-Bad cables.
No need to start a new thread, there is an Electrical/Lighting one. The host will probably move these there....
cadilac about two years ago I realize that there is alot of weird things that can go wrong with it and alot of electrical things, codes, sensors, 3 computer, ect. My problem is that my head lights go out on me sometimes. Very dangerous on the highway. Also the lights go out on my control panel too. Third but not least is that my car will turn over and even start but then will kill right away, and this happens every once in awhile too. The really weird part is that over the last year I have had it to 3 different garages, two which are GMC dealers and no one could figure it out. Any one out there that can help me? Right now I have my husbands million watt light that plugs into the cigarette lighter that he shines deer with. Thats just in case my lights go out on me I might stand a chance. Hell, I might even see a deer.
Any suggestions?
This is driving me crazy - Help!!!
ejdjr
The check engine light is the most of my worries , as this car cost quite alot of $$ & I have 0 warrantly. can anyone help with this problem ?
Your car had a 4 year/50,000 mile warranty. Being a 2004, it could have been sold first in mid-2003 and therefore was over 4 years old when you bought it. When buying autos, you should always find out the 'in service date', when the car was bought, which is when the warranty is started.
2) One more note, I have always heard a periodic rummmmmm sound from the rear of the car; someone made mention of `leveling system`, please explain this function.
You should be able to bring up the battery voltage on your DIC display by pushing the INFO buttons. Check that when the car is running you have at least 13.5 volts. More, up to about 15.0 volts is good. If you don't have this voltage running, you have other problems, such as alternator bad. But if a bad alternator, it should be showing an error message on your DIC display.
If the car will not start, the battery voltage is obviously low. But, if you are driving it every day and it is starting, here is something to do. Drive the car 20 miles or so - enough to get a good charge on the battery. More miles would be better. Turn everything off. Radio, AC/Heat, Lights, keep door closed, etc. Stop the car.Turn the ignition back to 'Run' position, but do not start the car. Bring up the battery voltage on the display. A nicely charged battery should show from 12.2 to 12.6 volts. If your battery, right after being charge up nicely, shows something less than 12.0 volts, your battery is probably 'bad'. If you can sit there a few minutes, and you see the battery voltage decrease, you also either have a bad battery (losing voltage quickly due to weak cells), or you have a huge power drain somewhere.
Most auto parts houses will also 'load test' a battery for free.
If the battery appears good, finding the drain is something an tech with experience in electrical systems is going to be needed. Does the car have Onstar? Cadillacs of about this age had problems with the Onstar module draining the battery. Whether Onstar was active or not. Otherwise, the drain could be in many places, your Caddy has lots of electronics in it.
2) Your car has a rear, self leveling air suspension system. There is a small air compressor near the rear tires. Every time the car starts, this system goes thru a 'self test'. The compressor starts and raises the car a little. The system then exhausts air back to the correct level. This is what you are hearing. I think the system will even do this with the ignition in Run, without starting the car, and you can very easily hear all this. It takes about a minute to go through all this. Of course, with your battery problems, I wouldn't be draining the battery by doing this (the compressor uses electrical power) until you get the battery/electrical problems resolved.
Some of the electrical system is probably not protected by the 'Battery Saver', so you could still have something that is draining the battery.
If one window, is it dead from the door switch and the driver's switch?
Sir: I have acquired a 1991 Sedan Deville with the same problem you had. Fuel guage inope plus heat/ac - no readouts on either. Any recommendations you have would be appreciated. Hope you fixed your problem.
But from your description of the problem, I would also suspect a pinched wire, possible inside the rubber boot that covers the wires where they go from the body to inside the door.
Luckily so far its only when I get in my car and turn it on.
Oh yeah and now it's leaking oil ..AHHHHH !!
I've only had the car 1 1/2 and it has 75000 FYI.
If under the rear seat, I would re-check the battery cable connections. I would also check the negative cable where it is screwed into a nut that is basically in the body just to the right of tthe battery. My 2005 needed this ground tightened down. It is covered with paint, which also makes for a poor connection.
If under the hood, I would check the connection, plus you might have corrision inside the rubber covering the cables, either positive or negative. Just moving these cables around to put the battery in could have broken strands inside the rubber that cannot be seen.
And, you could have bought a dead battery. What is the voltage at the battery connections, with the car turned off, and also while running. A battery in good shape should have 12.6volts. When charging, there should be anywhere from 13 to 15volts at the battery.
Good luck
Your vehicle is equipped with the PASS-Key® III
(Personalized Automotive Security System)
theft-deterrent system. PASS-Key® III is a passive
theft-deterrent system. This means you do not have to
do anything different to arm or disarm the system. It
works when you insert or remove your key from
the ignition.
