Maintenance Required Soon - 2014 Toyota Highlander Limited Long-Term Road Test
edited August 2014 in Toyota
imageMaintenance Required Soon - 2014 Toyota Highlander Limited Long-Term Road Test
With nearly 10,000 miles on the odometer, it's almost time for our 2014 Toyota Highlander to receive its second regular service.
  • schen72schen72 Member Posts: 433
    Has Toyota moved to a oil life monitoring system yet? Or is it still simply a timer based on the odometer?
  • titancrewtitancrew Member Posts: 17
    Do oil life monitoring system measure the chemical composition of the used oil or is it just someone's algorithm?
  • kyfdxkyfdx Moderator Posts: 271,390
    The latter
