Problems with my 2000 Buick Park Avenue.
we have been having a bit of trouble with it lately. It was sputtering, then it would run fine. Then it would shut off at a stop light, then run fine. We got a new fuel filter and some sea foam and it started running better.
I went to the store and back since I repaired it, it ran perfect. This morning I tried to start it and it wouldn't even try really. Just kept making a clicking noise! I'm broke as a joke and it's our only car. Any suggestions?
Answers
attempts to crank? Do they dim?
Sometimes tapping on the starter moderately with something with mass
to vibrate it while someone turns the key may help it make connection
if it's the main contact inside which is moved by the small solenoid
you're hearing making the clicking. The main contact corrodes or gets
oil on it (is your engine dripping oil under the front valve cover down over
the area where the starter is?).
Are you able to try to jump it to see if that helps the symptom of a weak/bad battery?
Check the battery cables including the grounds to the engine.
Check the connections for the positive cable from the battery to the connections
next to the fuse box with the red positive connection.
If you are getting headlight dimming when you get the click, it might mean your car is hydro-locked IF you have been having coolant loss. That might also explain the sputtering which could be due to coolant seeping into the intake manifold through the seal around the intake manifold.
The pattern is if the coolant is hot after the engine is driven a while, it pushes more coolant through the seeping seal. Then when the car is shut down, more coolant leaks due to the residual pressure in the radiator. That coolant just happens to be going into a cylinder with the intake valve open when the engine stopped. It fills the cylinder with some coolant and as the engine starts to crank that piston tries to compress the coolant. Can't. And the engine won't turn. Symptom is headlights dim due to the starter drawing high current but can't turn the engine. The interior lights will usually show the strong dimming.
If this is the case, it needs to have a new upper intake manifold and seal installed. I recommend the APN upper intake with a metal sleeve in the tube where the EGR gases are put into the air stream as well as the new seal that's part of the intake. (ineedparts.com).
