if your using coolant,FIX THAT QUICK!! or you WILL be replacing that head gasket,or engine!! overheating is how heads warp,and gaskets blow..
mecanics have a tool that pressurises the coolant system to help find leaks...shouldn't be that mutch,and a damn sight cheaper than replacing a overheated engine..good luck! i think your engine is giving you a warning that a catastrophie is lurking just around the corner..get on top of it,or it will get on top of you..k? :sick:
i always checked to see of i could turnu the alternator shaft.
also, see how mutch deflection you get at the longest stretch of the belt
tentioner has marks to let u k now when belt is streched..good luck!
I've wrestled with it on my 98 cherokee as well. It started around 180K and appeared from time to time over the next 100k miles. Fixed a bunch of stuff; Steering damper, sway bar links, new tires, even a ball joint. All of which seemed to help. But the silver bullet was was the shock absorbers. My error was thinking that they were relatively new and couldn't be the problem. They were a big part of it.