When the PASS-Key® III system senses that someone
is using the wrong key, it shuts down the vehicle’s
starter and fuel systems. The starter will not work and
fuel will stop being delivered to the engine. Anyone
using a trial-and-error method to start the vehicle will be
discouraged because of the high number of electrical
key codes.
When trying to start the
vehicle, if the engine does
not start and the
SECURITY light comes on,
the key may have a
damaged transponder.
Turn the ignition off and
try again.
If the engine does not start, and the key appears to be
undamaged, try another ignition key. At this time,
you may also want to check the fuse. See Fuses and
Circuit Breakers on page 5-98. If the engine still
does not start with the other key, your vehicle needs
service. If your vehicle does start, the first key may be
faulty. See your dealer who can service the PASS-Key®
III to have a new key made.
It is possible for the PASS-Key® III decoder to learn the
transponder value of a new or replacement key. Up to
10 additional keys may be programmed for the vehicle.
This procedure is for learning additional keys only.
AND:
SERVICE THEFT SYSTEM – 34: This message means
there is a problem with the PASS-Key® III system. A
fault has been detected in the system which means that
the system is disabled and is not protecting the
vehicle. The vehicle usually restarts, however, you may
want to take your vehicle to your GM dealer before
turning off the engine.
End manual cut and paste.
Your 2000 probably has some version of this security system. I don't think it will still have the 'resistance pellet in the key' system. The manual says this PassKey3 system has a transponder in the key, and it may be damaged. I think you are going to have to get some professional help for this, unless you have a bad key/s. If a key got really wet, or was physically damaged, I think you might need a new one and have it re-programmed.
Here is what my manual says about programming keys:
Canadian Owners: If you lose or damage your keys,
only a GM dealer can service PASS-Key® III to
have new keys made. To program additional keys you
will require two current driver’s keys (black in color). You
must add a step to the following procedure. After
Step 2, repeat Steps 1 and 2 with the second current
driver’s key. Then continue with Step 3.
To program the new key do the following:
1. Verify that the new key has PK3 stamped on it.
2. Insert the current driver’s key in the ignition
and start the engine. If the engine will not start see
your dealer for service.
3. After the engine has started, turn the key to OFF,
and remove the key.
4. Insert the key to be programmed and turn it to ON
within 10 seconds of removing the previous key.
5. The SECURITY light will turn off once the key has
been programmed. It may not be apparent that the
SECURITY light went on due to how quickly the
key is programmed.
6. Repeat the Steps 1 through 4 if additional keys are
to be programmed.
If you are ever driving and the SECURITY light comes
on and stays on, you will be able to restart your
engine if you turn it off. Your PASS- Key® III system,
however, is not working properly and must be serviced
by your dealer. Your vehicle is not protected by the
PASS-Key® III system at this time.
If you lose or damage a PASS-Key® III key, contact
your dealer to have a new key made.
In an emergency, contact Cadillac Roadside Assistance.
See Roadside Service on page 7-5.
txz
BIG P
Is it something that I can do Or do you think I need to take it in?
Thanks, Francisco
Rap is designed to allow the radio, trunk lid, wipers,sunroof etc to be operated
after the ignition switch has been turned to OFF. RAP continues for ten
minutes or until a door has been opened. The main components of the RAP
system are the Body control Module (PZM) which has controlled power relays,
accessory time delay relay, and several fuses. Have these checked, they are
probably on the left front of the passenger compartment, taped to the body harness. If one of these are bad it will drain your battery overnight.
Today I disconnected the pos term on battery while the key was in the on position, removed key after a few minutes. Now I'm letting the car set before I hook up the terminal again. Praying that works.
The 15.9 volts is the charge being put out by the alternator when running. The Voltage Ok display just shows the alternator is working. Has little to do with the battery condition, except it is high which shows the battery is very weak and is taking a large charge.
And yes, with all the electronics in the car, when the battery voltage drops, you may get all kinds of error displays. Get a new battery in this car and hopefully all your problems will go away.
I just put a new battery in my wifes 2005 Deville. Surprising to me, my local Walmart had the correct battery, $77, including the little end vents where rubber hose attaches to vent fumes outside thru the bottom of the floor. The battery in the 2005 is under the rear seat. Local NAPA quoted $147, with the dealer cheaper for a Delco at $140.
1. Check Engine light comes on and out at will
2. The engine stops in the middle of the road mostly when idle (traffic lights) and the oil pressure light comes on. I had to bring the car back to neutral and stop it. These days in lights I stop the car a bit back and slowly advance so that the engine is up and running.
Any help is greatly appreciated.
With this number of miles, there is a lot of problems the car can have. The first thing to do is get the check engine codes. You could have bad plugs and/or plug wires. The Engine Idle Sensor may be bad, or the ports in its body are plugged up. The butterfly valve for the throttle can be gooped up badly and is sticking, althought this usually gives you a high idle.
