2013 Scion FR-S: Track Tested
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Our 2013 Scion FR-S is finally supercharged. How fast is it? Find out in our latest track test.
NOT a "30 Horsepower difference"
How fast can you afford to go?
Apparently, not very fast.
I'm guessing if they had tested the top gear roll-on performance of the car, the differences in acceleration times would have been enormous.
Seems money better spent on investments and waiting for the turbo BRZ STI? Which will likely make this FR-S looks like a joke when it's launched.
IL explained the issue with lower grip, possibly reflecting the worse than expected 0-60 time.
That said, % power gains will never equate to a certain amount of speed improvement. I can add 10% to a 100 hp car and not see much difference, or I can add 10% to a Z06 and see a huge improvement. The % matters to builders and reflects how good the system is, but overall power is what matters for accel.
How much does one spend to get away from FWD?
First you melt the stock caliper dust seals on a track w/ a brake kit and act surprised (dur...track calipers mostly have no dust boots for this very reason), now this? How are we supposed to make use of useless or partially correct data?
Are you guys hiring? I think you guys need some help over there to sort things out.
"crappy worn out tires?" Have you even read comparison tests with lap time and slalom speed for the AD-08 and MPSS?? The AD-08 are quite a bit better than the MPSS on dry surfaces and on track where the MPSS gets greasy in short order. The only thing the MPSS is better at is in the rain, and when this is taken to the track, a second set of tires should be used anyway, instead of going with compromised ones like the MPSS.
http://www.leftlanenews.com/subarus-sti-badged-brz-isnt-what-you-think.html
Something doesn't add up.
so the formula should be 264 HP at the flywheel (new) vs 184 = 80HP improvement. Now it starts to make sense. You guys are really bad at math; get Josh to double check the #s, he is usually correct.
Cross Innovate Motorsports supercharger of the list of potential mods. For the next wround wait and see what the Rotrex blower solution from Kraftwerks delivers, expected in a few months. Hopefully it puts up MUCH better numbers.
Really? Sans the pointless supercharger, how is this car a "pathetic waste of money"? It has decent speed, good gas mileage and handles exceptionally well.
Could it be faster? Of course! I assume that's the basis of the pathetic comment, right? Where do you plan on displaying this speed? On crowded road ways, where the potential to get a ticket/have an accident is high? In stop-light duels facing 2001 Civics with fart canons? Track (doubtful a majority of the people buying performance cars have even seen a track)? That in itself is costly.
How is a car that goes at decent speed (with decent maintenance) with good gas mileage that can double as a regular DD a negative; but driving conservatively (which you'll likely be doing) in faster car so it doesn't suck down fuel (and present possible maintenance issues) a good thing? Yes, the FRS can get beaten by a V6 Camry (or something equivalent, as long as it's straight-line), but who cross shops a Camry and the FRS?
