Have you recently switched from a gas-powered vehicle to an EV, or vice-versa? A national TV broadcast network would like to speak with you; please reach out to [email protected] by 12/5 for more details.
Are you a current or prospective Tesla customer who is having a change of heart about the brand? A national news reporter would like to speak with you; please reach out to [email protected] by 12/5 for more details.
Rotate Your Tires
Edmunds.comEdmunds.com Member, Administrator, Moderator Posts: 10,281
imageRotate Your Tires
Rotate Your Tires article on Edmunds.com
  • psgivenspsgivens Member Posts: 1
    I think I should point out that this article doesn't make any sense. Scott makes an argument that it is important to swap front/back tires but not side to side. In fact he argues against it. Scott seems to think the reason that we rotate our tires is because we parallel park.
    I don't know what the average driving habit is, but for me, I spend probably about 0.05% of my time parking and 95% of my time on the freeway.
    With that said, the main reason we rotate our tires is because the streets are bowed to allow for rain run off. This causes your tires to wear unevenly on one side. By swapping your left and right tires, you help your tires wear evenly. Swapping front and back is important too, but not as important as side to side.
    I believe the correct pattern is to bring the front tires directly back and swap the back tires as you bring them forward. Over time, they will enjoy the tread patterns of all four spots on the car.
    Thus, to do it properly, you cannot do it yourself with out a full car lift. You can however do the next best thing, swap the left and right tires by lifting the front or back end.
  • brewerguybrewerguy Member Posts: 11
    My 2012 Buick Regal's owner's manual lists no intructions on how to manually reset the air pressure monitors after the tires are rotated. My last car, a 2009 Malibu had such instructions. Is there a way to do it without going to a dealer?
