Just for reference, they gave me an RX330 loaner. My personal opinion if they where side by side and same price, miles, etc, I would buy the 300. While some of the features in the 330 are nice, it is just too big. REally like the 300 because for ME, it is just hte right size. Only thing I would change is the turning radius.
Additional Maintenance Items for Special Operating Conditions: (itallics are mine)
[ ] Replace Timing Belt
Special Operating Conditions: (from page 53)
1. Towing a trailer or using a camper or cartop carrier.
2. Repeated short trips of less than 5 miles in temperatures below freezing.
3. Extensive idling or low-speed driving for long distances as in heavy commercial use such as delivery, taxi, or patrol car.
4. Operating on rough, muddy, or salt-covered roads.
5. Operating on unpaved or dusty roads.
At least a couple of the above apply and also since I've been using the 5,000 mile oil change intervals suggested for "most driving conditions", I will probably opt for timing belt replacement at 90K.
Pete
Anyway, hopefully I will get it back sometime next week and can start enjoying my new ride.
Take care everybody
Peggy
If your service rep has gone out of his/her way to help you, you might consider writing a brief "thank you" letter and sending it to the dealer GM or service manager.. it WILL trickle down to your service rep and they'll be HAPPY to take care of you again. Plus if you take the time to write them when things go RIGHT, can you imagine what they'll think you'll do if things go WRONG!!:)
Hopefully, it will be regular maintenance from now on...good luck peggylou!!
Lexus Owners
You'll need to register if you haven't done so previously. Click on "Quick Links" then "Contact Lexus". Let the Lexus Customer Assistance Center investigate your grievances. You will probably hear back directly from the dealer, but may encounter a much more conciliatory attitude!
Pete
Since the torque convertor is likely a big source of the heating of the fluid, taking it off-line with the lock-up solenoid in OD would very likely delay smooth operation and maybe even adversely affect reliability/longivity of the transmission.
If over-reving the engine when it's cold, lubricating oil like molasses, is bad the same should be said for the transmission. Life is full of "balances", compromises.
And speaking of cold engines, putting the transmission in OD would probably result in "lugging" the engine somewhat, and that is very hard on a cold engine.
Gteach, thanks for the suggestion to send the dealer a thank-you letter. I will definitely do that, its a great idea.
In the meantime, I am loving my Lexus!!!
Peggy
My rx will not shift into OD until warm. The reason they do this is that tranny fluid is not very functional until it reaches a certain temp. When the tranny is cold and going 70 mph in od it is very stressful in regards to the wear factor.
I am an ex Toyota tech, I would love to help anybody with any quistions. I have not been here in a while, I just bought a new 4runner sport, V8 AWD, and have been on those boards. Anybody please feel free to email me or whatever with any thoughts. Thanks Steven
I have a 2000 rx300 with 120k miles. Recently I did a brake job on all four wheels. When I looked at the rear wheel disk, it looked like it was attached to the rear axle. I saw a large nut which was secured with a cotter pin. How is this rear disk removed in order to replace it with a new one?
KE2FE
The AWD RX supposedly has a viscous clutch for bringing the rear wheels on-line with front slippage but the advent of VSC/Trac in 01 made that feature virtually useless and so it was dropped for 04 and future models.
My 00 RX owner's manual calls for regular gas,, and I have been using it with no problems.
As to the post 8066 by wwest, I'm not so sure about the importance of VSC/trac...At least in the AWD version, if going in bad weather conditions is the issue. I have been very satisfied with mine in moderately deep snow and slippery surfaces in NY winters. (Not sure from the post - may have only meant this for FWD versions.)
My bad weather performance comparison point is to a Subaru Legacy we also own.
I do run "severe weather" rated tires on both.
shoes4industry, Firesign Theater fan??
willard, philosophically I still prefer the viscous clutch and (optional) limited slip rear differential of my old 300 to the VSC/TRAC solution............but the 330's system seems more robust (for lack of a better word) even allowing for VSC. Have you done any experimenting in the garage (or elsewhere) with yours yet??
My insurance agent quoted me a slightly higher rate for the 99 than the 2000....any idea why?
I do understand about removing the calipers in order to remove the rotors. It is a pleasure to speak with someone who knows the car. I have been doing all the maintainence myself with the exception of the timing belt.
Once again, thanks for the help.
