I am calling them back and sharing your post. Thank you.
Also, I am filing with Honda.. :lemon:
I was able to duplicate the problem, they saw it, but it was not frequent enough to diagnose. I even recorded a video to show them I wasn't crazy.
After being on a first name basis with the service manager, I recommended (and they finally agreed) to "pick a part"
Afterall, there are only 2 main components, and a couple small parts that could be the problem.
So, they picked one part to replace - and if the problem continued they could swap my old part back in, and pick another.
My door was finally fixed, then I really fixed the problem by selling a Honda and buying a Toyota!
Did you solve your problem? We've had the same one: doors refuse tu close properly when it's very cold (last week it was -20). Ours is an 2008, bought used at the dealer in 2011. Last winter we didn't have any problem.
It's been frustrating to say the least; I've taken it in several times - twice when the door was acting up (as in not closing properly, and the door alarm is going off)...All they (Honda service techs/service writers) do is let it sit in a warm work bay, and voila - no more problems :mad:
Afterwards they lube the sliding door components - however it's usually no more than several days, and it'll happen again...I've opened 2 cases with Honda America, and they haven't done much either - usually telling me to go back to the dealer when the door acts up again...Then once again all they do is let it warm up - blah blah blah :mad:
What I've found is to let the van idle/warm up for several minutes, and cranking up the heat; this has worked a few times in which the door will then close properly (did it just this morning actually).
also, i v to say, somehow what looks like the roler on bracket that guide the door is bumbpy at closing. door shakes little bit and jerks, then comes to close
i cleaned all contacts and no use
anyone knws?
dan
Best of luck to you and be safe!!
We have a 2008 Honda Odyssey EX-L with about 45K miles on it. A few days back, we noticed that the tailgate trunk door was not going up automatically. From some search, we found that the item called "tailgate struts" makes all of it happen and it has been found faulty by Honda (
http://www.csmonitor.com/Business/2012/0222/Honda-recall-involves-Odyssey-miniva- ns.-Is-yours-on-the-list ) and there is a recall for it. But we were not notified about the recall, and a recall also does not show up on the Honda recall website against the VIN. Dealer says that it costs $86 for each side and will cost me about $225+ in total including labor !!
I am wondering:
a) Why do I see recalls against the struts but my specific van VIN is not included in the recall list?
b) Has anyone else done a replacement from another store/internet? This seems to have happened to others too, so please share part information. I believe a couple of substitutes are: Stabilus SG126007 ~$95+ or Strongarm 6238 ~$51. Any feedback on these specific parts and/or your own experiences?
I called up Honda (recall option) and asked them why my van was not selected for the recall. They asked me to go to a Honda dealer and show the problem and ask them to contact Honda. And that is what I did and then after a couple of days, Honda approved the work at no cost (!!) and the Honda dealer installed the new struts. I am sure having 2 Honda vehicles currently and a history of Honda purchases must have helped.
Honda Odyssey it's a very complex vehicle but at the same time can be improved! They have been working on this car for over 13 years and I owned two Honda Odyssey different years and I was able to notice the differences. What happened to you it's not new, and you should be reimbursed for any damages to your personal property and the car!
It's not your fault! This "window opening situation" it's been noticed on 2010,2011,2012... It's a problem with the car... The dealer has no clue how to fix it that's why they give you all the BS excuses to get rid of you!!!
I'm sorry to hear this and I hope that somehow this won't happen to you again!
Be safe and God Bless you and your passengers!
Cristian
The sliding doors can be easily reset by disconnecting the car battery for a few minutes and you are back in business. BUT make sure that the sliding rail it’s clean (don’t lubricate)! The door it’s designed to push with approximately 35lbs. when the door its obstructed will open back but if this will persist the door will shot off. And has to be reset, disconnecting the battery.
I hope this will help, be safe and God bless you and your passengers!
In Germany they use this technique on their cars! Here in AZ I saw many WV with spots of Vaseline coming out due to high temperatures!
You mentioned electric as the problem with your sliding doors, can you be specific on what you had to fix or replace? My sliding doors on my 2006 Odyssey will not unlock or open electrically or manually. My kids have to climb in and out of the back hatch. I have taken it to the dealership and they can't get the doors opened at all. They told me they would have to basically tear out the inside door panels and they could break to get to inside of the door to see what was wrong with it.
I bought this Odyssey new in Sept 2006 and have had nothing but problems with it!! I have replaced so many things. This is the list of items I have done thus far:
Power Steering Pump
Torque Converter
Sliding doors rollers
DVD player
Inner tie rods
Outer tie rods
Wheel Bearing
Main fuse box
Starter
A/C leaking currently and not working. Need to get fixed
Sliding doors will not unlock or open at all.
Needless to say I will not buy another Honda!!
Any info and suggestions you can offer will be much appreciated.
