If I stop and start the engine immediately after I get this code, it will not go into TOD, but the "check TOD" and wheel indicator lights will keep flashing.
If I let the engine cool, I can shift into TOD without any problems, but again, after several miles of driving, I will get the flashing "check TOD" light again.
Any ideas?
Identify the fuel relay on the RH fender well and remove it to allow you to put a jumper wire across the hot terminal to the fuel pump terminal. This will allow you to turn the pump on (with the ignition preferably) and pressurize the fuel system. If you are not handy and familiar with electrical troubleshooting, you may want some help to do this. Then you can be sure the pump is on when you try your initial start up and see how the engine starts. If it fires right up, and does so the next time you cold start, then your fuel system is losing pressure but your pump is fine. The gauge will tell you if you are losing pressure too fast by watching it after you shut the truck and fuel pump off after running it, and see if it falls. It will fall but it should do so very slowly, like over a several hour period. If it happens fairly fast, then the next place I would check would be the fuel regulator:first remove the vacuum line to it and see if fuel come out of it when the fuel pump is on.....if it does, it is bad and has to be replaced. If no fuel comes out, then it gets trickier, because you can change the regulator but it is a bit of work to do so and see if that makes a difference. It is about $50 bucks last time I did one. You also should replace the O rings at the same time. As I said before, if there is a check valve in the system at the tank that could be my last check. I just don't know if it exists but I suspect it does for safety reasons if none other. Maybe a search of this forum and others will help on that one. Good luck. One guys opinion.
Let us know what you find!
This is a lot of work, but easier (I think) than looking at the fuel pump. When you tested did you see any loss of pressure over 15 minutes or so? I generally look to the obvious first, and since Isuzu makes mention of the fuel regulator as a cause for slow starting, I would start there. I have often thought about putting a direct push on type switch on the dash that would allow you to energise the pump at will so cold starts are not a problem. Most car companies have a longer run time than Isuzu for the pump at start.??????
I agree that if oil was deep in tube then you might get shorting of spark current, but not a little at bottom of tube. One guys opinion.
good luck, one guys opinion.
I followed directions I found on planetisuzoo.
I had had a CEL for a while and surging idle. My mechanic told me it was the MAF sensor, but that didn't seem right to me... then I started hearing the engine whistle. Dead giveaway.
It hasn't run this smoothly in a long time.
so i let the vehicle sit overnight and in the morning pulled all spark plugs out and smelled them all over and over. I found that one spark plug reaked of gasoline, so hopefully my theory is right and its a leaky fuel injector that is flooding the system and is the final cause to this problem. tommorrow i begin the replacement process. i will respond with a conclusion.- jes
after the rains this last weekend, I went out to my trooper to discover that the passengers side floor were soaked with water. It's coming in thru the blower motor. I took the garden hose and soaked the windshield and the flow started again. I loosened some of the screws mounting the blower motor, and quite a bit of water came rushing out. Is this a pretty common problem ?. I've had the Trooper for several years and this is a first. Any suggestions as to what to do to rectify this problem. Thanks for any input. John
Recently tried to engage shift-on-fly 4x4 but it would not engage. Dash light blinks normally but front wheels do not kick in and dash light just blinks until I give up and turn off shift-on-fly switch.
No odd noises whatsoever, drives perfectly in 2-wheel drive.
Have tried to engage 4x4 from dead stop, low speed, 60 mph, but no go. 4x4 has worked perfectly before, this problem just began with the first snowfall. (Typical!)
What else could I try? :sick:
See more Car Pictures at CarSpace.com
Question 1: How do I check for vacuum at the actuator? (Engine off/on? Tranny in park or not? etc. Don't want to run over myself.)
Question 2: How can I "wiggle the actuator free" if it is 'stuck'.?
Question 3: Where does the other end of the vacuum hose attach? I'd like to check both ends to make sure they are attached properly. Is it possible it might have been knocked off during pressure washing engine bay?
Thanks for your help. Wes.
Wiggling as you call it is a little more interesting.
Go to www.myisuzuparts.com, enter your vehicle info, then find Illustration figure 4-12, second image. It shows the axle assembly schematic. Before attempting to remove the actuator, I would definitely drive the vehicle long enough to warm it up and repeatedly try to cycle the SOTF system (after completing Question 1and finding the vacuum switching with the switch...I don't know which port has to have vacuum to work right, but obviously it should change when you cycle the switch.)).
The t case has an electic shift motor and a module sits atop the case where the vacuum is switched by the shifting tcase. If you search www.myisuzuparts.com you can also identify it. You would want to work your way back to the vacuum source on the engine too....I don't know your motor but I think you should be getting the gist of this.
The electric switch on the axle actuator is just to turn on or alert the driver and 4WD system as to the status of the axle, it does no other function.
Also, If you have TOD system, I know even less about that except it can be hard to troubleshoot. Good luck.
Like you, I did some things to TRY to solve the problem...engine flush, rad flush, new thermostat...nothing worked.
It turned out that the problem was with the valve that routes hot water from the engine through the heater core. Hot water was not getting into the heater core at all, so of course no heat would come out into the passenger compartment.
I can't recall if the valve was actually built into the heater core or if it could be replaced separately, but pull out the heater core and have a look at that valve...I bet that's your problem.
I also have a 2WD 2002 under 50k in South Florida. The only transmission issue I have noticed so far is a small clunk going from Park to Drive or vice versa. Gearshifts seem fine.
Was thinking of having it checked out (recall the old AAMCO ads), and will run it by Gold Coast - anyone there in particular?
Today I stopped to wash my car at the car wash. After I did so, I jumped on the hiway. About a miles down the freeway, My vehicle stalled. On the side of the freeway, I went thru the process of problem solving the situation. This is what I had done....
