2016 Acura MDX
I recently attended the Detroit Auto Show and I heard that Acura is planning to do an early release on the 2016 in the March time frame. It will come with a 9-speed transmission and they are making the entertainment system an option on the advanced model. I also heard they were making some additional options available for the lower-end models. Has anyone else heard any of this?
Check it out: http://www.acura.com/MDXLanding.aspx?model=MDX
X-Ray Specs: 2016 Acura MDX Gets 9-Speed Trans, Electronic Gimcrackery
Check it out: http://blog.caranddriver.com/x-ray-specs-2016-acura-mdx-gets-9-speed-trans-electronic-gimcrackery/
Check it out: http://www.consumerreports.org/cro/news/2015/02/acura-mdx-is-the-2016-or-the-2015-model-the-best-choice/index.htm?loginMethod=auto
Does this mean the MDX will get the factory installed CarPlay on the 2016 or 2017 model? Anyone with info on this from dealer sales staff?
Check it out: http://www.leftlanenews.com/apple-carplay-to-arrive-in-40-models-this-year.html
While the upcoming, larger and 3rd-row optioned 2016 RX 350 reportedly will have a surround view camera system, and panoramic sunroof options, and already has the heads-up display option on the 2015 RX, when will we see these options come to the MDX in the US (the Surround View Camera System has been available in Canada on the top trim MDX since the 2014 MY) ----> 2016 or 2017MDX? The Surround View Camera3 option is soon to be offered on the 2016 RLX Sedan Advance Pkg. and is similar to the 2015 Infiniti QX60 Around View Monitor, and the Lexus 2016 RX 350 Panoramic View Monitor; Surround View Camera3 uses four cameras to provide a bird's eye view of the surrounding area.
(Surround View Camera3:
For 2016, the Acura RLX with Advance Package includes the first U.S. application of Acura's Surround View Camera system3 that provides a 360-degree image of the area around the vehicle. The surround view camera system is designed to assist drivers during critical and precise maneuvers in snug parking situations. Using four separate cameras, views from behind, directly in front of, and both left and right sides of the vehicle can be displayed on the navigation screen. The system can also use all four cameras to seamlessly create a composite bird's eye image, to provide the driver with information about the surroundings. In addition, dynamic on-screen guidelines help the driver see their projected path relative to the lines demarking parking spaces or other objects, allowing them to maneuver with greater confidence and safety.)
Check these links:
1) Canadian availability: http://acurazine.com/forums/3g-mdx-discussion-2014-414/anyone-who-got-canadian-mdx-2014-surround-cameras-892165/
2) US 2016 RLX availability: http://www.acura.com/PressReleaseArticle.aspx?year=2015&id=8325-en
Does anyone know if the 2016 MDX has built-in keyless ignition safeguards, like a timed auto shut-off, to eliminate the risk of carbon monoxide poisoning, if you have an attached garage? And if not, is there a recall in place yet to retro-fit/fix this problem?
Check out the following link: http://abcnews.go.com/US/keyless-ignitions-led-carbon-monoxide-deaths-recalled-suit/story?id=33344253
