Gas mileage
Diesels enjoy running steady rpms all day. And at 1600 rpm, I was at my torque peak (420 lb-ft), so I was getting maximum "twist" the whole time - no need for shifting, even on mild hills.
Generally speaking, any engine will get its best economy just above its torque peak, hut it's up to the manufacturer to select transmission and axle ratios that translate that rpm to a usable speed.
Just as a comparison, I got 24.3 as i explained at a ste speed of around 57. If my average speed is 67, my mpg drops to 19.5-20.
With the old 4.9l V8 which was rated at 16/25 I usually get 19/28. The new northstar is rated at 17/26 but I'm hardly getting 19mpg on the highway! and 14 to 15mpg in the city if I'm lucky.
I don't have a lead foot, infact the engine hardly revs past 2500rpm and usually cruises around 1500.
Is there something wrong with my engine or is this normal for the northstars?
thanks!
But I have been noticing that around 50 mph the tachometer (engine speed) is pretty low (below 2000 rpm) and as I go near 65 the rpm also increases in almost the same proportion as speed. SO I find tachometer touching 3000 at 67mph. I have been trying to drive at 55 mph (and it is very difficult unless everybody in your lane does so) just to see how much the mileage difference it is going to make (I hope a lot).
Has anybody experimented with tachometer ?
Civilized, 55 very well might be the best cruising speed, I'm not sure. However, a bigger point is to remain at the same speed, no matter what speed you are going, for the best efficiency. Acceleration is what uses most of you gas. If you take freeway trips at a steady 55 vs. 65, I'm not sure you'll notice any difference. Just try to keep it steady.
If you don't know how an engine produces vacum, you don't know too much. Put simply, an engine is nothing more that an air pump. Vacum is created because you have pistons trying to pull in the air or air/fuel mixture into the cylinders but there is a restriction -the throttle plate(s). When the engine is at idle, the plate(s) are fully closed, restricting the amount of air that is admitted into the intake manifold. TaDa- thus producing manifold vacum that is used to power many accessories. Even when the plate(s) are partly or fully open,(gas pedal is to the floor) there is some restriction due to the fact that the engine is trying to pull many hundreds of cfms of air through an opening that only allows a few hundred cfm at at time. When you downshift- the term "engine braking" comes into play because you suddenly shifted to a lower gear and increased engine speed- the engine makes so much vacum in the manifold that this itself slows the car down. Assuming your foot has let off the gas pedal, this will be the case. In a diesel, however, this is not the case. Diesels have no throttle plates to control the air volume entering the engine, instead they change engine speed by the amount of fuel that is or is not injected into the cylinders. Because of this, they have very little vacum naturally created by the engine. In most larger trucks, they have seperate vacum pumps mounted to the engines to control things such as a/c, emis. control devices, etc. This is why they produce such a large amount of torque vs. horsepower.
Sorry, my mechanical engineering degree took over- sometimes I feel the need to explain things like this to people with questions like the ones here.
I said I'd have trouble detailing it, not that I don't know! And my trouble stems from when I posted that, if Edmunds is right, at 3am. I just couldn't figure out how to say it at that time. Thanks
-Later