First and foremost, I checked the distributor and router for moisture. In doing so, I found no moisture. I then checked all the plug wires, and everything was secure and dry. After that, I went ahead and checked to see if I had blown a fuse. In doing so, nothing was blown. I also checked the fabric wire fuses and rearanged the relays next to the fuses. Then I started to think that there was fule pump problem. I went ahead and put some fuel in the carb from a gas can I always keep for safety purposes. I added not too much and not to little. In craking it over, nothing fired. It just turned over. So then I got thinking, maybe my coil was shot. I went ahead and purchased a new one at the auto store and replaced the old one. To all avail, It still woudn't fire up. All it's doing is turning over. In the end, I ended up having to have it towed home.
So here I am, and I just don't know what to make of it all. When I look back to what I did at the car wash. I didn't open the hood this time to wash down the engine, so I don't know how water could have got anywhere. One thing I did do was spray under the engine and the under carrage. I always do so here in Colorado. Esspecially when the snow and mud collects underneeth.
If there is anyone out there that can help me troublshoot this problem, It would be soooo greatly appreciated....
Thanks a bunch....;)
Maddy :confuse:
I
Anyone else have ideas?
SUVs and Smart Shopper
UPDATE: I have not crawled under the beast yet, HOWEVER, yesterday when I started up and drove away, I noticed the 4x4 was fully engaged! (Dash light was fully on, traction on ice was obvious.) I switched 4x4 OFF while driving and tried to engage in again, but it did not. This has happened twice...4x4 will engage from a cold start. I tried a few things like putting in park, hit dash switch and drive off, but no 4x4. Engaging in reverse, no. Hitting button multiple times, no.
What do you think of this, and what else do you think I should try?
Also, this is an '01 with under 50,000 miles. Do you think a warranty applies?
Thanks. Wes
I don't have your year or type of front axle, but to make a guess on what you describe, I would ask a couple more questions. When you hit the 4X button, do you hear the transfer case shifting in and out of 4X? You can listen with the vehicle sitting still, it does not have to be moving to shift. The electic shift motor should cycle or attempt to when you hit the button.
If you hear the transfer working consistently, then I would next check the vacuum being applied to the axle.
It could be that after sitting, the vacuum is gone and on start up, and if the vehicle is in 4X then the axle shift actuator is reacting to that command and does not have to overcome the vacuum that pulls the axle out of engagement. IOW somewhere there may be a sticking valve. It could be the one on the trans case that reacts to the trans case shifting into 4H or 4LO and sends vacuum to one side of the actuator. I am not that familiar with the actuator system, so I don't know if the actuator is spring loaded one way or the other or whether vacuum in the other direction is needed. I would research that a little more, by carefully looking at the axle actuator and pulling the vacuum hoses while the transfer case is shifted into different positions. You should be able to determine what is happening (or not). Remember that to be safe, park on level surface (or ramp) with park brake on and chock the rear wheels at least. You don't have to have the vehicle in drive to operate the transfer case and thus the axle. Vacuum should at least be present or not depending on the button position. Listen before doing anything for vacuum leaks. Have someone you trust shut off the engine while you are listening down there to hear if you hear a leak as might be present.
I am no expert,but I think this will cover the basic things. Be careful if you elect to do it, good luck
These are pretty easy things to check first in the event you don't have warranty coverage.
Are you having a problem getting enough amps from your alternator? The belt squealing sounds like the alternator, if working properly, is making a lot of amps which is why it is hard to turn. Maybe you have a short circuit or too many loads (120Vac inverter running something big?) demanding excessive current. If you want lots more current there are after market alternators that can be made to fit that can produce 200Amps maybe more, some can act as a welder too.
It could be excessive mechanical friction preventing the alternator from turning freely, that would make the alternator body hot.
It could be not enough friction on your pulley. If the pulley is worn out or coming apart then the belt might not fit securely and that could make it slip. If this is the case the slipping pulley will be hot.
Hope this helps. Good luck.
Thanks for any help
I am not sure when shift on the fly became the 4WD for Isuzu, but in any event, have you looked at the drivers side sun visor....there were directions on it from the factory for 4WD useage.
If your front hubs do not have any language or knobs on them, then you likely have shift on the fly.
You must stop the vehicle to shift in to or out of 4WD. If you have manual hubs, you should lock them first before shifting into 4WD
If your hubs say auto hub on them, then you do not have shift on the fly, and the following applies.
Once you have shifted into 4WD while stopped, you may then proceed to drive and the front hubs on the auto hub will engage after about 1 tire revolution. they then stay engaged until one of the following occurs:
1>) You stop, disengage the 4WD and then back up about 1 tire revolution (9 feet or so). The autohubs will disengage and then you may drive forward normally. If you don't or can't reverse after shifting out of 4WD, no harm will come to the vehicle, but your front axle will stay engaged until such time as you do reverse.
2.) While in 4WD, you may need to back up for some reason. IF you do, the auto hubs will unlock briefly while you reverse direction, and then reengage while going in reverse. There is a brief time while you are not in 4WD, but for all intents and purposes, it generally poses no problem for the normal driver. IF you then shift into drive from reverse, the auto hubs will again disengage briefly and then reengage going forward.
I hope this helps.
One guys opinion!
Some machanic stated that this is a big job to do, but I do not know if is true or not If someone can give me a tip I will thank you very much.
thank watcord :sick:
Best advice I can give you is make sure whoever does it replaces the gaskets for intake and the thermostat, and use only the OEM thermostat. As for gaskets, most prefer either OEM or Felpro for quality and fit.
Hope this helps.
Good luck!
Isuzu to quit light-vehicle market in U.S (Straightline)
