2013 Tesla Model S Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The 2013 Tesla Model S needs variable regenerative braking.
https://www.youtube.com/watch?v=78pYMZR5_rE
Here is just one complaint of many...
Dr. Bob Reinke | 26. MÄRZ 2014
Have severak times complained to the Chicago service center about this life threatening problem and been told that the brakes will always disable and overcome the the go-peddle. There are several problems with this false statement: I have tested the sequence on my P85 and found that if you are on the brake and enable the go peddle, the car goes. If you have enough brake peddle left, you can slow the car. The reason I say, "Enough brake peddle left," is because my brake peddle fades to the floor in about 5 to 20 seconds, depending on the previous brake use. The fading is worst in heavy stop and go traffic. The brake and go-peddle have a little over an inch side clearance in my Tesla and I can normally stop the car with my foot 7/8 on the brake peddle; however, that leaves enough of my size 10s hanging off the brake peddle, and over the go-peddle. Enough to depress the go-peddle when the leaking brakes bleed down to allow my shoe to engage the go-peddle. At that point, pressing harder on the floored brake peddle only depresses the go-peddle harder. With no further brake force, the Tesla rockets into whatever is in front of you.
when complaining about this problem at the Chicago service center, I was told that the Model S brakes don't bleed down. I found that the brakes in 6 of the 10 cars in for service all bled to the floor in less than 20 seconds. Then I was told that I was pressing too hard. How hard does Tesla think the driver is going to depress the brakes while it is charging into the rear of the car in front of him.
The unexpected acceleration is caused by several Tesla faults: The close proximity of the use diametrically opposed peddles---My 56 Oldsmobile had about 7 inches between. Perhaps they were smarter then? The brakes under NHTSA are supposed to override the throttle. Tesla brakes leak-down making them worthless, and let the shoe push the go-peddle. The Gong is ineffective because it sounds incessently over inconsequential alarms. Who is listening for a gong while your car is pushing the car ahead of you into the car in front of him. I now drive wothout shoes, so I can feel my foot on the break, or touching the go-peddle. The right fix would be to move the peddles, or perhaps make the return spring on the go beddle stiffer to telegraph to your shoe it is on it; however, if Tesla is too cheep to fix the peddles the cheaper fix is a keyboard stroke to properly softwear shut-down the go-peddle while the brake peddle is off the home proximiry switch.
I was told by the service tech that the brake always overrides the go peddle. Then he held the brake while he floored the go peddle, the rear of the Tesla humped up like a bull in heat and burned two black marks under the rear tires. Just like my Toyota did before the fix. Then he said that the brakes actually reduced the power of the drive motors. Obviously, it didn't reduce the power enough to prevent the Model S from taking off after the brake peddle bled to the floor in stopped traffic.
Perhaps the most relavant question should be can Elon afford to pay 4 billion dollar penalty (GM) for failing to respond to a clear safety problem? All the ridicule and smart remarks on this thread only iritate and resolve nothing of the problem. Apparently, those who are having the Uncontrolled Acceleration problem are the only who understand the danger.
Undoubtedly, there are the smart elete reading this who can never make a mistake, who will pick this entry apart, and solve nothing--but that prevents no deaths caused by an easily softwear mended malfunction. The fix costs is so little to save one life."
and THIS....
"when complaining about this problem at the Chicago service center, I was told that the Model S brakes don't bleed down. I found that the brakes in 6 of the 10 cars in for service all bled to the floor in less than 20 seconds. Then I was told that I was pressing too hard. How hard does Tesla think the driver is going to depress the brakes while it is charging into the rear of the car in front of him."
The shareholders and fan-boys will howl with indignation but THIS IS A DEFECT and the cars should be off the road until it is fixed.
and THIS....
Other than that, this was the oddest request I have read in an Edmund's test. The right pedal is already your "rheostat". Why not request a rheostat for brakes and acceleration too while you are at it?
My wife and I have had Regen set to Standard since we got our Model S last summer and think that the one pedal driving is ultra smooth.
