I'll check into the PCM issue, and if we get it figured out I'll post again so that others with a similar problem can maybe get some help as well!
THANKS!!
My Tachometer is stuck at 3000 rpm with the key in the ignition but the vehicle NOT started. Is there another source for this problem?
That is why I believe it is the pick up sensor.
I appreciate any help, as I am on a very tight budget, Love my car but with two kids under three I can't be stranded let alone afford a tow bill. THANKS!!
It could very well be the cluster, which is prohibitive to replace just for the tach function in an automatic. Don't even know why they put a tach in an automatic. My Harley, which should have tach, doesn't.
Thanks again.
I find it hard to believe I need a tach to tell me the engine is running, if that is the sole reason they put a tach in an automatic; well, there are other means (less expensive) to indicate the car is running.
However, what I did notice is that I disconnected the battery for 30 seconds or so, and then reconnected. I inserted the key in the ignition and turned it on but did not start it. The tach, cycled up to 3k, then back down to 0, then sat there for about 15 seconds, Then went back to 3k. Suspicious???
In order for the tach to sit at 3K, it has to have some bias signal at the tach
I can see some sort of electronic circuit feeding the tach input but am not sure what it could be. For the tach to jump to 3K and then bleed off, and then jump back to 3k (not exactly jump, but ramp up to 3K) is strange. All elicited by removing the battery. Or, is this standard, simply by resetting the car's electronics?
What I need is an electrical wiring diagram for my tribute. Is there a pdf file or ...... something on line I can look at.
It has been my experience that there is a problem with the transmission in both the tribute and the escape (sister vehicles). Google "escape transmissions" and you will discover what I am speaking off. There are a number of reported issues.
This was the first time I did all the serice work by the book (typically I do the work myself, but on this vehicle I had the dealership perform the work). Alot of good that did. My tribute transmission died at 60K miles and the dealer does not want to claim responsibility. I took the vehicle to TSI transmissions and had it fixed, I was not going to put another dollar into the mazda dealer pocket. $2500.
I would request the ford dealership kick in a warranty on the transmission for the life of the vehicle before I would consider buying it.
hwmspec
Thanks for the info on the transmission. I read that the Tribute had transmission problems but did not see carryover to the Escape or Mariner. I know they are essentially the same vehicle but I thought maybe the Tribute was a bit different to add its zoom-zoom. I guess I was wrong.
Started at about 25K. I don't ride the clutch at all when I drive, and my last car had over 120K with original clutch.
If you notice the problem, let's hope it is still under warranty.
2 questions - 1. How quiete or noisey should my car be? I think our old 98 Taurus is a quieter ride for goodness sake. Noise is all on acceleration.
2. What is a normal engine temp reading for this vehicle? Mine is sitting right in the middle.
It has been running fine until this morning. It rained last night and it sputtered and had no power, and I had to put it in park and hold gas and brakes at the lights, floor it to get to 45 MPH with the emergency lights on.
I made it to work, the sun came out, it dried out, and ran fine.
I have the highest-milege Escape 4x4 that my Lincoln (Florida) and Ford (Michigan) dealers have seen. Been with Ford since 1992, and quite satisfied with their service.
I have gotten a email notice you are having troubles with stalling and hard to start
there are a few conditions that can lead to that however your Ford escape is new can rule out that theres no engine wear,
have you checked the Idle air control valve?
also check fuel pressure regulator,
theres another condition which the car stalls if the ambient temperature is extreamly hot but thats not your case. its cold, this would be a bad idle control valve,
I have seen a lot of this going on even my own car does the samething,
the problem I believe is that the Ethanol in the gas is causing your problems
switch to a non-ethanol gasoline should salve your problem!
to get regular gas is some what hard, but however if you have a boat marina near by you should be able to buy the gas there (call to make sure it has no ethanol it it) but you cant put it in your car needs be in gas cans. for boat use only, but it regular gas that was for car in the days of old.
