Why won't my car start? Lincoln LS.
anselmo1403
Member Posts: 2
I own a Lincoln ls v8 2003. The battery started to act as if it were dying it first started to die quickly (5-10 minutes) with the key turned but car off, then it went to about 2 minutes until it would die. Then everytime I turned it off and tried to turn it back on it was dead so I had to get jumps. Now it doesn't crank even with a jump. Now its jumped by another vehicle when I try to diagnose the issue. Fuse #1 (starter relay coil) was blown so I replaced it and it started to work again (battery didn't die either) for about 2 days until the issue came back. Now the fuse keeps blowing everytime I try to crank car. It only blows when I crank not when I turn it to on with engine off. The main starter relay is good, I changed the starter and cleaned battery terminals but problem still continues. I've disconnected the gear selector switch and when I cranked it the fuse did not blow. Once in a while when I turn to crank it it sounds like it wants to crank but noise stops after a second. I believe its a short but I'm unsure. I've wasted about 20 fuses and want this fixed anyone know what it would be?
