i do have 4 brand new jeep wrangler tires on it,,
any suggestions or ideas
thanks..
cmig
Among other things, look for "check engine light".
S
The easiest problem could be a leaking vacuum hose. The solenoid can be repaired or replaced (or bypassed into permanent 4wd mode) if necessary.
Question - does your "4WD" light illuminate when you shift into 4wd?
IIRC, there was some discussion about this issue on the main Wrangler board.
Good Luck
The 87 YJ has a vacuum actuated setup in front to get 4wd going, and that is about all I know about it. It SOUNDS like it is working, but it sounds like you need to do a service on your transfer case. I think your son fried it.
-Paul
Have it attended to immediately!
Consider that sentence to be repeated several times.
Steering failure could lead to a substantial reduction in your quality of life.
Consider a V8 swap. I know of at least 4 people who have put in V8's and are getting in the mid 20's for mileage vs the teens for the 4cyl and 6cyl. Each of the engine swaps was a small block chevy V8 (in one case an LS1 engine) and only 1 was a hemi.
I've seen a Canadian firm doing diesel swaps and even Extreme 4x4's TV show did a diesel swap (in a Samurai) and run veggie oil waste. There are options.
-Paul
I am searching for an owners manual first off.
Was the 3 speed manual transmission original?
Was the strait 6 cylinder the original as well?
I am looking to restore the jeep to as close to factory specs as possible. I am also looking for gauges several are out or non-working as well as some some I can't tell what they ever did.
any help?
Mark
-Paul
Depending on what you want to do, here are some vendors to consider:
www.dpgoffroad.com (Kansas)
www.northridge4x4.com (Washington State)
www.4x4groupbuy.com (Maine/Arizona)
www.4x4rockshop.com (Alabama)
www.redrock4x4.com (Colorado)
www.offroadtoystore.com (Colorado)
If you want to go specifically to a manufacturer, many sell direct as well.
I've used all the above and had ZERO complaints with any of them.
-Paul
~Diane~
There are two complete harnesses on eBay at the moment by the same seller for $150 each.
Auction One
Auction Two
Another solution would be a car breakers.