Any ideas based on these symptoms? Current status is the radio's anti-theft light is blinking on all the time and radio is inoperative. Next step would be to check the fuses for the radio and radio's anti-theft system? Or ...?
Thanks in advance for any advice.
lets know if you find out anything, and next time be smarter and dont buy honda odysses lol
The situation with our Honda doors has been as follows: The passenger side has not opened or closed at all for over a year now. At some point a cable that is a part of the mechanism broke and hung down from the track on which the door slides. The driver’s side would work automatically, but only from the outside or by using the switch on the dash board. However, if the car was not driven for several days the battery would drain and would need to be charged in order to start the car. A local mechanic could not pinpoint where the electrical ‘drainage’ was happening, but found that by removing the fuse controlling the door, the battery would not fail. The downside of that of course was that we would have to open the door manually which was very difficult and inconvenient so, depending on what we needed to be doing, we would put the fuse back in and try to remember to not let the car sit for more than 2 days without starting.
A few months ago the cable appeared from the driver’s side door. We were suddenly able to more easily manually operate to door, but now the only way to open the door was from the outside since the inside handle stopped working; a rather dangerous situation in the event of an accident. The newest development is that we are unable to open either sliding door, from the inside or the outside!
Our frustration is that we reported issues with the doors within the first months of purchasing the vehicle new....back in 2006. Honda service denied any widespread issue with their sliding doors. Since the problems manifested randomly, they would not acknowledge that we were actually experiencing problems until they would actually 'break'...numerous times. They have been repaired both under warranty and out of pocket. The problem has just gotten progressively worse.
Most disturbing is the fact that Honda will not stand behind their workmanship and resolve this issue. We have been in touch with customer service and have written directly to Mr. Thomas E. Shoupe (president of Honda Alabama, where Odysseys are manufactured) and Mr. Richard Schostek (senior vice president, Honda of America Manufacturing). Neither of these gentlemen bothered to even respond.
It is interesting to read through the list of other issues you have had. I want to go through our service receipts and compare them to your list, but off the top of my head I know that we have had issues with:
Power Steering pump
Sliding door rollers, of course
Tie rods
Wheel bearing
Air conditioning lines
Electrical system
battery
For years I had been convinced that Honda was the ‘gold standard’. That was before we actually bought our first this Odyssey.
I would suggest that you at least make sure you file a complaint with customer service. They will probably do nothing, but you will receive a case number which will remain on file for three years from what we understand.
I just purchased a 2005 and I can't seem to open the sliding doors with the key fob. I assume that I need to flip a switch somewhere but I can't seem to find it. Anyone know?
Same thing happened to me today for about the third or fourth time. I have a 2013 Honda Accord. I love the car except for this one flaw in design. I stopped at the service center where I bought the car and the serviceman stated that it is not a flaw, but that I just need to be more careful in the future. At that point, I knew I was getting nowhere and I needed to solve the problem myself. So I thought hard and came up with a solution. I figured if I put the remote key in a plastic box, it would prevent an accidental opening. I used an old hearing aid box for my key and an old earring box for my wife's key. The remotes fit comfortably in the boxes.
My 2005 Odyssey just ripped the door off of itself. Over extending upon opening and routed entire side of my car and both brackets ripped off of the body. Left hanging only by the electrical cables. This car has been nothing but a lemon. Two gas tank leaks, one engine fire while I was driving it, two complete shut downs while driving in fast lane, just like GMC cars have, I was just fortunate I was on city highways and not the freeway or I am sure I would have been hit. I had no control of the car at all. I have replaced two transmissions and just about every other part, including a leaking power steering pump, master cylinder, and all of the other recalled items. Three days after getting it back from the dealer for the leaking power steering pump, it caught fire in the engine while I was driving it 75 miles from home. The dealer later claimed they left a rag on the engine that had caught fire. I have spent enough to buy 3 Odyssey vans in repairs. So furious to find recalls for items I paid for at the dealer. And when I ask about the recalls they say "I haven't heard about that". The first of my gas tank leaks cost me a fortune, and you could smell the gas strongly. I was told by the dealer that it was highly unusual for that part to go out, I was just lucky, and because it is one piece from the gas input to the tank it cost me an arm and a leg. Now I find out it was recalled along with all of the other parts I have paid to replace on this POS. This latest door incident not only cost $2500, but when the bracket threw a bolt it just missed my 3 month old Granddaughter's head! This is the car from HELL. Twice it has shut down without warning, and it just stops where you are. You have no power, as if there is no battery even in the car. The last time it happened a block from the dealer and I made the service manager come and get my car. I wasn't getting back in the death trap. The dealer had my car almost two weeks and said they never found why, they just went ahead and replaced the main fuse. Again now recalled. It's obviously time to contact a lemon law attorney, but curious if anyone else has had these issues. I am the original owner and kept all maintenance up with the dealer.
