Rearview Display Delay - 2014 Jeep Cherokee Limited Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The 2014 Jeep Cherokee features a slow-shifting transmission and a slow-switching rearview camera and central display.
Also, I've driven several new Cherokees and I don't recall this being an issue, but I didn't spend much time in reverse.
From Page 272:
When the vehicle is shifted out of REVERSE (with camera delay turned OFF), the rear camera mode is exited and the navigation or audio screen appears again. When the vehicle is shifted out of REVERSE (with camera delay turned ON), the camera image will continue to be displayed for up to 10 seconds after shifting out of REVERSE unless the vehicle speed exceeds 8 MPH, the vehicle is shifted into PARK or the ignition is switched to the OFF position.
You can also turn those guidelines off, also in the settings, should you desire.
