Honda Odyssey Heating/Cooling Problems
i have an 02 odyssey , there is no temperature control on ac
or heat mode,unless you turn the temp control to the max ,then it will turn on , any other setting i get no air.
i checked freon...and i have good pressure,also jumped out
the freon low pressure cut-out switch......that didn't help.
i want to check the inside and outside temp. sensors, but
i can't find them....does anyone know where these sensors are located ??....can anyone help????
perhaps your problem is related either to the relay assembly (see items marked 2) or it is the "thermistor" (see the item marked 19) in the following exploded view diagram:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - - - cgry1=Odyssey&catcgry2=2002&catcgry3=5DR+EXL+LEATHER+RES&catcgry4=KA5AT&catcgry5- - - - =A%2FC+++++COOLING+UNIT
one thing you may wish to try is determine if the relays in that diagram are currently well seated in their sockets. if they've vibrated loose, that may be an issue. same is true for checking the connection on the thermistor that is currently in there.
did you try googling or looking at a Helm's repair manual, maybe speaking with an independant specializing in Hondas?
good luck.
A couple days ago the climate controls froze up and won't respond. The manual controls still work on the navigation screen but the Auto assembly right above it doesn't work at all. Thanks
I found the part,#14
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- cgry1=Odyssey&catcgry2=2000&catcgry3=5DR+EX+NAVIGATION&catcgry4=KA4AT&catcgry5=H- EATER+CONTROL+%28NAVI%29
Anyone know how complex it is to replace? Can I do it myself?
Thanks for any information.
I have a brand new 07 odysset EX-L RES and NAVI.
I understand that the passenger and driver can have different temperature setting which is regulated automatically. Everyone in the back will have to manually set temperatures which is not automatic.
But in Page 215 of the manual it says
"On EX and EX-L models:
When the rear passenger’s zone is turned on using the REAR button on the front control panel, the rear passenger compartment temperature is selected based on the driver’s
temperature setting."
Does this mean that rear passenger temperature can also be automatically regulated, even though it is set to the temperature of the driver?
I thougth you could not regulate rear compartment temperature automatically.
PHK
Since this is a 2007, bought in May from the dealer - is this something that they will rectify regardless of how it was caused without charge?
Jahlimey
My 2000-EX was doing the same exact thing. Only high fan. Rough noise. No compressor operation. Warm air only.
I found this forum. Did some reading. And, decided to change the transistor. Did some calling and surfing for the part. The dealer quoted me $60ish over the phone, but dropped it to $45ish when I went to buy it. $45 is comparable to the $38+ from places like Majestic Honda once you’ve factored in the handling and shipping charges. Anyway - It was $52 and some change out the door. I mentioned my symptoms to the parts guy at the dealership. He said he’d heard of all this before.
I made the comment (jokingly) that I may be back for another part (I think the fan switch relay is mentioned in these posts as well.) if this transistor didn’t fix it. He laughed and said something to the effect of “I think you have the right part for this fix...” He was right.
The hardest part of the replacement is getting into position to do the work. The unit is located behind (towards the front of the van) the fan blower motor. I pulled the fan out to make getting to the transistor easier, and because I figured it could use a cleaning anyway. It did. Three screws hold the fan in. And three screws hold the transistor unit in. Nothing special about it other than the fan screws being socket or torx drive. The whole job took less than an hour.
I will note that the new transistor unit does not look exactly like the original in that it has more of what look like cooling fins on it. (Mine does, anyway.)
After the replacement of the transistor unit. My system works factory new.
I too, owe these guys quite the THANK YOU !!
I hate to think of the cost of taking the van to the dealer (or any repair shop), handing them the keys and saying fix the A/C system. Ouch !!
ps - Please let us know how your story turns out.
Please let me know if this is the same problem you experienced and whether the transistor that you refer to is different than the air max motor. We are extremely frustrated and appreciate any helpful responses on this one.
Thanks to everyone in advance.
My 2005 Ody is doing the exact same thing. How did you resolve your iclimate control ssue ?
Can someone please suggest how to troubleshoot/fix?
Any help would be much appreciated. We're checking our warranty, but if they don't cover the work, I'd like to save on the repair.
George
After replacing the resistor the blower fan now works at all speeds and the A/C is blowing cold once again.
And know what it might be?
Thanks in advance
That if the compressor is in good condition, meaning after there diagnosis which I paid $103, they are not sure if the compressor is also kaput. Anyone with similar experience with their Hondas? Thanks for your help.
If you take it to Firestone and get them to charge it, it might cost you $60.
Like I said - I had the exact same problem you did and my buddy said bring it over and lets put some freon in it to see if its leaking. That totally fixed everything and it's been working fine for nearly 1 year. It makes no sense at all - but it worked.
Best of luck to you - Let me know how you make out.
I
Any inputs on what happened will help!
Thanks...
Do you think there is a problem with the radiator to cool the oil or maybe problem with the whole cooling system..Does the oil that goes to the radiator from the engine, have a pump,if so is it damaged.
Fans are working fine (I think) and radiator doesn't leak
We stopped at a rest area and shut the van completely. When we restarted the van, the blower started working and the van started getting cooler. I did not know that Odyssey now joins the list of "try rebooting" to fix.
Our dealer service shop cannot figure out what is wrong. Any ideas?
I am experencing this same issue with the rear vents and took the car to a honda dealership who advised that warm air should come out of these vents. But I too can not get it to work. any ideas?
I'm reading with interest some of the fixes our readers have commented with regards to AC fixes. One notably message perked my interest is where the what-cha-ma-call-it under the passenger dashboard part is replaced for $60 and under 1 hour.
My problem is that my AC does not cool times (like yesterday), but today it worked like a charm (thus not a freon issue). It seems that it works only when it wants to.
Any of the readers experienced these types of symptoms? Pls let me know. Many thanks.
CG
