Volkswagen Cabrio Transmission
cabrio98
Member Posts: 8
in Volkswagen
this past april i purchased a used 98 cabrio from the original owner. she reported no maintenance problems at all. but after i bought i realized that the intermittent wiper only works when the car the temperature outside is warm. ??? (what's this about?)
ALSO, this past weekend i was driving home from a road trip. i drove about 60 miles at about 70 miles / hour. along the way i made a restroom stop and turned the car off. not too long after i turned the car back on, i noticed the car was stuck in 3rd gear and would not shift -- the car is an automatic. the engine started revving, but the car wouldn't go faster or shift into 4th gear. finally i pulled over, shut off the car. i check the oil, b/c i knew i was overdue for an oil change but everything seemed fine under the hood. when i started driving again, the car drove fine without a problem. this really freaked me out b/c other than this one incident the car drives amazingly!! i'm bringing it to the dealer tomorrow to have it diagnosed, but i'm terrified of being swindled, b/c i was already "taken for a ride" at another vw dealer. the car has 54,000k miles.
any suggestions or thoughts?
thanks, marilyn
thanks, marilyn
thanks,
Replaced seal and torque converter bushing. Still threw fluid. Pulled anew,
and replaced seal again, along with torque converter. The fluid still flies!
Is there some 'input shaft seal' that is leaking out onto my converter and flying out the openings of the bell housing?
Seawarrior
Take care
Hope this helps anyone. Glad I did not forget about my 10yr/100k wrnty
-jasmyn
Upon further investigation, I found that while you can get into the tranny and replace the filter, refilling it was the problem. VW uses some type of machine that pre-heats the fluid prior to filling. Alledgely, having the fluid at the right temp ensures that it flows properly through all the little nooks and crannies in the tranny and that is the only way to ensure proper fill level.
One webpage suggested draining the tranny, measuring the amount of fluid drained at "room" temp, and putting that much back in. While I guess that could work, I instead took it to a local independant garage that specializes in VW. The cost was probably about 60% of what a VW dealership would charge. Unfortunately, my daughter has our service records for the car so I can't give you an exact $$ amount.
This is my family's first VW and one thing I can tell you for sure... it's not user friendly if you like to do your own maintenance! :mad:
Paul
My 2000 cabrio will not shift while in "D". It seems to be in 3rd all the time. I can manullay shift from 1 up, but it goes into 3rd and not through 2 nd. Book say it is in Fail-Safe mode. Does any one know why that happens?
I noted that the clamp on the shifter rod in the engine compartment was almost at the end of the rod. I got out my Haynes manual for this vehicle only to discover that the manual trans shown are nothing like the one in the 1999. I removed the shifter boot and found that the rod seems to have rotated counterclockwise (sitting in the dsrivers seat) and is now only going in to third and fourth but only when the shifter is pushed down as in going into reverse and moving past the plastic guide. This gives me third, fourth and fifth.
Anyone have any ideas as to how to correct this?
Here is what I have noticed and know. I noticed that once the car warms up it drives/runs fine. So with that being said + a check engine light illuminated I bought a code scanner and found that it was the Throttle Position Sensor that was malfunctioning. I have one on order and I will let you know if it fixes my Cabrio.
Ray
Anyone else have these issues or have any suggestions other than replace the transmission?
Ray
I bought Japanese for reliability. So it goes. Cabrio. great car, big problems.
