Tire Wear After 20,000 Miles - 2014 Mini Cooper Hardtop Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The tires on our 2014 Mini Cooper are looking worn in the front, but they probably don't need replacing yet.
BMW may not recommend rotations due to RWD better equalizing the wear between front and rear.
fwd vs rwd has nothing to do with it.
mini IS bmw. bmw hasn't recommended tire rotations since the 90's by some accounts.
google it. you'll see only about a few hundred forum posts on it. one poster stated that that the 2009 owner's manual stated mini does not recommend rotating tires:
http://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/196709-mini-usa-does-not-recommend-tire-rotations.html
i RTFM (online version) for 2014 and on p. 174 it states:
"Rotating wheels between axles
Different wear patterns can occur on the front
and rear axles depending on individual driving
conditions.
The tires can be rotated between the axles to
achieve even wear. Your service center will be
glad to advise you.
After rotating, check the tire pressure and cor‐
rect if necessary"
what this means is it definitely is not covered by their maintenance program and if you want to pay for it feel free to speak to your dealer. I think it could best be stated that while mini says you *can* rotate your tires they don't recommend it.
i rotate the tires on both our bmws (and the other two) myself.
My FWD cars wear the front tires at a much higher rate.
conditions.
glad to advise you."
Sounds like they recommend it in this case, where different wear patterns are present.
Does this mean that the ride quality of these tires has improved over time, or are they still horrible but drivers are used to it now?
