Honda Accord Coupe Starting and Stalling Problems
MY 1994 Hinda accord coupe has been stalling quite a bit lately at first i thought i was low on gas so i filled up and it stopped stalling for a couple days then it started again. it stalls when i am slowing down at a red light once on flat surface and three times going down hill. when it stalls the battery and oil light goes on. What could be causing this problem? How can i fix it? and what has to be fixed and how expensive might it be? also my gas gauge is messed up the needle just lays past E all the time. sometimes it goes up o where it should be. What could be the problem with that? and how can i fix it? thanks for your help
Any thoughts??
The title if this forum suggests any and all Accord Coupes. The only posts here are about 1992 and 1994 vehicles. That is very misleading.
These posts should be moved to the Honda Accord (1990-1993) Maintenance and Repair or Honda Accord (1994-1997) Maintenance and Repair forums and this one made Read Only.
We'll let this one stand.
You wrote "we can have a separate Coupes discussion for Starting and Stalling problems"
Please clarify why generic starting and stalling concerns would be related to the shape of the vehicle's body. Sedans with identical engines would be no different than coupes.
Also, why would owners of sixth, seventh or eighth generation Accords with more modern engines be interested in reading a forum about recent problems that two people experienced with engines built thirteen to fifteen years ago? Those folks would find much more support in the forums dedicated to their generations of vehicles. I believe that the title of this forum is misleading and useless to most members.
Everything was fine for about a week, then last Saturday the same problem, this time in a restaurant parking lot. Crank, catch, stall. I opened the hood, wiggled the cables a bit, and it started up.
Everything was again fine for about a week, until yesterday afternoon. I drove to work in the a.m., left after an hour to go to the dentist, and then came back to work an hour later. After work, the car didn't even turn over this time, just cranked. I fiddled with the cables again, disconnected them from the battery, wiped the terminals clean, re-attached the cables, and nothing. Just crank. Had to have the car towed to my mechanic. Spoke with him today, and he's been able to start it with no problem several times through the day.
Not sure where to look. Any ideas/suggestions?
Rap
p.s. I couldn't find a forum specific to Maintenance and Repair covering my model year!
Good luck,
Rap
Thanks for any help
Was wondering if there was a spacer missing between starter and flywheel housing???
