Suburban stalls at 70 mph
Just drove from Kentucky to Florida, 3 times on the trip doing between 70 and 75 mph the vehicle just stalled
Pulled over to side turned key off and restarted right up and took off again at 70 for another couple of hours and then all of a sudden stalls. Had cruise on all three times plenty of fuel no warning just dies and starts right back up.
Made it where i was going but needless to say waiting for other shoe to drop, Cant find anything obvious
Any help would be appreciated since I have to go back in 9 days
Answers
If there is a trouble code associated to the symptom the freeze frame and failure records that also are set could help.
Have been reading about this exact problem in early 2000s suburbans. Evidently there was a recall on 2001s for the crankshaft position sensor, Most of the material I have read states that the CPS over time gets hot and does not contact or see the flywheel anymore and the computer shuts down the engine to prevent damage to the engine.
I am going to replace it myself today $42.00 at autozone and I will update this when I have some results
Its an 04 suburban 5.3L flex fuel with 190K
But if you comb the internet you will find a ton of articles about this stalling problem with these vehicles.
One site in particular had 73 posts on this subject and alot of them had replaced the CPS and drove them for thousands of miles afterwards and no problem. In full disclosure some were fuel pump related, One had changed the fuel pump, filter, and regulator and to no avail, Replaced the CPS and no more problem. I figured for $41.00 bucks and a little work was a good starting point
The site is TOPIX Chevrolet suburban
I did not replace the CPS. I replaced the Fuel Pressure Regulator drove approx. 1200 miles back to kentucky and she ran like a champ. No Problem
