Which trim to buy on new Forester?
overhearoverhear Member Posts: 10
edited July 2015 in Subaru
I'm planning to buy a new Forester in the next few weeks and I'm trying to decide on trim level. My only requirements are a moon roof and heated seats -- so I've eliminated the basic 2.5i -- and good gas mileage is also a priority. But I know nothing about car engines, so I'm having trouble distinguishing between the remaining trims: 2.5i Limited and Touring, and Premium trims.
Are there truly significant differences in gas mileage between the 2.5i Limited and Touring, and Premium trims? Do they drive differently?
  • kyfdxkyfdx Moderator Posts: 269,922
    Unless you get the 2.0 turbo engine, all of those vehicles will drive the same.. Get the one that has the options you want.
  • overhearoverhear Member Posts: 10
    So, for me all the trims will be equal then. Is there a national new model search tool that will filter by trim and actually show prices? The Edmunds tool seem to require that you request a quote from each individual dealer. If that's the case, it's not much of a time saver.
    You can drill down with the Make | Model tabs above and you'll see on the second page a couple of boxes. One's he Model (preselected with the Forester) and the other is the Style (aka "trim") with 8 styles listed for the 2016 Forester.
    After you select your style, you can pick colors and options to get the MSRP and Invoice and TMV numbers. Hope this makes sense!
