Honda Pilot Electrical Problems
My 2004 Honda Pilot is somehow losing its connection w/ a power source. When this happens all dash gauges bounce up and down when I turn the car off. When I restart the car, the trip meter/exterior temp goes back to the trip meter even though I always leave it on temp. The entire electrical system will for a brief second completely turn off while I am driving the car. Occasionally harder to start than before - when attempting to start the car, it does nothing (similiar to having a dead battery, but my battery is testing fine). If I leave it alone for 30 min and try again it will start fine, however the entire system has reset itself – the radio needs the theft code re-entered and driver power window needs to be re-programmed. I cleaned battery terminals etc. but no change. The dealer says the car is testing fine – all electrical systems are fine, the battery is fine, grounding and connections are fine. Is anyone else experiencing this issue?
About a month ago both heated seats stopped working. I've checked and replaces the fuses and still nothing. Weird because the lights on the switches do not even come on.
Thanks for any help.
bjader
Was having the same problem as the 1st and 3rd poster was having. Saw the same problem over at the piloteers forms and someone there also suggested cleaning the battery terminals. Got some 5 dollar battery terminal brush from Autozone, some baking soda, water and a toothbrush... Cleaned off a whole bunch of gunk, used the brush and then drove some 4 hours back and forth on a road trip - Not a single problem.
Sounds too easy.
If that doesn't work, follow the cables and tighten and clean the other ends too (assuming you can get to them - one probably ends up near the firewall).
Also you could have an issue in the wiring harness or even the PCM itself which regulates voltage.
