The trade off is they never run that good! They start hard sometimes, they run lousy sometimes, they diesel when you turn them off sometimes, and they stall out sometimes....none of which happens to a modern engine. That's just the way cars were back then, we were used to it, knew no better. But now, when I drive one of them, it brings back the horror of how badly cars could run when it was cloudy, or hot, or cold, or wet, or just about everything back then. They're fun to play with, but to drive everyday? I'll take my Lexus hands down!
Just sayin...... I fully appreciate your point!
When I enter the car, everything comes on okay and my stereo plays and the check is okay.
Then I put my foot on the brake and the green light comes on on the Start button. When I press the Start button, the car makes a metallic stuttering sound but the car does not start.
I tried jump starting it with jumper cables connected to another car but I just got the same stuttering sound so it's not a dead battery. I let it be overnight but (sadly) got the same sound next morning.
Any ideas? Thanks in advance, any advice would be greatly appreciated before I take this in.
Starting problems. May 2013 - couldn't start. Towed to dealer. Starter replaced. August 2013, couldn't start. Towed to dealer. Some relay replaced. September 2013. Couldn't start. Towed to dealer. No problem codes. Car is still at the dealer. Two follow up calls. Still couldn't find the reason.
Not sure what to do. It is getting pricey to have it towed almost every month with similar problem.
Spoken to Service Manager and mentioned that I am not confident how this problem is being fixed. Looks like its a miracle. Not sure what to do. Any advice?
P.S. Sorry forgot to add that after couple towings dealer was able to start it. And ones it died on mechanic on the test drive.
I am on my second set of the same problem with my 2000 ES300 (under 90K miles). The first time it wouldn't start, I replaced the battery and it was fixed for about a year and a half, the second time I had the terminals for the battery replaced as the negative one was corroded ($67). Three days later after not driving for two days "CLICK". ARgh! Brought it back and and they said "We know what your problem is, the Starter" I guess it was 'firing intermittently'. Quoted $579 to repair. Getting done this afternoon. I will come back and update you all. Hopefully this is the last problem! Merry Christmas, and Thank You, Santa for the new Starter.
Our '08 has recently started cranking longer--5-8 seconds vs. 1-4 seconds--and I think it's likely the fault of the battery. Still has the original battery. Will change the battery if it gets much worse.
