Chevy Suburban 5.3L coolant leak into engine
I'm having a difficult time solving an internal leak of antifreeze into the top of the engine. It is getting into the valve train and apparently into the cylinders as well, but never gets into the oil pan. It uses about 1 gallon a week with no external leaks. Oil fill and PCV cover inlets are full of white/brown mix of water and oil. I've already changed the head gaskets once, about 6 months ago- they were leaking. Milled the heads flat, etc. Thought the problem was fixed but it came back in about 2 months. Any ideas?
It sounds like changing head gaskets fixed the problem for two months but the problem then came back, right?
Have you re-torqued your head mounting bolts after gasket change?
Arrie
No, never did that. We did end up having the radiator rodded out, it was clogged with the GM coolant - the engine got up around 240 deg. before we had it fixed. Of course it happened after the new gaskets. I'm afraid that with 140K now on the motor, it may be best to just go through it, but there is no sign of water in the bottom end and the oil pressure is still around 45 lbs. Will the stretch bolts handle a retorque?
I'm not sure what you mean by 'stretch bolt' but what ever the bolt is it will handle the re-torquing. Re-torquing is sometimes needed for head bolts because the new gasket settles a little bit. This used to be a normal procedure and I'm quite sure it still is for some car engines. Re-torquing the head bolts simply means tightening them back to the torque they were set to when the head gaskets were changed. This does not increase bolt stress.
Arrie
Head to a transmission shop to hear and diagnose your grinding noise. Depending upon what this problem is, may not be cheap to fix, but it could prevent a more catastrophic and expensive problem.
I've considered taking off the skid plate to try to visualize the source, as there's a small puddle - maybe an ounce of fluid - on the driveway or garage floor some hours after driving. I had it checked at a trusted garage, and the owner said that when pressurized (from driving) coolant can 'weep' from around the head gasket. He couldn't find anything. Its not getting in the oil and so far its only a mild nuisance. I just keep a bottle of coolant in the car when on long trips, and refill as needed every month or so. I can't afford major repairs, so for the cost of a couple gallons of antifreeze a year, I'll just keep on trucking.
That's exactly what's happening to my truck, word by word as you described. Took it to a mechanic and he said it's the water pump, however I doubt it. I think it may be a leaky gasket or something. If you find out what's actually causing it please let me know. One of these days when I have enough time I'll try to take the front apart and maybe find out where it's coming from. Good luck!!
I have a 2005 LT suburban that had me baffled for about its coolant leak. It was dripping around the transmission (the pink color had me thinking it was transmission fluid first), leaving a decent size puddle. I feared it was the intake gasket but the oil was clean and all parts of the front and side of the engine were clean and dry... just about to give up and ready to pay big money on a repair when i finally found the leak! There are 2 long hoses that connect to the heater core on the passenger side of the truck. There is a white plastic "T" connect to the fire wall and the o-ring seal on it was bad. The white plastic piece was fine, just the internal seal had failed and its right below it is the A/C drip pan. This was the reason the coolant was traveling all the way back to the transmission housing. You can't just buy the o-ring seal, i had to buy the entire "T" but it was only $35 and the job was not too diffucult. I was really glad not to have gone into the heads or water pump route to resolve this. Hope this helps others with the similar odd coolant leaks with out a clear source issue.
I have a 5.3 which is burning coolant. The exhaust smells of coolant and I have to add coolant daily. I don't have any coolant puddles on the ground anywhere I park. I am not a mechanic, but assume coolant must be getting into the engine somehow or it wouldn't be coming out the tailpipe as smoke.
We apologize for the unexpected concern! If you are unable to get the advice you are seeking, and would like a dealership to locate the leak, feel free to let us know. Just send us an e-mail to socialmedia@gm.com along with your VIN, current mileage, contact information and a preferred dealership. We look forward to your response!
Patsy G
GM Customer Care
