Rain-X asserts that this product will de-ice your windshield at temperatures down to -25F. It will remove 'frost, light snow & ice'. It will repel rain, sleet, snow and ice. Of course it will also perform the rudimentary function of cleaning your windshield.
Directions
Open hood, locate windshield washer reservoir and fill with Rain-X De-Icer Windshield Washer Fluid. Close hood. Clean windshield as needed.
I'm contemplating giving my 2000 Land Cruiser to my son and getting a new one for myself but I'd hate to miss out on a new model.
To me here are some following things to consider:
1. higher tire costs
2. higher tire replacement costs
3. higher wheel replacement costs
4. bigger sized tires seem more susceptible to abnormal tire wear
5. more rapid brake pad use
6. more rapid rotor use
7. less ride comfort
8. less fuel mpg
9. higher unsprung weight
10. faster deterioration of suspension components springs, shocks, more stress on wheel bearings,etc.
11. gearing might seem less appropriate
12. greater chance of body and/or fender damage in the mostly unlikely situations you get max articulation for the stock suspension set up.
13. higher CG
I called the dealer and they had it towed back to the shop. The service guy was very nonchalant about the whole situation and just said they would refill with coolant and attach the hose. He had no concerns about any other damage caused by the lack of coolant.
I drove about 10 miles and for 20 minutes from the time I left the dealer until I noticed the high temp. I don't really know how long the temp was pegged for. I would appreciate any advice on whether I should be concerned and what I might ask the dealer to check to make sure no damage was done.
Thanks in advance.
Flyfish - If you’re “weary of plunking down $55k” for a Land Cruiser do yourself a favor and checkout the engineering & production quality of a $55k Chevy Tahoe like I did. I’m in the market for a second (S)UV and a Tahoe sitting on the Chevy dealers floor was a real eye opener. Besides some ill fitting trim pieces and a busted armrest sitting on the floor one surmises that GM employs only Jr engineers at minimum wage. Even with a $12,000 discount I figured I’d still be ahead with a LC after 7 years of maintenance & depreciation.
I guess when Toyota feels ready to tell us about a new LC they will, but until then, their plans are more confidential than any top-secret plan the Pentagon has.
I ordered my '04 LC and had to take certain options that I did not want as I'm sure you know how Toy works.
I removed the running boards shortly after.
I drive my LC off road as I have all the 4-wheel drive units I've owned during the last 35 or so years.
I'm just asking what would be the largest size tire I can run without clearance problems.
I am aware of consequences of running non OEM size tires.
Thanks Again
I hear you there! I stopped with an FJZ80 1997. Before that I had the 87,91,94,96,97. I still own the 94/96, so I am afraid my knowledge would probably not apply to the 100 series.
As to additional wear/damage to other components. If you lift the 100 series (I have mine lifted) the CV joints probably get a little more wear, though you can lower the front diff to offset this (haven't gotten around to this yet). Seems suspension lift options are a bit limited. Only company that's doing anything, and that's well known is Old Man Emu. There lift options consist of rear springs and shocks, plus stiffer torsion bars. Don't know of any other company doing suspension components for the 100 series.
On my other LCs (80 series) and this one, I've found that with a lift and larger tires, mileage drops about .5 to 1mpg, though on this LC, I got 20+ mpg a couple of times on a cross country drive 2 years ago. I don't think you need to be too concerned about doing harm if you go to 285s--however, 325s, I don't know. Of course you can do anything given enough time and money I've seen 325s and they seem to me to be a nightmare to keep in balance.
Pad wear of course depends on your driving style--I learned a long time ago to coast! I have 40K on my stock pads and they look good for 20K miles (at least) more.
As to the new LC. I got hints from the area tech rep (a fellow Cruiserhead) that the 100 will be here in '07 as well. A 130 has been rumored--but when? Additonal inputs from a long time service manager and a local dealer owner reinforce their continual full court press to NOT take away the LC here. The owner said that every owner's meeting where the LC is discussed, dealers are adamant about the need to keep the LC in the model mix. I, like many here, have a real fear that Toy will put a LC badge on a Sequoia ala Nissan and the Titan frame.
