for the past 3 1/2 years with no major issues until the past year.
I'm experiencing hard shifting from time to time (lasting one or two jerks that only happen maybe once every few weeks or so) that gets a lot worse when I'm doing "stop and go" city driving in warm weather. It first got worse for me I want to say it was late last summer. Hubby has a Scan Tool and was able to pull a Code of P0742 - Torque Converter Clutch Stuck On.
The hard shifting eventually subsided completely when the weather got colder, but now that it's been getting into the 90s, last Wednesday night it got worse again. After the car sitting for several hours while I was at work I drove a few blocks to to pick up a friend, car sat for a couple minutes, drove a few blocks to the park, the car sat for a 1/2 hour, drove a few blocks to drop off my friend, and along the way it started jerking a bit and acting up. In the past, sometimes if I just manually shift the car, it helps to better control the car so that's what I did. However, after I dropped her off, when I was on my way home, it got much worse. I didn't even a few blocks from my friend's house before it was hard shifting no matter how I drove it and it did this for about 3 miles or so. I turned the car around so that I could park it back at my workplace a couple miles away. 30 minutes passed with the car off and my husband drove it home without any trouble.
I have driven it since with very little problems, and we even drove it on a road trip yesterday (highway miles mostly) taking it about 120 miles from home with little problem.
Any suggestions, or has anyone else experienced the same thing??
~Tracy
I had the exact thing happen last summer. It shifted incredibly hard and made a "clunking" noise from time to time, always during city driving. I would pull over, turn it off, and restart. Worked every time...but I don't know why. I posted here and it seems lots of people have had this problem. Someone wrote that they heard disconnecing the battery for 30 min or so helped, so I tried it.....oddly enough, I haven't had the problem since. Now, I don't know if the problem will return this summer, but I'd say it hasn't happened since last July. Very odd problem. Anyway, Sorry I'm not much help...but if you figure out the real root of the problem let me know.
You might want to get a transmission fluid and filter change before adding it though if you haven't had that service during the past 3 years.
This has happened several times and I have not been able to get it to do it while at the dealer. Today I went to the parts store and bought a code scanner but the check engine light had went off. I connected the scanner anyway and retrieved code P0742 which says something about the torque converter solenoid being stuck. Does this make sense and is there anything you could point to that would help me solve this problem?
A. Gee, a GM product with a stuck TCC solenoid, how rare. Actually this is very common on GM vehicles. You would think after ten years of problems with it, they would have come up with a better way of controlling the lockup torque converter.
It seems like it is just sticking intermittently so I would suggest a transmission fluid and filter change to see if the clean fluid will clean out the TCC solenoid. If not, it will have to be replaced.
Going to a local mom and pop tranny place today to get an estimate, so will let you know what I Find out
Yesterday my husband talked to the local GM dealer mechanic who said they may be able to "trick" the car into thinking it's running properly by cutting a wire somewhere. The computer is overriding where it shouldn't be or something? It supposedly wouldn't cause the car any harm, except when it would "act up" their wouldn't be any power towards the solenoid, which is causing the problem. Anyone heard of doing this?
~Tracy
Currently I get about 20-23mpg. I will definitely post in the next few weeks what my gas mileage becomes at this point.
Another thing we are planning is to install a switch where that wiring is located. That way, in the summertime when I'm having issues with the solenoid due to hot weather, I can flip the switch so the power to the solenoid is switched off. In the wintertime when I don't have issues at all, I will have the switch flipped so that there is power to the solenoid.
I will keep you posted.
~Tracy
~Tracy
A bit nervous about the transmission only because the tranny went on my old Delta 88 at 95K!!
Interestingly enough, I also had the transmission fluid replaced etc (brother did that for me so not exactly sure what was done) last December.
Seems like the car jerks when the car shifts.
I bought some Lucas product to try...is this as good as the Napa product?
I figured, it can't hurt and might even help. Should I have my mechanic try this wire-clipping trick too?
Don't want to replace the transmission!
