2013 Ford Focus ST Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The 2013 Ford Focus ST with the Recaro seat option features a head restraint design that some people may find uncomfortable.
It is m You don't have to be up close to the steering wheel for it to be an issue. I like my legs pretty well stretched out when driving but some headrests are just a bit annoying and others aren't as much.
If you like sitting back into the seat with your shoulders against the seat it actually doesn't matter how the seat is tilted as many of the headrests will force your head forward even if the seat is back and reclined some.
I think most drivers don't sit back into the seat like that so it isn't a large scale problem. Either they sit more upright than the seat and have it reclined back some so that just their lower and middle back rest on it leaving some space between their head and the headrest and some probably just slouch enough that it doesn't matter where the headrest is. So you have the alert drivers that sit away from the headrest and the tired slouching ones that sit away from the headrest and only the ones that like to be upright but have the seat fully supporting the length of their back that notice it. It takes a bit but usually they just adjust the a driving position where they sit at the same angle but the seat leaves them a bit farther down their back.
The biggest place it is noticeable, as mentioned in the article, is for passengers trying to doze off on longer drives. Since tilting the seat forward or back doesn't change the angle of the headrest in relation to the seat back it will typically be at an uncomfortable angle for resting (something drivers shouldn't do). Unless they are the type that sleeps with their heads on a pile of pillows most aren't used to getting comfortable like that.
Sure looks silly but if it's an issue for you and you're making a long trip, that's a solution.
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
