No Parking - 2007 Dodge Charger SRT8 Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Repairs needed in the Edmunds long-term 2007 Dodge Charger SRT8.
the e-brake on my bimmer I could never manage to set up right, even going exactly by the shop manual plus using all new parts (the old one disintegrated completely after those little pins that hold it together rusted through the thin splash shield behind the rotor and it all got blended by the lug bolts lol). It kinda works but you have to pull it up almost 90 degrees and then an additional click..
Good thing I rarely ever park on an incline
Don't you have a section for used car buying tips?
"Step 8: Have the Car Inspected
If you like the way the car drives, you should have it inspected before you negotiate to buy it. A pre-purchase inspection can save you thousands of dollars. You can take the car to a trusted mechanic for a thorough inspection or request a mobile inspection. A private party will probably allow you to do this without much resistance. But at a dealership, it might be more difficult. If it is a CPO car, there is no reason to take it to a mechanic."
So yes, a high performance car can have both rear disc brakes and rear drum brakes at the same time.