Thanks for any suggestions,
Di
a) Your Service Engine Soon (SES) light comes on
b) Your mechanic retrieves a code from a Scan Tool
c) The code retrieved is one of the 2 codes that the dealer manual suggests to do the wire clipping "trick"
My husband does mechanic work on our cars so he was able to do the wire-clipping once he checked the book to see which exact wire that it was - - but only AFTER he gave the code we got from hubby's Scan Tool to the dealership mechanic, who told us about the wire-clipping.
Hope that helps. Good luck!
~Tracy
P.S. - A "side effect" of the wire-clipping of course is that since there is no power going to the TCC Solenoid, the car recognizes this and therefore the SES Light is on all the time now. But as long as my car runs smoothly then we don't worry. Since hubby has a Scan Tool we can also check the codes from time to time as well.
Had to replace the lower control arm vertical bushings on my 2000 Intrigue GL at 150,000 km's. GM parts guy was suprised they had only lasted that long as this was the first time he had ordered these parts for an Intrigue (Winnipeg dealer). Pain in the butt to replace as you have to remove the entire control arm. Took about an hour for both sides but overall not too bad.
Service Engine Soon light does not go on.
Guess that's a good thing!
Di
So! I have a question. Has anyone else experienced the phenomenon of having the transmission go soon after having the transmission flushed, etc? Maybe it's just dumb luck/coincidence, and my other Olds lost the transmission at 95K, too.
How will I know when it is imminent? Right now it isn't slipping, just clunking, and it is intermittent. Is there a diagnostic "code" for "your transmission is about to quit"? Seems as though I heard someone mention one (seriously).
PS Should I add another bottle of Lucas?? I really can't afford for the tranny to go now.
Any input is welcome )
Di
Di
Good news, the tranny is not shifting as hard since the Lucas was added; actually, seems to have gotten better gradually. Still does not like getting hot (hot weather/driving an hour or so, would start jerking into gears).
Bad news, yesterday a new "thing" happened. Twice, when I was starting up after a stop light, felt like I was running over railroad tracks (this is what happened right before my '87 Olds Delta 88 lost it - the tranny, that is).
Think the writing is on the wall, but just wanted to give an update.
Wish I had answers to some of the other problems people are posting :confuse:
Di
By the way, I have the flickering lights problem. It happens only when it's cold, 35 degrees or lower. And the steering shaft has been replaced on warrantee. That was good for about 60k miles, then the clunking happened again. The dealer said he squeezed some grease into the shaft. I have the impression a spray can may not get it done.
Anyway, still think we might be able to use the aerosol lithium grease...others have, and I will post after I try it. You have to use the little red tube that comes on the can and slide down the rubber tubing that covers the shaft. Think positioning yourself under the steering column to do it is the trick. We shall see
~Tracy
Thank You, Craig McBrain
Again, do a google search on "P0742".
I haven't been able to find much on Google either, but then I'm not sure if I was searching for PO742 or P0742 (O vs. zero).
I still haven't noticed any change in my gas mileage either.
~Tracy
At the bottom of the question, the host has a link to Diagnosing the Torque Converter lockup. The 1998 Grand Prix GTP shares many of the same drivetrain components as the 1998 Intrigues.
I would appreciate any help or suggestion on the car doing dead thing and the transmission issue!
Thanks in advance,
MTRAM
However, the wire-clipping has proven to only be a temporary fix until what seems to be (for the Intrigue anyway) the inevitable rebuilding of the transmission. Within the past couple months, I no longer can completely rely on my car to go in the instances that I will "gun it" to get onto the highways, etc. It will whine in too low of a gear, and I have to let off the gas, and hope I'm not in the middle of a busy intersection. It doesn't die, but it's not as reliable. Not good in the dead of winter in the Midwest either. Therefore, we'll be getting it rebuilt within the next couple months (tax refund come quickly!).
~Tracy
So my question is, is this car doomed even IF I get the tranny fixed? Because it's starting to have issues again and it's either needing to get fixed very soon or traded off (even though I'd love to avoid a new car payment if at all possible since I'm so close to paying it off).
Thank you in advance,
~Tracy
