Ken, I'm sorry. I thought this abbreviation was commonly used. I meant the center stoplight in the rear window. I've also noticed a change from my '99 horns towards the '01 ones. I was thinking of the original ones, which were sonically as unconvincing as the center stop light still is visually.
Spike: The ML DOES have a lockout switch for the windows. The only trouble is that where it's located (slide switch on the console), your dog might accidentally step on it. BTW: Couldn't we have a picture of this dog of wonders??
Kind regards from Europe,
Birger
The recent discussion of new Dunlops and competing Michelins has caught my attention while a recent automag (Car and Driver?) rating Yokohama the best all around in all categories really caught my attention wince the test mule was an ML320.
Any thoughts out there?
If you want some info on alternatives, stop by http://www.keysolutions.com/M-Class and have a look at the tire ratings. Unfortunately, not that many people have contributed. I know a few folks on the M-Class list have put on Yoko AVS tires.
If I were you, I'd wait and get the new Dunlops (assuming you're mostly doing street driving)...
I have the same situation with my dog. Her paws are just the right size to lower the windows. My mom just puts a small pillow on the center console of her ML, which doesn't totally elimate the problem, but it's better than nothing. But the most annoying thing is in my 1996 C220 with the trunk release on the center console. The release works with the car in drive but only if the car is stopped. Let's just say my dog has the habit of opening the trunk at red lights...and the trunk opens ALL the way...
-Todd
Rearview Fresnel mirror ??
Rich
I couldn't find it at any of the local auto stores in the Boston area and ended up ordering it from J.C. Whitney. It's called the Backsee.
Months ago I saved a contact # for someone who was sharing the extended warranty for a super price.
Well I can not find that information and have two weeks to make the purchase.
Please advise me via mail if you have a "contact."
Thank you... Mike
Rich
-Todd
On the other hand the RX300 is built on a car platform, not as sturdy, without a frame, yes the ride should be more car like.
I have an ML430 and considering that it is a four wheel drive vehicle I find the ride quite good.
Dave; Welcome! What took you so long?
Also keep in mind that the ML has a low range gearbox, it is a plus when in difficult situations, you can keep the vehicle in low range and put the selector in first gear, is almost a crawler gear, go to the dealer and try it, it will pull hard.
Also, is there anything new for the 2002 coming?
1.
Technology of ML is far superior.
2. RX has a front drive Camry engine/transmission mounted sideways as in most front drive vehicles. The shortcomings of that set-up are many but one that was particularly irksome to me was the 42 foot turning radius. I simply could not turn in quick enough to park in my spot without backing up twice. When i finally discovered the spec that lead to this dilemma I realized the RX would be no where near as maneuverable as the ML. The ML has a logitudinal drive train which is far more efficient.
3. Misc.: RX is a 4 speed trans not 5; no low range; not in any spec as heavy duty as the ML; ML has 4 wheel traction control in addition to fulltime 4 wd with a 50/50 torque split; the RX is front wheel drive that kicks in the rear only when needed and in our climate requires the optional limited slip rearend to be effective in snow.
4. both are good vehicles backed up by the best manufacturers' service and warranty policies (I've had both Merc and Lex). The Ml is way cooler.
5. I am often asked about gas mileage. To the surprise of all I get over 20 mpg consistently, winter and summer. When I commute the 38 miles to my office I can get 24 mpg without trying.
No SUV can compare, that is a real SUV.
Hope this helps and remember - test drive, test drive, test drive....
More autoshow pictures, including detailed ones of the all new '02 MB C230K coupe can be seen here:
http://albums.photopoint.com/j/AlbumIndex?u=137587&a=12386777&f=0&sp=0
how much are the OEM flares from MB cost anyway ? they are unpainted correct ? installation concerns ?
dt77
00ml430
Unless you activate the "city lights", you (on the US/CAN side of the Pond) will not be able to use the silver-look-flash-amber bulbs by Philips and Osram. These bulbs will probably fit in your receptacles, but they're single-filament (21W) and not like your amber ones dual-filament (21/5W). You will thus lose the 'corner lights', unless you get hold of a proper 5W bulb to put in the empty socket in the high beam reflector and do a bit of supplementary wiring.