Email asus2908 at yahoo.com and let me know how its going?
are you using E10 gas which is ethanol, this can cause stalling in cars if its at a high level
try using non-ethanol fuels only place to find it is at a boat marinia.
let me know if this fixes the problem.
2002 Ford Escape XLT Sport 4x4 V6 (152K miles):
Inspecting the engine/transaxle/suspension area, I noted dampness underneath the power take-off housing (transfer case). Took it in to my local Ford (Lincoln-Mercury) servicing dealer, and determined that the unit had failed internally, and was venting lubricant. Ordered new unit ($1,350), and will have it replaced November 11. This is in addition to the $1,960 invested in engine mount, suspension, steering, and oil pan gasket replacement October 14. The vehicle has performed very well since new, but recent events (150K miles) have dramatically increased maintenance costs. Will continue to operate this vehicle into the distant future to recoup these costs. Fortunately, we replaced the shocks, struts, brakes, and tires in September.
I am having multiple misfires with my 2004 ford escape. Cylinders 1,2,4, and 6 are misfiring. It has always had problems when there has been a recant rain with high humidity. It seems like there is moisture getting in the fuel system. Now it does it all the time. I replaced the plugs about 8 months ago. The engine misfires only when holding a constant speed. It doesn't seem to misfire when accelerating or decelerating but can be felt when at idle. Any help would be appreciated.
Hi everyone,
My husband and I are military and will be based in Minot, ND. We have been doing alot of research and test driving small-midsize SUVs. So far, our first choice is an Escape XLT with 4WD. However, I want to know if anyone has had problems with the reliability of their Escapes? I had a terrible experience with my previous Ford, a 2003 Ford Focus ZTS. I just had to have a rebuilt transmission put in it 6 months ago with 91,000 miles on the car. I've also had problems with my alternator/battery, due to inexperienced Ford mechanics. However, I am willing to put this negativity aside if I can get some positive feedback about the Escape. This will be our first SUV and we think this vehicle suits our needs the best (i.e. driving in snow, towing, hauling/moving things, etc.). Also, I just read in a previous post about the engines in Escapes stalling? That is a major concern to me and if I am getting myself into a trap, please let me know now versus after I purchase an Escape. Many Thanks!!!!
"Hi,
I'm certain that you receive all manner of reports, sent by customers. Consider this one more of a heads-up...something that will hopefully not reach the complaint stage. This morning, Wednesday, the 6th of January, 2010, I came into your establishment for a service check--this the product of a problem that has suddenly reared its head in my vehicle. This was my first time at your dealership. I chose you because I'd read good things about your group, and frankly have checked you out on the BBB site. Here's an account of how its gone so far:
Arrived a bit ahead of my 8:30 appointment, which I confirmed online. Followed the signs where they led me, which turned out to be wrong--was told to speak with person at front desk. Returned to front desk, and person there, who seemed unduly nervous, began the process of checking me in, entering whatever into her database--the usual. The only thing that wasn't "the usual," was the curt demeanor with which she asked her questions and answered mine. And when I was asked for the very same information I'd already entered into the online form, like VIN#, etcetera, and also issued the natural--and politely put--question "Haven't you received the online form I filled out yesterday?", she got unnecessarily short with me--as if annoyed. I went out to get the Registration, returned, and the atmosphere disintegrated from there, but not to the argumentative stage because I avoided it. (Pat myself on the back!) We got it all sorted out, but I think the pall of friction that hit me when I first entered that room is something that you should be apprised of.
The girl at the front desk may have been stressed because of the man sitting just behind her at the second desk. The fellow was on edge. The few questions the girl asked him were answered abruptly with unnecessary edginess--almost as if he were trying to get into it with someone. He even acted this way with another customer whom he spoke with. In my case, I simply asked about the process that was clearly explained on the Ford website and then on the form I filled out online--about what would happen, and how I would be speaking with a rep/mechanic or whomever. Frankly, I have done so much research on the problem I'm experiencing with my vehicle that, thanks to the contributors in various chatrooms, I might have lent someone insight--it's a problem that many are talking about on the net on various Websites.
