Failure symptoms
Problems with Mass Air Flow sensors are common. Bad or contaminated CHRYSLER Sebring Mass Air Flow sensor can possibly cause a wide range of various vehicle drivability problems such as stalling, especially when the engine is cold, misfiring, poor acceleration, etc. In addition, a problem with the Mass Air Flow sensor often causes the "check engine" or "service engine soon" light in the vehicle instrument panel to illuminate.
Description
The Air Flow Sensor or Mass Airflow Sensor (MAF) is one of the components of an electronic fuel injection system and is found in many of modern vehicles. Most mass air flow sensors are one piece hermetically sealed units with no moving components.
Purpose
The Mass Air Flow sensor is used to measure (actually weight) the amount of air entering the engine. This measurement is used by the engine computer or ECM to calculate proper amount of fuel injected into the cylinders in order to provide optimum combustion and low emissions.
Maintenance Tips/Suggestions
CHRYSLER Sebring Mass air flow sensor requires no regular maintenance. On mass air flow sensors with a sense wire, this wire can become contaminated with dust particles. These particles can be removed with automotive solvents that are safe for the use on mass air flow sensors. CHRYSLER Sebring mass air flow sensors are commonly misdiagnosed. Before replacing the mass air flow sensor check for air leaks in the connecting air ducts and intake manifold. These leaks can cause similar symptoms as a malfunctioning mass air flow sensor.
Location
The CHRYSLER Sebring Mass Air Flow sensor is usually installed in the intake air duct between the air filter and the throttle body mounted on the intake manifold. Some mass air flow sensors are mounted directly to the throttle body.
I popped the fuel line at the rail and there is fuel but did not seem to be under much pressure, I also bought some starter fluid and it will start and run on that for a few seconds. I suspect my pump may be powering up but just not generating pressure or the pressure regulator is bad, either requires dropping the tank so I maybe should just replace both, my issue is I have never had a fuel pump "sort of" fail they have always been just dead...anyone have a similar issue before? I have had a dodge durango and a dakota where I had similar symptoms with bad crankshaft / camshaft sensors but those gave codes.
I'm working on an 04 sebring 2.4 liter and having same problems it sounds like. I have access to a lot of manuals anre are having a hard time chasing this one down.
Re: Sputtering, stalling, won't start. Ok guys, I also have a 96 Chrysler Sebring, 2.5 v6 Convertible. I have spent over $3400 this past year fixing everything! I am here to save you from doing the same. I replaced the ECU,spark plugs ( but that was ok they were the wrong ones) Chrysler Sebrings are suppose to only use Champion Plus premium, Bosh does not work on everything, including this car. I replaced the timing belt, oh Lord I could go on and on. In the end I finally find a mechanic with some brains, apparently I had leaky valve gaskets and the oil went into my CRANK SHAFT Sensor. Anyway, you must use the OEM, I bought mine at Auto Zone for $61, dealer had it for $82, but after I bought mine, found the OEM on Amazon for $31. Finally, no more sputtering, stalling and no start. I found we should replace the crank shaft sensor about every 60k miles, although Chrysler says every 100k. Be sure you use most OEM products for this car, after market ones will not work!!!! We live and we learn. God Bless and good luck guys, easy fix! Oh and I paid $40 for install not a big job, they can go in from the drivers side wheel well after removing the plastic cover when the tires off. Don't get ripped off like I did.
PS: Also check for recalls on this car, there are many which can save you a fortune!
Hi there, I have a 2007 Chrysler Sebring Touring 2.7 GAS. It has had stalling problems for over a year now. It finally just crapped the bed today. Wont even start up. Changed numerous amount of sensors. Thinking it may be the electronic throttle body. Has anyone else with the same model as my car changed that and had any luck? Anything helps. Let me know!
Above, @rbender says there have been some recalls for some 2007-2008 models. Some vehicles with TPMS systems have unused wires that could corrode and short out, causing no-starts, dead batteries, and stalling.
Recall #08V152000
I have a 2003 Sebring LXi 3.0. I get no spark or fuel. Considering the ASD relay. Where is the ASD relay?
After reading about these issues I'm a little depressed. I was hoping to find others with my issues that had solutions.... I have a 2004 Sebring convertable that I just bought a few months ago. I check the car fax and it was great - previous owner took very good care of it with all the regular mileage check ups. When I have been driving for at least a half hour - it wants to stall with I come to a stop. It has only died twice, but started right back up. When it starts acting like it's going to stall out, I put it in neutral and give it a little gas till the light turns green. But it continues to act like that until I turn it off for awhile. I took it to a Pep Boys, and they just had me pick it back up without doing anything saying their diagnostics only gave them an electrical code and that I would have to take it to the dealer to run down any electrical problems and told me it would probably cost quite a bit for them to track it down. Does anyone have any information or answers for me? I would like to not go to the dealership totally dumb. Other than this issue it runs great.
The same with the misfire that you have described, it needs to be diagnosed by someone familiar with the manufacturer.
I replaced my crankshaft position sensor, map sensor had the plugs and wires changed on my 1998 Sebring JXI convertible and am still having a stalling problem. It doesn't do it all the time, but I can be sitting a traffic light and the rpms will drop and the oil light will come on and the car will die. It starts right back up, but this is really annoying. Has anyone else had this problem and if so how did you fix it.
Thanks James
My husband and I bought a 2002 Chrysler Sebring convertible about 3 weeks ago, didn't have it checked out before hand, knew I should have, DARN!
Love the car, however, for the first two weeks it drove perfect, however knowing that the struts/ball joints need to be repaired. Since then, the car wouldn't start, had a friend of mine, mechanic check the fuses, it was the starter/relay fuse, replaced it, car starts, but the fuse would blow every two or three days.
Now, when I drive it, 35-40 mph, it dies, it will restart in neutral, but then it hard shifts to drive.
I've looked at the forums and thinking that it may be the Crank sensor?
I'm actually going to call the small dealership where we bought it and tell them what's going on, only paid $2100 for it, AS IS...Not sure whether they can and will do anything, but if they don't I will check with the Lemon Law here in Florida. Any ideas, comments welcomed.
Thank you for looking
Teresa
It runs. But now it stalls out at low speed and I have to restart it. How can I fix this so it does not stall now that I have replaced fuse 8 and the starter relay?
But later in the day, I found the starter fuse 8 blew again. I replaced it and then had to jump- start it again. I will take it to oriellys tomorrow for testing
