In mixed driving short trips of about 6 miles, I'm getting 15 mpg and about 18.5 mph on the highway. My Trooper is about to roll over 91K miles. I think it runs as well now as it ever has.
Things I've done to improve MPG are well documented on this site in previous messages.
For the life of me, I can't find the referenced in this thread.
Can someone help me out? Does this sound familiar to anyone?
If it helps, the spark plugs with very custom, plasma / arc technology and you had to buy these from the company that manuf. the harness / system.
bradesp
The new "built into the spark plug" version is here:
http://www.pulstarplug.com/
This is the product I used in my 1995 Trooper, I got the whole kit, zero resistor spark plugs, low resistance spark plug wire set, and the DirectHits units.
http://www.directhits.com/index.html
And the white paper that gives the circuit diagram and technical details:
http://www.directhits.com/tech/SAE_02ffl_204.pdf
Other articles about the DirectHits can be found using your favorite search engine and "DirectHits" or "Pulstarplug" or "Combustion Technology Products Corp." etc..
Here is a place to get efficient low noise spark plug wire:
http://www.rahq.com/acatalog/Online_Catalog_Ignition_7.html
Here is a web page dedicated to all sorts of MPG enhancers, I don't know anything about it, except it popped up in my web search.
http://peswiki.com/index.php/Directory:Fuel_Efficiency_Retrofits
The 3.2 DOHC motor seems very good. You have to make sure the timing belt maintenance is followed, and common complaints seem to be about lifter noise and loose steering. If you do a search of this forum, you can learn a lot. ( The factory recommends running a 0-30 synthetic Mobil 1 for noisy lifters for at least one oil change cycle, and the steering problem is usually addressed with power steering fluid change, adjusting steering gear and checking tire pressure and alignment).Isuzus have a pretty complex electrical architecture, but seem fairly reliable to me. I highly recommend going through the vehicle and changing all fluids so that you know what you have to start with.
Good luck, and if you find out the problem with the doors, please post so we can all benefit. Best of luck.
Regards
Chintan Talati
Corporate Communications
Edmunds.com
I have a 1998 trooper, recently failed the smog test with NO high (AVE: 88, MEAS: 848) at 15 mph.
My check engine wasn't on, and have been using 91 gas. just had an oil change with synthetic oil (the same day as the smog check), run the car for 20 minutes on the road, still failed. The guy suggested a catalytic convertor replacement, is there other solutions?
David
Washer
When the windshield washer switch is depressed, battery voltage is applied to the windshield washer motor and the alarm and relay control unit. The windshield washer motor pumps fluid on the windshield and the alarm and relay control unit energizes and applies battery voltage to the LO winding of the windshield wiper motor through the windshield wiper switch. The wipers run at LO speed until the switch is released.
Unless there is a kink or something blocking the inlet or outlet to the pump, and assuming you mean that when you attempt to apply fluid the wipers do turn on, I would guess that the pump is bad in the front of engine compartment.Here is link to picture:
http://www.carspace.com/atfdmike/.59a62722!v=.
You may unplug the electrical connector and use a 12 volt test light to see if voltage is applied when the fluid button is applied. IF there is power, then pump needs replacement. They are available at most parts stores. good luck
1998 Isuzu Truck Trooper LS V6-3.5L
Vehicle Level Powertrain Management Emission Control Systems Catalytic Converter Technical Service Bulletins All Technical Service Bulletins Emissions - Misfire DTC's/Catalytic Converter Damage
Information IB04-03-S001
Misfire DTCs and Catalytic Converter Damage Due to Installation of Alarm Systems
Issue Date: February 2004
Affected Vehicles
2003 - 2004 and prior Isuzu models.
Service Information
It has been determined that aftermarket alarm systems incorrectly installed in vehicles have the potential to cause misfire codes and damage the catalytic converter.
These alarm systems use a circuit interrupt which utilize the ignition circuit on the vehicle, they also utilize mechanical relays and normal vehicle movement can trigger these relays to engage and disengage the ignition circuit while the vehicle is in motion. These disruptions of the ignition circuit, which occur in milliseconds, may cause more fuel to be commanded. Over time, on and off fuel dumping can cause misfire codes and ultimately damage the converter assembly.
Engineering could not identify any alarms that utilize solid-state circuitry that would eliminate this concern. Because of this, it has been determined that all alarm systems must be routed through the starter circuit in order to avoid this condition.
Dealers must be aware of this issue and take note of the wiring on vehicles with alarm systems that come in for repair, particularly for catalytic converter damage that seem to have no known root cause.
I would also suggest that you do not rely on the voltage guage for checking the condition of your system. A Digital multimeter will give you precise and accurate readings. A common Isuzu service recommendation is to check harnesses and connectors for conductivity (ie: clean with contact cleaner and make sure wires and connectors are all intact. Maybe with some more info from the codes you will get more help. Good luck.
