Road Trip to San Jose - 2015 Volvo S60 Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
I took the 2015 Volvo S60 for a road trip to San Jose. Here's how it went.
The Vette does that with 450hp.
As far as TMPS systems not showing individual PSI readings; some manufacturers are starting to ditch traditional TPMS sensors and are instead just using the wheel speed sensors to determine if a tire is under-inflated. If one wheel is rotating at a slower speed than the other three, it's a good sign that it's under-inflated and the system uses this to trigger a warning. This means that it doesn't actually have a certain PSI value to display. Nevertheless, it would still be nice if systems like this would at least indicate which wheel seems to be under-inflated.
No thanks to direct TPMS sensors. Unneeded extra cost to both the manufacturer and consumer when it comes time for replacement tires or a spare set of wheels for winter. Plus, they get all wonky in the autumn when temperatures fall or vary widely between night and day. Thankfully all of our cars use the ABS sensors so it is just a simple reset.
I continue to agree that this is the best car seat ever, super comfortable locally and on longer trips.
Now, about that TPMS.... There is no excuse for Volvo cheaping out. I believe the manufacturers are now required to put in TPMS, right? Someone who knows for sure, please comment further. That said, this is a so - called "premium" car from a so - called "premium" manufacturer. So, no excuses, this is simply a fail. And the issues RM noted on his trip when the TPMS alerted illustrate exactly why this is a fail.
As I have previously noted, Volvo cheaped out on more than one electronic system in the latest S60. RM noticed the speed limit indicator issues previously noted in an earlier report. This system is so completely unreliable that I simply turned it off to avoid further frustration. And please don't get me started again on the navigation system POI search mess, just wait until you try this out for yourself and see what you say. Good luck finding Costco, Barnes & Noble, etc.
