2015 Ford Mustang vs. 2014 Chevrolet Camaro
Edmunds.com
We break down the 2015 Ford Mustang and 2014 Chevrolet Camaro to see how they stack up.
"Where the Camaro has an advantage is its V6. Rated at 323 hp and 278 lb-ft of torque, it easily tops the Mustang's base engine ... Official horsepower figures haven't been released yet, but Ford estimates that the new four-cylinder will deliver at least 305 hp and 300 lb-ft of torque. That would put the Mustang squarely above the base Camaro in terms of both horsepower and torque, not to mention the weight advantage of the small engine."
Would someone please proofread these articles before posting... or buy the writer a f*cking calculator?
So does an Nissan Altima.
The 2.3 is mid-level engine; the V6 is the base engine.
Therefore, Chevy's base engine is more powerful than Ford's base engine.
You want to win the pissing match? Then expect to pay more for the mid-level 2.3 4-cyl in the Ford versus the base level V6.
In ~1983-1984, the there was a super rare Mustang SVO equipped with a 2.3 liter turbo engine. That engine continued on into the ford thunderbird "turbo coupe". I owned a 1988 thunderbird turbo coupe and that engine, despite being in a very heavy car, was just a ton of fun.
This new 2.3 liter harkens back very nicely to that limited time in the 1980s when ford was cranking out one of the world's best 4-cylinder turbo engines - way ahead of it's time.
Do you forget that one of the hidden gems way bac
_____________
That POS was 175 hp that came on only at the top end. Just a joke really, a few year later Honda would get 205 hp from a 1.8 liter without a turbo, and it was much smoother.
_______________
It would not get out of its own way until the turbo kicked in all at once. It was not reliable and cost much more than the 5.0.
While the final weight has not been published, the new Mustang is expected to come in at about 200 lbs lighter than before. One of the ways this was achieved was the increased use of aluminum. The hood as before is aluminum but this now extends to the front fenders.
The rest of the body structure is stamped steel but has increased use of lighter and more expensive high-strength steels. Aluminum is used in some of the suspension components such as the control arms of the independent rear-suspension.
Old Ford guy from Missouri