I had also spoken to someone there at your dealership and pre-ordered a rental vehicle, on January 5th, in anticipation of at least a day's time being needed by the mechanics--in retrospect, thinking about it, I believe that the gruff person at the second desk may very well have been the person I spoke with. But after my asking for my vehicle, he not only claimed to "not know" anything about the reservation but also not even know if there were any vehicles available. We eventually sorted it all out. But the gruff person's parting phrase "someone will drive your vehicle and call today" was somehow not very reassuring; not how the, quote, friendly verbiage on the website explained it would all go.
These are stressful times for many, but there is absolutely no need for rudeness, ill-manners and blanket-anger. Professionals don't do this sort of thing. If they do, their business doesn't make it over the long haul. And your claim, "After 26 years of serving the Connecticut shoreline, we know what works and what doesn't for both vehicles and customers," can't possibly be what was going through the minds of the people I dealt with this morning.
One other thing, the rental car I eventually took possession of was filthy--trash under both front seats, also four bottles hidden beneath a paper mat on the passenger side, dirty inside and dirtier out. I walked backed into the office and calmly let the girl know. She earlier made such a big thing of not smoking in the vehicles--I don't smoke, but the person who used the vehicle I've been given did...cigars!--that I thought she'd appreciate knowing just what kind of mess I found (and I will bring back to your dealership, you can bet on that). To accentuate the point, I carried in just one of the cups--the one left in the console cup holder--and handed to her, after first asking where I could dispose of it.
Thinking you've got some internal morale building to do,
XXXXXXXX-still waiting for a call from your mechanic-XXXXXXXXXX
Well, (this is not part of the letter, but my continuing missive to the chatters) I know this is not your usual Ford chat talk thingy, but, like I asked in the title: Ford had a banner year? How? And is this a B horror-movie? The outcome of this was: I got a call from the Manager. She reamed me non-stop for, like, 10 minutes on the phone. I asked if she'd really read the letter. She reamed me some more. I sat there amazed...so did my husband, who listened to the whole exchange. Manager said "Come get your vehicle, we think your personality will conflict with ours." I wedged a "Is Ford entering the Shrink phase of their business?" There was a lengthy pause on the Manager's end. (Which I doubt ever really happens.) I asked if she'd hung up? She began with the bullying diatribe. I broke the connection, went to pick up "Sir." (Yeah, it's anthropomorphization to the max! But he's clear coat black and beautiful! So "Sir" hit me right outa the shute.) And my dirty rent-a-car tab they picked up...as I'd suggested they should. I'm still on the hunt for a fix to the Escape's problem. I'll be back with whatever happens, hoping it helps some of you out there...and with less text this time:-)
Get ratings & reviews on car dealers & repair shops in your neighborhood
Dealer Ratings and Reviews
btw, we frown on posting individual's names but posting the dealer name is ok.
P.S. Sorry if I've hurt your feelings, but there's so much of this sciolist pap on the web, in the guise of true knowledge I mean, that it's an insult to thinking and caring people...of which you are obviously one...I mean.
P.S.S. There will not be any direct e-mails, as requested by the mediator/moderator of this chat room...and a darned good request that is...!
I recently started having the same problem but it is more intermittent. It started happening in cold weather but I don’t know if that is a factor. Three times in the last 3 weeks the car will not start. It will not crank. The only sound is a relay contacting behind the dash board. In one case it started ten minutes later and was fine for about a week. When it happened a second time it would not start all day until the tow truck driver tried to start if several times. I brought it to the dealer, where I purchased the car, and left it for over a week where it was parked outside. It started every time they tried it. I took it back and used it for a week, it was fine in sub-20 degree temperatures and now it won’t start this morning. In addition I have been hearing a clicking noise behind the dash board when cursing in high gear. Have you had any luck resolving your problem? If so what did they find?
pjr4
