Has anyone with a 2008 GMC Acadia had any compensation or help at all from GM?
wcstephens
Member Posts: 3
Let me just start by saying anytime I drive this piece of junk...I am putting my life and others with me in danger. I have so much money tied up in this thing and after paying 270.00 this week for the second CV axle on the drivers side to be replaced (the passenger side was also replaced last year), I now need to spend 500.00 to have the motor mounts replaced. I'm not sure that I can even list all the issue and yes, I contacted GM about some of the issues and guess what...no help. One was with the emissions issue (purge valve) and we were leaving for vacation and had to get it fixed before leaving. It took so long for the GM rep to call me back and then to say they could not reimburse me and that I should have contacted her before getting it fixed and they possibly could have paid for it. Needless to say, she was not a very courteous person and rather hateful. Thankfully, some of these issues were under warranty, but it was in the shop more than driven or in my garage! When our son turned 16, we bought him a used vehicle...it was not a GM product and has been almost 3 years and has not had any trouble out of it at all!
6/13/08...bought 2008 GMC Acadia SLE...First mistake!
9/2008...fuse box caught fire and the car filled with smoke with me and my son in it. The fuse box was replaced
3/6/09...air bag light comes on constantly...re-routed the harness
11/17/10...left headlight blows...found to be inop d/t socket being shorted out on headlamp assembly
8/25/10...No AC...replaced front blower motor
1/19/11...air bag light comes on constantly again..replaced the connectors & re-routed
7/15/11...leaking coolant...water pump was replaced
12/1/11...drivers headlight inop & has moisture in it...dealership drilled holes in the light
6/29/12...low beam headlight inop...replaced both low beam headlights and connectors per recall
7/20/12...Car would not move...replaced wave plate, sun gear, stator shaft, and right front boot (due to leaking from the right front of the engine)
7/30/12...right back tail light full of water...drilled holes in it myself to avoid charge
3/8/13...master cylinder, brake booster and water pump replaced (for second time)
4/11/13...air bag light constantly on again...per dealer...685.00 to repair and charged me 35.00 to tell me that...needless to say I did not have it done and to date the air bag light is still on and off
6/30/13...would not start...purge valve leaking fuel...replaced
7/22/13...first call to GM for some type of help
7/24/13...no return call...left message
7/26/13...no return call...left message
7/31...no return call...left message...call finally returned and will get a call back August 2nd
6/17/14...2 CV axles replaced
8/19/15...1 CV axle replaced...informed motor mounts needed to be repaired soon for $500.00
6/2008 to date...constant squeaking in the steering wheel and air bag light on and off!
I'm sure there is more, I just didn't document it!
It's great of them to help you out, but in doing so do you know that now the techs pay is going to be reduced for doing the work? It would really be great if they still paid the technician the same rate for the job, but that isn't what is going to happen. The technician's labor will now be reduced for the entire job as if this was a brand new car. The labors that the technician will be paid for the job will be cut by a third to as much as a half of what it would have paid him/her otherwise. There are a lot of people who don't think that is a consumers problem and that's because they don't associate how the techs labor getting shorted like this ultimately chases good people from the trade.
To the original poster, it does look like you've had quite a few issues but I'm assuming most were covered under the 5/100 powertrain. The air bag issue on the other hand isn't acceptable. If you're working with a new dealership I'd stress that this issue originally started and repair was attempted while under the bumper-to-bumper warranty (if you were still in mileage at the time) and see if the district/regional GM rep will assist due to a safety issue that was never resolved. For safety equipment they usually have a little leeway to authorize courtesy repairs, especially if you can show a history back to when it was still under warranty.
Good luck with your dealer visit, @wcstephens. Please keep us posted.
If the dealer couldn't get technicians to work for the rates they're willing to pay they'd have to offer more money. That would take an increased share of the profits or result in higher labor rates charged for out of warranty work. Which one do you think they'd choose?
Since entry level techs are a dime a dozen and profit is so important we haven't reached a point where there's a reason for dealerships to pay more. Instead of complaining it would be better to offer advice to someone thinking of a career in auto tech so they fully understand it's going to be tough. Unless you get really good and develop specialized skills you'll likely be doing a lot of low pay work. This would be much better advice than to chastise a consumer about why their vehicle might not have been repaired adequately the first time (and speaks nothing of the design and original manufacture that plays a part in reliability).
Lower skill techs often get a lot of the warranty work and some might not have the training or experience to do it properly. That can be why a consumer can't get their vehicle repaired properly. The tech will get faster and better, accept the lower pay or move on. The consumer doesn't care.
Other times you have an experienced tech that doesn't want to put in the effort to troubleshoot. That's why there should be metrics and performance goals the dealership has to meet to keep their franchise along with public perception and having to keep consumers satisfied in order to keep the doors open, but unfortunately that isn't the case and bad dealers still manage to stay in business.
Now back on topic…
Also not sure if you've already done so, but since you have a safety related item that hasn't been repaired correctly you might want to head over to the NHTSA's web site at the following link and file a complaint so it can be documented.
https://www-odi.nhtsa.dot.gov/ivoq/
