Transmission stays in lower gears when ambient temps are very cold
2015 Outlook 2.5 CVT - Regardless of engine temp/or oil temp, transmission will stay in low gears (relative - its a CVT) such that the car is always doing approx. 2100 RPMs. When it occurs, 35mph is 2100 RPMs; when problem is not present, same speed would be approx 1200 RPMs. Same for higher speed. 45mph would be 2100 verses approx 1400rpm. Gear indicator does indicate a '4' or '5' when it would nornally be '6'.
Outside temps in excess of 30 degress - no evidence of problem. Below 30, may or may not happen.
No check engine light and it does affect MPG significantly.
I've read quite a few complaints about CVTs in general misbehaving in extremely cold weather. I suspect Subaru will be addressing the issue soon enough in TSBs.
But really, it should clear up after 10 or 15 miles of driving---if it doesn't, maybe it isn't "normal" for your CVT.
Assuming it does go away after a reasonable time period, I would say it's normal.
You may want to crosspost over in Subaru Crew - Meet The Members II too, @topoff. Lots of "regulars" just check in there and miss new discussions.
I can paddle shift (while in D) to upshift (sometimes she indicates 4, sometimes 5) to 6th, but within seconds it reverts back to the higher RPM. After about 10 minutes of driving (what I consider to be long after being full warm, but I haven't got my laptop connected to be absolutely sure....), it will more naturally go to 6th and low RPM.
I suspect that the ambient temp sensor in the intake has a roll in this in addition to the coolant temp.
