52103717A Isolator
5010321AF Gear Kit
5017438AA Bearing
68056356AA Seal
5072506AA BRG Kit
5072498AA BRG Kit
5013477AB Sealant
03400850 Diff Side Bearing
axle replace & side gears
0300102 Ring Gear & Pinion...original damaged upon inspection backlash noted
Prior to the repair today Chrysler replaced the drive shaft, rear shocks, torque converter, rear wheel bearings, rotated tires, replaced front tie rods...did software updates...none of these prior repairs had any effect.
I have a 2003 1500 Hemi 2 wheel drive. A vibration begins in the rear end around the 60 mile an hour mark and worsens at around 70..it travels all the way into the steering wheel, driver and passenger seat, etc. I have noticed that it doesn't seem to start until I am about 15-20 minutes into driving. Not really sure if it is better or worse in cold versus warm weather....I live in Florida. Have had it into several dealers, several shops and no one can come up with any answers excpept to say it must be in the drive train. Have had tires road force tested, numerous parts replaced and I just started believing they were all guessing at the expense of my wallet. A couple of the tires were replaced when they showed slightly out of spec and it made a minor improvement...shocks, made a minor improvement...endless trips to the dealership to leave it for a day or two and then to find out the issue is still there. I finally gave up and have been living with the problem but in Florida on the interstate...if you aren't driving 70+ you are getting run over.
I would really like to get this fixed as I can't afford to take on a new vehicle at this time....if you could, let me know if you feel like this is the same issue you were experiencing.
Also, if anyone knows of a shop or dealer in the Orlando area that they have a good relationship with and can be trusted...i am all ears....i have heard a thousand times...not a problem....we can fix it....to find out it is not fixed and they don't have a solution.
thanks in advance for you advice, comments, insights..
i have a 2007 quad cab 5.7 hemi....im a.s.e. certified..i hooked my computer up to trans and all number were normal...i feel it want to shift to O.D (NORMAL) IF U have no other issuies i leave it be...
miles
a.s.e a1 to a9
g1 and g2(diesel
GOOD LUCK.......
If you have aftermarket wheels & tires then you have just taken yourself out of the loop of repairability (unless you get an eccentric mechanic to modify the suspension system for you). Chrysler will deny responsibility and blame it on road surface. I can confirm that aftermarket wheels and tires make it worse because I had a customer bring his vehicle to the dealership with that issue and we removed his wheels & tires and replaced them with a set off of a stock unit. The issue was resolved to the extent that stock wheels & tires will allow it to be but the issue was clearly intensified by the customers aftermarket wheels & tires. You should have seen the look on the customers face as we proved the issue. Funny. But the customer went on to say that was the last Dodge he would ever buy.
If you'll notice, the issue is exacerbated on freeways that are of cement construct. In fact, I've had some customers tell me they allegedly had to slow down because of the violent shaking they experienced. In other words, they had to adjust their driving habits to accommodate the engineering of the truck. On the other hand, when driving on BLACKTOP the issue is not as pronounced.
I can tell you without a doubt you will NEVER get rid of this issue. To Chrysler, the amount of customers that complain is not worth the cost of making an engineering adjustment in future production. Most customers simply accept the issue and move on. Personally, I would never own one for this reason (and I had 12 years at the company). Get used to it.
Anytime you have a wide expanse of sheet metal you can get oil canning. Many American cars of the 70s with their huge front hoods had this problem.
I'm looking for help. Legal advice. I put a huge down payment on this truck and bought an extended warranty.
Recently bought new tires because the last dealership told me Rams are notorious for cheap tires. This did not help!!! It also cost me 1,000 dollars. I just want the truck out of my life. Do I have case or grounds to sue Ram or get them to give me money back? Any help would be appreciated