I have never swapped out an engine but looking at the service manual for 1993, and for 1992 through 1995 the SOHC engine is the same. It would matter for purposes of single or double cam, and whether it was a manual or automatic trans. Only the SOHC 3.2 is available in 1996, and I cannot tell if it is the same as previous.
the other engine option available for 1992,1993, 94 and 95 was the 3.2L DOHC Fuel injected engine. For all practical purposes, same mechanical mounting, but different ECM.
Hope this helps.
Karl is sympathetic if you want to go vent. :shades:
Spring has Sprung...and So Have the Speed Traps
Note: The PL14459 is extremely common in Japanese vehicles, fits most Honda cars for example.
Suggestion for a larger capacity filter: The thread is 20mm x 1mm, measure the filter seal location and then find dimensionally compatible other filters. I once found a reference for a much larger filter made for a diesel engine that would fit, but the pressure relief valve built inside the filter was too high a pressure compared with the PL14459. About that time I found the PL24458 by comparing dimensions and specs in the Purolator book, I used that as long as I could find it.
Related topic. Last oil change at 134K, I switched from Valvoline Max Life to SynPower, mainly using high octane, did switch down once, and the ticking started back intermittently. About to change the oil with 4K on it, but last tank used high octane, and it went away. Not bad considering it's been only 40 days since my last oil change !
Strange oil change fact. After each, at about 1500 - 2000 miles I'm down about a quart, but at 4000 miles, perhaps a 1/4 quart low.
I use high octane gasoline to avoid preignition. I also use fuel injector cleaner (Valvoline or Lucas Oil brands) once in a while.
I have 93K on a 2001 Trooper manual 5 speed. My best MPG was 22mpg in Yellowstone park at 45mph. Next best was 21mpg driving 65-70mph with a tailwind. My worst was 16mpg keeping up 65 to 80mph on 6% up hill grades with a sports car over the Rocky Mountain passes on Hwy70 West of Denver.
Ask a great Trooper mechanic at http://www.creechimports.com
I am aware of the major Isuzu issues, lack of dealers, etc...
Any other issues I should be looking for??? Any advice is welcome.
Thanks in advance,
Tim-
1.) Stay away from a Trooper that looks beat inside, because that means they probably have not done the maintenance.
2.) See if all the tires are the same type and size, sleazy tire selection to save a buck also means they probably have not done the maintenance.
3.) If the suspension feels worn out and the handling is very sloppy the Trooper has seen some very hard use. Do a good evaluation before buying, then upgrade using an OME or similar suspension upgrade kit.
4.) Have a mechanic that you hire for $100 to $200 do a thourough check out of the new Trooper, this way you know what you are getting, remember engine/transmission replacement are far too expensive for a used car, unless you are emotioanlly attached to it.
5.) If you buy it, have all the fluids changed right away. Do the 90K maintenance includes oils for engine, trans, xfer case, 4wd or TOD selector, power steering, front diff, rear diff, and engine coolant. I would also add a full flush of the brake master cylinder and lines. I did all of this on my 2001 Trooper when bought it had 30K miles. I have had 63K trouble free miles and am doing the 90K maintenance today. Doing the service might identify issued to take care of before they become a problem.
Ask this discussion to tell you of particualar issued for your model. example on my 2001 the intake manifold gaskets are prone to crack, so check for the cracking and change them before dirt is sucked into the engine.
To hold the balancer, a strap wrench will help if you have one. If not, I have used a piece of half inch rope and made a tourniqet with a screw driver on the balancer to hold it. You may need a balancer remover to pull the balancer off of the crankshaft. Be careful not to hammer or pry the balancer, as it can be damaged. There is an alignment groove and key that you will need to keep track of once you remove the balancer. Good luck. Let us know how you do!
I had an Audi that developed a $1300 leak in the evaporator core at 50K. I'm hoping that's not the case with my Trooper.
I owned a sweet '92 Trooper for 12 years before I foolishly sold it....now I am looking at a 2000 limited 4wd at a local shop down the street with 62K. They are asking 10500 which I think is high. Reading the posts, I am hesitant to buy -- transmissions, timing belts, oil consumption, ect. I've gathered quite a bit of helpful information from posts, but are there red flags I might check that would indicate whether to avoid this Trooper. Also, carfax showed it was a lease vehicle -- could this mean a rental?? I thought i read something about specific features of rental fleet vehicles??
Any suggestions are appreciated...
Thanks, Scott
One big consideration for me would be how readily you can get service AND parts given Isuzu's departure from the American market. I have a 94 which my son drives, and I too like the older models, but they are not without their problems too. Manufacturers are only required to service emission parts and warranty parts for 10 years after discontinuance of a vehicle, so factor that in too!
Even if there's no legal requirement, parts for 30 year old obscure models seem easy enough to find. Daewoo owners were very concerned when parts dried up, but that shortage only lasted a few months.
It seems the Tranny is the biggest risk with these vehicles??
105K miles
new timing belt, plugs
Tim
