2000 Dodge Durango needed an engine computer. Got it and my truck cranked yesterday but not today.
Please if someone could help I would appreciate it
Answers
is the battery new & fully-charged? suspect it if not, and eliminate the possibility of too-low (or too high) voltage causing computer to malfunction. suspect the voltage regulator; it may be integral with the alternator.. look for corroded connections or damaged/dried-out insulation on wires. inspect the wire/connection from negative battery post to starter motor. and/or test it by paralleling it with a single jumper cable, and try starting the car with that single parallel cable in place.