Just my late-evening 2ç/0.02€
Birger
- who's off on early Easter holidays until 04/16 :-)
Just my two-cents worth.....
Drew
if i have a timeport phone can i integrate it with my vehicle?
Of course the best solution would have been to get the ML 55 bumper assembly too, but I didn't think it was worth $2K.
Bob
I think it is a good deal for the dealer to sell it at such a price but I would think twice before doing it... Here is why... In just a few months (or much sooner) we will have official information on the 2002 models with the many improvements over all previous model ML's...Such as Front and Rear Climate controls, Side Air Bag Air Curtains, New Side mirrors with signal markers, new front and rear bumpers, new Bi-xenon headlamps, New Bose Stereo Speaker Configuration, Automatic Power up "AND" down windows, rear 1/4 power window options, Linguatronic options + other comfort features... ALL of this means we will all take a considerable hit on our current "19xx-2001" model values.
Even if no changes were going to be made, the $31,900 would suggest that the same people who purchased 2000 models at @ $35K would be able to sell them at no loss or even a profit... doubt this seriously... as soon as you drive a vehicle off the lot in this price range you've lost $5K! In addition, the 2001 model are selling close to invoice now in many locations with good negotiation skills. This will soon change to perhaps below invoice as dealers try to clear out 2001 inventory in preparation for the 2002 models. Therefore, you would be better off spending $5K more for a 2001 model now and have full warranty, full maintenance and all the new standard features the 2000+ models have over the 19xx models....
Finally, we own a 1999 ML430 and am very happy with it but our vehicle with every option M4, Bose, Sky///, metallic brilliant silver is worth about what you might be paying for same year ML320....
My advice - get a 2000+ model. Your best scenario, as explained above, would be to work a deal on a 2001 ML320 for close to invoice; with all the ++++ of a new vehicle it is well worth the difference... OR wait until the 2001's are being cleared out below invoice and get and even better deal...
Final Final comments.... just because a dealer asks these prices does not mean you could sell the vehicle yourself for these "high market" prices... they have a very large audience and sometimes an Uneducated Buyer is their Best Customer : )
Take care - Frank
I don't know if it would be bad Karma to list the name. Email me directly and I will share with you.
Why all the need for Higher output bulbs, auxiliary lighting, etc.?
I drive 38 miles to my office in rain, fog, and 125 inches of snow each year. The only lights on my 99 ML320are the original and factory activated fogs. I have absolutly no problem seeing at night or in heavy fog or snow and I wear bi-focals.
Are you folks near blind or are these simply vanity installs?
Said shipping of '02 will be earlier this year than before. MB will probably begin shipping '02 in August '01. Current '01 allocation will stop in June. "Special Program" (rebate/discounts) will begin in July '01.
He will mail me with '02 ML features difference. I'll post them if they are not redundant.
Mike
Bob: I imagine your brakes will be OK, but I would be careful on long downhill runs with a trailer in the desert!
I probably would mention something non-specific like "I can get this warranty at XYZ price at another dealership" and see if they can match for you. If not, the answer is simple.
David
I'm curious if they're just showing the MY2002 pictures. The air suspension is not coming out until the full redesign in MY2004 (2003 year introduction)...
Thanks for sharing the info. but it is not likely many of us will be able to get the publication in a timely manner. Can you scan a photo such as Ken requested or send a scanned version to Drew so he can post?
If you can't, can you describe what you mean by "twin headlights"... are you saying a totally new hood and fender arrangement with separate lights such as the E-class? Or are you just referring to a similar looking arrangement to what we currently have on the ML but with distinct interior high low projector beams in a one piece assembly?
Thanks Again!
Frank
dt77
http://fullspeed.to/ml
Photos of my ML55 can be found here:
http://albums.photopoint.com/j/AlbumIndex?u=1295943&a=9616489
Please be aware that those photos were taken at delivery/pickup back in October.
I'll be ready to actually deliver the ML55 in mid-May for those of you that are wondering.
Any questions, please email me.
Jason