Bob
I found a large vacant parking lot, dropped the chains, and gunned it a few times. To my surprise the Trac system kicked in almost immediately and shortly therefore dethrottled the engine. No fun at all. Made several runs at it, sometimes twisting the wheel radically to engage the VSC, with no success. All it would seemingly do was apply the brakes at the front and then suppress the engine output to a non-slip level.
Otherwise it performed very satisfactory with just rear snowchains throughout the period.
I was hoping to make another trip to europe this summer and pick up an X3 to bring back. But now summer plans have become indeterminate.
But I do really want to see and drive the new RX400h before I decide on the 330. I'll still probably op for the 330 since I don't quite see the sense of V8 performance. I'd much rather see the hybrid RX with a 4L and 3.3L V6 performance.
After seeing that ad wherein the guy ties his 4WD pickup to a tree and then guns it a few times to show that all four are "working" I'm out looking for a good stout tree to tie the RX to.
Despite the new RX330, still loving my "old" one. I plan to keep for another 100K.
And even though it isn't perfect, I still enjoy having GPS.
So...my question to you'all who've changed the timing belt/water pump, etc., etc., how much was it? Should I start saving now? Thanks for any feedback.
I WILL NEVER BUY ANOTHER LEXUS AND I WILL NEVER RECOMMEND THAT ANYONE ELSE BUY ONE EITHER IF THEY DON'T MAKE GOOD ON THIS PROBLEM.
Also at 50,000 mi the drivers visor broke and I have to go to the customer service # in order to get the dealer to fix it.I had called the dealer before the 50,000 mi warrenty but when I brought it to the dealership for the 50,000 mi service there was more than 50,000 mi on the car and they fought about covering the visor.
So if I understand this correctly: They are willing to split it with you but you still wont buy another Lexus product because of this? Go ahead and buy something else and see where you are at with 70k.
Here's the only exception I could think of that may help you: IF you had service every 5000 miles AND they did all of those supposed "multi-point" inspections they love to put on the service write ups, shouldn't they have found that the seal was developing a problem sooner? Perhaps that's why they are covering half the cost?
I know it stinks to have to pay lots of $$ to fix anything --but we all have to go through it eventually -- yes, even with Lexus.
A friend took his 91 LS in to be serviced at Bellevue Lexus and the next day discovered a smallish pool of oily fluid on the floor of his otherwise pristine garage floor. It seemed impossible to me that Lexus could have done something to cause this so he spent $1100 to have the seal replaced.
Later I heard rumors that over-filling the engine with oil will sometimes cause the rear main seal to blow.
Pete
Good luck
A Rep. at Lexus stated that it looked like a defect, once he confirmed that it was the factory windshield. My friend believes that it is the plastic between the glass that is warping, due to the heat her in Las Vegas.
My mileage is 58,000 and the warranty has expired many miles ago.
Do you think that this is a windshield defect or something that just happens with time? I've never seen anything like this.
Do you think that Lexus would be willing to replace the windshield if it is a faulty product even though I have excessive mileage?
Thanks to all for the input and suggestions,
Troy
Try these steps..
1. Erase the homelink memory by holding the two outside buttons on the unit for twenty seconds.
2. Program your garage remote into one of the homelink buttons by pressing down the garage opener button and the homelink button at the same time. A blinking light on the homelink confirms it "took"
3. Next, go up to the opener unit and open the casing where the light bulb is. There is a little black button in there with a little red light next to it. Press that button and wait for the red light to come on.
Now...
4. While that little red light is lit on the opener you have about 10-20 seconds to go back to the homelink and press the button you just programed with you garage remote. Press that homelink button up to 5 times. Once your garage closes or opens you are fully programmed and it should work from then on.
Worst case, if you still cannot get it to work then call homelink's 800 number (it is in the RX manual) -- I had to call them the first time I tried to program it a few years back and they were very helpful. As far as I know, homelink works with ALL openers even the one with rolling security codes.
Good luck!
Purolator C38222
Pete
Also, make sure that you are not in the vicinity of your garage door when you do the programming because that can screw it up, too.
I must admit that I didn't do anything about erasing the old code even though it's a '01 I bought used.
Just follow the directions and be patient. I think it took me a couple weeks to finally get it right but I was psyched!
And now I'm moving so I'll be reprogramming mine in just a few days!
Also, does anyone know who makes the glovebox-mounted CD changer? I'd like to pick up an extra cartridge and if it's a major electronics brand, it would probably be cheaper than buying the official Lexus one. Thanks!