Since there is no factual news (that I'm aware of) on a replacement, I'd guess '08 or later will see a new design and options. Maybe a hybrid offering?
Even with higher fuel costs, and the lower #s of LCs imported to the states, demand and prices seem to have stayed pretty srtong. I'm near 3 dealers and LCs (both new and used) seem to be gone as soon as they hit the lot.
Gotta say as much as I liked my 80 series, the 100 is one sweet rig!
But why bother - it sounds like you already did your research. More fun to go enjoy a drive congrats on the new Cruiser!
Symptoms under medium load acceleration 30-50 mph whirring or buzzing sound from the HnL lever..I can actually feel it...then 65 to 75 mph under medium load (never WOT) same thing. Cruising is fine. 1998-2000 there was a TSB. I was wondering if this applies to 2002's.
Anyhow thanks for reading. I'll keep googling or probably go to the stealership.
Most of that era seem to go between $3,000 and $5,000 on eBay. TMV only goes back to 1980.
My wild guess is that a full restoration would cost double or triple what the final value would bring after fixing it up, but you'd have a cherry classic to enjoy for another ten years.
HELP...my mechanic is stumped and I don't want to keep having to repair this!
hope any one have a photos for the new land to share us
http://motortrend.com/autoshows/coverage/112_det03gal_toyfj/
The FJ Cruiser does not replace the Landcruiser. Toyota will be selling them both. The FJ Cruiser will cost around $25-$30k. The Landcruiser costs around $55k or so.
There will be a next generation Landcruiser. The FJ Cruiser is not the next generation Landcruiser. Yes, it is more similar in size and styling to the early generation Landcruiser. The FJ Cruiser is built off a shortened 4Runner/GX470/Pajero chassis.
I'm not an auto analyst and don't appreciate being called a half-wit.
May I suggest that your focus merely on price is incorrect - just look at the Hummer to see that. The FJ is merely returning the Landcruiser to its rightful heritage. If its cheaper than the current LC then so what.
J
J
FWIW, I went to the LA auto show today and spoke with several Toy people there about the next generation LC. No real news to report except I was told that the company president (the US, Japan?? just where I don't know) drives one and thinks it's perfect the way it is. One lady asked me if I had any other inputs as she wanted to put them in her show report. I asked her to mention F/R lockers, and see about making the Nav Screen movable ala a rear view mirror. Then I went to the Lexus display and checked out the 470. So, if I were guessing I'd say nothing next year and maybe nothing for the '08 MY either, but I wouldn't be surprised to see the night vision option move to the LC line.
All things considered, I'd take these inputs as good news? Keep things as they are, but continue refining the vehicle. No surprise here, but one comment that came up was the concern about fuel economy. IOW, Toy may be taking a wait and see approach with the LC (100 series) until they can really add to fuel efficiency? I also checked out the RRs. At first, sitting in one felt a bit more refined than the LC, but after checking out the LC again and the 470 (plus factoring in RRs "issues") I would stay with the LC all the way.
Yes, the style might be a bit dated to some, but it still seems to be the best value out there in the luxury SUV market IMHO. So if you're in the market for a new LC, but you're holding off for the next model, that would seem to be a least 2 years away.
The problem is the folks I was talking with at the show, while wanting to be helpful, are probably not any more knowledgeable than we on this list are. Too bad there weren't some engineering/design types there :confuse:
Again, lots of conjecture and spin on my part. But I think your MY '09 is pretty "spot on". I'm sure Toy has some fairly firm design specs now and they're just biding their time with contiual refinements to the 100 before introducing the new one?
:confuse:
Therefore, the FJ Cruiser does not replace the full-size Land Cruiser. They will be sold side-by-side.
