Suspension Noise Fix - 2014 Mazda Mazda3 S Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Our 2014 Mazda 3's suspension noise fix was a surprise.
The brake dust shield scraping against the rotor tells me that the dealer just assumed when he found this cut washer that he had addressed the entire issue (not a bad assumption, but still...not thorough), because a test drive is warranted if the dealer has been taking things apart to that degree, and a test drive of even a few hundred yards would have revealed the bent dust shield noise.
You're not supposed to go in and fix one problem and cause another. Once they found the washer, they basically threw the car back together, bending the shield in the process, and called you to come and pick it up, because your car over the course of those four days went from being a potential profit center to a cost center.
I would be putting the car up on my lift to look for improperly-torqued threaded fasteners, unsecured wiring looms or hose supports, dangling underbody cladding or splash guards and maybe damaged suspension bushings.
Glad I didn't take it to the dealer like 99% of owners would have...
I find it hard to believe with was there the entire time and nobody heard it up till now. I guess it could have been wedged in and then bounced loose so who knows. But the point is some manufactures wouldn't even consider covering something like that.
I had to take my Wrangler in for the left cylinder head 'recall' that cause the CEL to come on. Edmund's one had the same thing.
When I got it back it leaked oil. Took it back. It then leaked coolant. Took it back. It then had a nasty harmonic rattle in the dash behind the A/C unit that they have not been able to fix.
Yeah, I don't go to that dealership anymore.
NO HARM DONE. NOW I HAVE A NOISE FROM THE RIGHT SIDE, DO KNOW WHAT IS IT. WILL SEE.
